Question about Miele 300 Front Load Washer
Miele w1213 detergent drawer will not open - seems to be locked closed, child lock on/off has no impact
  • 14 Answers
Some machines have a drop down drawer lock on the front bottom edge of the drawer , it is usualy held up by a screw
Posted on Aug 26, 2009
How can I open detergent drawer, opens about 20mm & won't come out any further
Pull the drawer out as far as it goes then lift it up and pull it out completely. It may be stacked due to detergent remainings.
So, you should clean the drawer with a soft brush under warm running water. Do not put the drawer into a dishwasher!
Replace the drawer by tilting it into position.
Hope it helps.
Jun 08, 2015 | Asko W6021 Front Load Washer
Tip
My Miele washing machine is locked.
Recently I received many requests from users in troubles because they could not unlock their washing machine.
I decided to publish a tip illustrating the unlock procedure.
These instructions apply to most Miele front loading washing machines. They will work on all the W4800 series washers.
Instructions on how to set on and off your Miele’s child lock function are also contained in the user manual.
If you attempt to open the door while the Child Lock function is activated you will get the message "Machine locked" and the picture below on display:
If the door lock is locked during the wash cycle, press the pause button, and the door will open.
In order to deactivate the Child Lock:
  • Press and hold the "Heavy Soil" button until the display shows an unlocked pad lock picture and says Ready to Use (hold up to ten seconds, it should be less).
If you want to re-activate the Child Lock:
  • Press and hold the "Heavy Soil" again, until the display shows a locked pad lock picture and says Ready to Use .
The drum door cannot be opened, and the machine may stay locked if one of conditions below is occurring:
  1. The water temperature is more than 55°C (130°F).
  2. The water level is too high.
  3. The Child Lock function is activated.
  4. There is a fault.
If the washer is in one of the above conditions, you will get the machine locking even if child lock is off.
If the door is locked because of a fault, and there is water in the drum, the machine will also lock up.
In that case the door will open only after accessing the drain pump.
The pump service door is opened using a tool stored behind the dispenser drawer.
The tool must be used only after disconnecting power.
I think I will post a detailed procedure on how to fix a blocked drain pump on the next tip.
I hope this tip has helped you to fix your problem.
Goodbye.
on Dec 10, 2009 | Miele W4840 Front Load Washer
How do I turn off the locked drawer option?
If you've followed the instruction on page 9 of the User Manual and it still doesn't work, unplug the dishwasher for several moments and plug back in. This seems to revert all settings to default.
Jul 09, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Washer detergent drawer will not open...drawer lock or detergent cup?
Something has jammed the drawer closed. You will need to access the top of the dispenser.
Remove the 2 screws holding the top lid in back. Slide the top lid rearward and remove.
Pry open the top of the dispenser top and using a small screwdriver, unsnap the lid snaps.
This will release the drawer and you can clean out any debris that caused it to jam up.
Good luck.
Jul 08, 2011 | LG WM-2277HW Front Load Washer
Top drawer would not open. I got it open unplugged unit and now it opens and closes fine but the lock indicator is on and the drawer will not turn on. When i press the Lock button nothing happens.
The child lock has engaged. Press the lock button for 4-5 secs and hopefully it should disengage.
Please post a comment to say if this helped.
It would also be helpful to know under what conditions the drawer lid locked up in the first place.
Sep 16, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Have a Miele W320, during the rinse part of wash cycle, water pours from underneath the detergent drawer. What can I do to stop this happening?
Is the drawer gunged up? Are you using too much detergent?
Remove the drawer, and clean it with hot water and a brush.
Look into the empty drawer slot for any blockages and remove.
Replace drawer, try pouring hot water into the open drawer to try to dissolve and clear any blockages.
Consider using a dosing ball and adding detergent to the drum.
Feb 18, 2010 | Miele W320 Front Load Washer
Fisher paykel drawer dishwasher is stuck open and will not close
Hey I dont know if you have this problem, but with mine the gasket seemed to be blocking the opening, so you could close it, but you had to shove a lot. The FP help line said to just unplug and replug in the unit. I did it and lo and behold it worked fine again. It did seem to leak a little bit the first time I reran it, but that seems to have gone away. Hope this helps
Nov 14, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Three straight lines on display.
Open the door, and in the gasket is the light, tighten it. All should be good.
Sgt 48
Mar 24, 2008 | Miele Touchtronic W1213 Front Load Washer
Miele 300 Front Load Washer Logo
133 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
