Question about Smeg SE399X/5 Stainless Steel Electric Single Oven
Smeg oven SA392EB cannot reset clock
I cannot set the clock on my oven. There is an A that comes up but as I dont have a user manual I do not know how to take oven off auto. I have tried several combinations but have had no sucess. Help!!
  • Anonymous Dec 20, 2008
    I have the same problem and the manual is useless we have tried everything.
  • Anonymous Mar 13, 2014
    Reset clock from Auto to Manual
Turn off at mains, turn on again. 0:00 will flash press the manual op key ( on mine button on right) use +/- keys to set the time. Don't use buttons with wavy lines as they are for setting auto cooking time.
Posted on Dec 08, 2008
My SMEG SA392EB did the same thing. Turning off and back on at the wall did not reset. In the end, turned it off overnight, then back on and left on for a few hours, then accidentally found that touching the very left of the buttons (the bell) did make the timer show up, dimly at first, but then gradually became brighter. Was then able to turn off and back on to reset clock
Posted on Feb 15, 2010
8.1 Clock adjustment When using the oven for the first time, or after a power failure, the display flashes regularly and indicates . Press the keys and at the same time the keys or : each single press changes the time by 1 minute either up or down.
For the SIL63VML
http://www.smegtech.com/site/smeg/pdf_libretti/914772046-GB.pdf
Posted on Dec 22, 2010
Smeg pyrolitic oven is setting an alarm off on clock after we set the required temp it will start to heat up then the alarm goes off if not quick enough to reset clock, it then locks the oven door
in cleaning a pyrolitic oven is suppose to lock the oven door , this is a safety feature due to fact that oven gets up much higher in temp than a normal oven , the heated air it produces if let out would flash burn anything in front of it to ashes (people,pets,rugs,etc.) the clock doubles as your display window to see what temp oven is at , there should be a clock selection to see current time of day even if oven is in use , and last but not least , it has a delay cleaning start feature , you can set it to come on and clean it's self , Id recommend not to use this feature for safety reasons (I don't think the mfg thought that feature out too much )
the door should remain locked till oven temp is below a preset minimum safe temp ,id not force it open for safety reasons
Sep 28, 2015 | Smeg Ovens
Smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Apr 10, 2008 | Smeg SE280X Stainless Steel Electric...
Smeg SD012 top oven failed
Is the clock set to auto and not manual? Is the clock display flashing? If so then set to manual, this should do the trick
Jan 17, 2014 | Smeg Ovens
My SMEG oven will not work, when I try to turn on the oven the whole thing powers down (the clock timer dies) The only way I csn reset this is to switch the power at the isolation switch off and on several...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 20, 2013 | Smeg Ovens
Model SA392EB
Feb 15, 2013 | Smeg Ovens
SMEG DUCO4SS double oven electronic timer the bottom (main) oven does not work no light comes on and no heat but the fan does come on i have sitched the power off waited and then reset the clock
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Apr 07, 2011 | Smeg DO81CSS Electric Double Oven
Since a power cut yesterday, our Tecnik 8522 oven has flashing 'A' (Auto) on the clock & the bottom oven does not work. I know I have to reset the time to get te A off but no buttons work on the facia...
If you cannot change it from auto. to manual it doesn't mean you need a new oven. The electronic timer can be by-passed fairly easily by joining the active and oven load wire together..
Feb 10, 2011 | Ovens
Need a wiring diagram for a Smeg Oven SA392EB
I don't know about Smeg, but major appliance manufacturers in the United States generally put a wiring diagram inside the back of the oven, usually either on the back cover or on the back panel of the oven itself. In laundry equipment, sometimes it's folded up or placed in an envelope inside the control panel, but I suspect that would not be the case for stoves because there would be a greater risk of fire.
Dec 16, 2010 | Ovens
Our smeg oven is not working. the clock is on but the oven and grill will not work? Help!
Check that the oven is on the 'manual cooking' setting rather than Automatic, if its on Auto it will not come on until the time set.
Dec 12, 2010 | Smeg Ovens
Smeg SE399X/5 Stainless Steel Electric Single Oven Logo
4,718 people viewed this question
Top Smeg Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
