Question about JVC DR-MV1S DVD Recorder/VCR
DVD displys "loading" constantly
Cant turn unit off Can play VCR OK Cant open DVD to check why jammed.
  • spudman2727 Jan 01, 2008
    Manual says the loading is normal for 50 seconds - it stayed on 20+ minutes and as noted, can't do anything in the mean time, including shutting it off. Unplugging didn't work either, it would come on and stay in loading...
I have the same unit with the same problem. Its been to JVC 2 times for power supply repair(the power supply overheats). I am now having this again and will send it a third time. I was told by JVC they will replace the unit after 3 repairs. We'll see??
Posted on Mar 13, 2008
  • 22 Answers
First of all if it is still under warranty take it back and exchange it or have them look at it. As far as it not wanting to turn off you can search for a reset button on the back of the unit. Reset it. Or if no reset button just unplug it and plug it back in. See if that helps. As far as being jammed. Unplug the unit. Very carefully take the unit apart. See if anything has been accidentally placed in the unit when a dvd was pushed in at the same time. I have experienced this before cause I have little kids. Things happen. Now there again by taking it apart could void any warranty you may have. Also something in the unit could also shorted a circuit out causing it to not turn off.
Posted on Sep 18, 2006
Why doesn't the open/close button on DVD player of DVD/VCR combo work?
Assuming there is not a forgotten tape stuck in the VCR side, the mode selection logic has gotten all confused. On the VCR side, a tape is grabbed and loaded to be played. There probably is an EJECT button that is enabled for later use. The DVD side is disabled so no buttons work. On the DVD side, the open/close button is enabled (if no VCR-side problem is detected), allowing you to place a DVD in the tray and close it to play. The VCR side is disabled so no buttons work. That's the theory. From your description a sensor on the VCR side may have failed or been damaged, causing the player to keep reverting to VCR and preventing use of the DVD side.
Sep 21, 2015 | Emerson EWD2204 DVD Player/VCR
Magnavox vcr/dvd combo the vcr part only plays for 8 seconds
What you have is called a transport problem in the VCR unit--the mechanism is either jammed or something in it that loads the tape is bad.
Every time it is used it cycles to self check the mechanism--if it fails it is usually a belt bad or a gear assembly not working.
Someone would have to open unit to see what is happening.
May 28, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My dvd player tray does'nt open when it should and when i insert a disc to play, it only plays for a few seconds then it stops but the disc continues to spin
Hello
The laser pickup unit of your DVD player may either be faulty or dusty. Just put in a cleaning disc into it and play it for at least three times, and check. If it does not help you, the laser pickup unit of your device should be replaced with same type and number. Just check the loading belt too. OK.
Dec 16, 2011 | Zenith XBV443 DVD Player/VCR
I have a JVC VCR/DVD-recorder, model DR-MV7S. It developed a problem... when you placed a DVD on the tray & pressed the "eject/open" button to take the DVD into the recorder, the tray...
This can be due to a faulty LOADING drive settings, It can be due to a misalignment of the loading section and so the load does not reset to the PARK CONDITION of the MODE.
It can be a aulty gear, belt or jamming in the drive.
You need to open the player, remove the mechanism and manually check the forward and loading motion which can confirm. If the belt or the drive is jammed this can be checked and replaced or reset.
Check the mode switch settings of the forward loading.
Sep 19, 2011 | JVC DR-MV7S DVD Recorder/VCR
Unlock telefunken tel9800 dvd/vcr combo region
open tray
enter 0520, then press up, down, left, right (these are the keys around the ok/enter button)
a message will appear on the screen showing current region
press 0 and enter
it should now play any region
hope this helps
Angel
Dec 16, 2009 | Televison & Video
Ejects cassette and powers off makes loud noise
A very likely situation could be that the VHS DECK ASSEMBLY has a jam or a problem. Remove the case of the unit and check for any damages or loose mechanisms, if all works ok and looks ok, slowy , carefully put a tape into the unit and see if there are any jams or anything stopping it from moving.
Nov 20, 2009 | Emerson EWD2204 DVD Player/VCR
Sanyo dvw 6000 dvd/vcr player
DVD loading mechanism doesn't load completely that's why opens after attempt of loading.
You need to open top cover of unit and inspect loading belt might be lose, tray timing can be out of phase, some wire got stuck with tray while loading etc.
Oct 02, 2008 | Sanyo DVW-6100 DVD Player/VCR
Unable to open my DVD player
i have same problem with vcr , all mecahnism ok but dvd ok but vcr does not work all mechanism ok beccause i check manul its and are ok let me know if you knw somethins , in your case chech manual it open the dvd internal and check for work manual . wilfred
May 27, 2007 | Panasonic PV-DR2714 27 in. TV/VCR/DVR...
Vcr not playing tapes, just ejects them
Not enough info. What is the product? Brand, model, how old?
May 13, 2007 | Philips MWD2205 DVD Player/VCR
JVC DR-MV1S DVD Recorder/VCR Logo
372 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
