Question about Philips 42PF7320A 42 in. Plasma HDTV
Black band running from top to bottom of screen
There is a black band about 6 inches wide running from the top of the screen straight down to the botton of the screen, it is just to the left of the center of the screen
  • 5 more comments
  • dheckle507 Oct 31, 2008
    Is this an expensive item to repair? What would prevent it from happening again? Is this a recurring problem once it begins?
    Is it harmful to the tv to watch it till it goes to the shop?
  • Anonymous Apr 11, 2009
    did you get it resolved? I have the same problem and I am not sure how to solve this.
  • tela2 Apr 14, 2009
    six inch band in the middle of the screen.
  • dmatadha May 14, 2009
    5-14-09 I have similar problem. The black band is about 3-4 inches and runs top to bottom almost in the center of the screen (slightly to the left). I called Philips rep and she told me to take it to a local repair place (certified). I bought the Philips 42 PF7320A three years ago.
  • Anonymous May 15, 2009
    panasonic 42" thank goodness it happened 2 weeks before the warranty expired!
  • Anonymous Mar 17, 2014
    Black band from left to right about 2" down from top and about 2" wide
    Problem Solver:
  • 10 Answers
If this line goes from top to bottom its going to be your display there are ribbons on your tv at the botton that control vert drive the ribbon is either bad connection or most likley the display is bad take off back and gently press on ribbon where the black line is if it fills in its the ribbon if not its the display
Posted on Aug 12, 2009
  • 905 Answers
This will need to go into the shop to get one of the video processing boards replaced that controls that part of the screen , this will happen when it gets to hot inside the set ,( thermal break down)
Posted on Oct 31, 2008
  • jason Nov 01, 2008
    yes , because now the extra voltage that is supposed to be taken by that board lays on the power supply and other components
    it would be advisable not to have it going while there is a problem
White band from top yo bottom of screen
Good luck with this. If it is under warranty, Sharp will take forever to do anything about it. I had this issue and Sharp wanted pictures of the problem, Pictures of the serial and model number and the receipt. I sent it to them 6 months ago and never heard anything back. If it is not under warranty, this is a major repair and it may cost more than a new television.
Apr 11, 2014 | Sharp LC60E88UN 60 in. LCD TV
Disney princess tv suddenly narrowed the visible part of the screen. Now everything is squished into a two in wide band with all the rest of the screen is black.
if that 2 band according to you from top to bottom,it has a defective vertical stage.if this two band appears one on top and one at the bottom,it`s on vertical stage.leaky capacitors,resistance changed or resistor devalued ang ic`s, are too weak to amplify a signal to make the screen complete....
Jan 29, 2014 | Disney 13" TV
Wide black vertical bands on copies
Remove scanner glass, refix CCD cable & try. If problem persists replace CCD ribbon cable..
CCD snap shot:
Jan 28, 2013 | HP PSC 1610 All-In-One InkJet Printer
Panasonic TC-P42S2 .. Transparent 2 inch wide vertical discoloration on panasonic 42 inch plasma, very left of the screen.
Fixed mine, myself! Black 3 inch vertical band (stripe) appeared after a cros country move on our PC-T50G10. Occasionally we would see white band with multicolored pixel width stripes. Took the risk of taking off the back to see if I could see anything. Found places on sides and bottoms where plastic like 2" flat cables could be seen. Guesstimated where the band was and found that I could flip down a black cover on one end of the cable. Tried to pull it, gently. Mistake. Realized it wouldn't one out like computer hard drive cables, so I took out the screws holding the plate on the other end (it's only an inch long). That allowed me remove the cable. Took it out, cleared away dust, put t back and closed the black over. It worked! Put the screws back in, back on and... we are happy (although I do have four extra screws!). Just be gentle.
Feb 17, 2012 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Strips of 2 inch wide black and white, running top to bottom
Definately a damaged screen, no way to fix it for less than the cost of a replacement screen sorry.
Jun 16, 2009 | Philips 200P4 (Silver/White) 20.1 in. Flat...
A bar code stripe on the right side of the copy.
i'm not sure if you're talking about a solid black band or a bunch of little stripes running down page. does it happen when you run an internal report or only on copies? if its a black solid band, check and make sure the bluish colored tab on top of the drum is all the way to the left side. if its a group of fine lines, depending on whether it happens on internal reports or not, it could be the drum is going bad or you may have a bad scanner. write back with a little more info if this suggestion doesn't work.
good luck,
Mar 18, 2009 | Brother IntelliFAX 5750e Laser Fax
Dark band on left side, Samsung HL-R5668W
the reflecting mirror is likely loose and falling down inside the light reflecting tube. you should have seen the band getting darker and larger,
the small mirror is in front of the lamp and bends the light,
remove the lamp and look down the tube (light path)
May 06, 2008 | Televison & Video
Picture is off kilter on Samsung HLM5065W
It is a setting in menu just play with it you will get it wright.
Oct 25, 2007 | Samsung HLM5065W 50" Rear Projection...
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Monitor has a bad sector
I suggest you tackle logic board.
Oct 04, 2007 | Acer AL1913 19" LCD Monitor
Philips 42PF7320A 42 in. Plasma HDTV Logo
645 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
