Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso I have replaced the circuit boards and the level (water) sensor and it still won't work. If I push the stop/cancel button, the timer displays 7min and the extend spin and cycle signal (softer) lights come on. It also sounds a beep tone, but not in a regular pattern. What should be done next? Target practice? Thank you gain for your time. Mark I have the exact same problem
  • 2 more comments
  • wgwhite Oct 31, 2008
    No bad contacts
    the buttons are not stuck
  • wgwhite Nov 01, 2008
    the drain pump is working correctly
    President:
  • 1,952 Answers
Water level controls - The water level control is also know as a pressure switch, this is where you set the water level ( small - medium - large ). The water level control is responsible to shut off the power to the fill valve and direct that power to the timer so the washing machine can start up. The WLC has electrical contacts in it that sends power to the fill valve and when the WLC is satisfied the water level is correct the electrical contacts open power to the fill valve and send the power to the timer and the washer starts. Picture of this here. How the water level control knows when it is time to shut the water off is, a air tight hose runs from the outer washer tank to the water level control. As the water fills the outer tank air is pushed up the hose, depending on which setting you have made ( small- medium - large ) is takes a certain amount of this pressure to make the WLC cycle over and shut off the water and send this power to the timer. If this hose develops a leak or a pin hole the washer can over fill as the WLC may not be able to shut the water off. The water level control can also break down and allow the washer to over fill as If you have a loose hose on the water level control or tank end, use a plastic wire tie to help hold the hose tighter and make a tight fit.
~ The water level tube (tube that runs from the square box), access panel on the outer drum where the bleach tube also ends) from the pressure sensor switch (front panel) can become clogged. Or the two holes from the outer tub into this square box panel on the outside of the outer tub can become clogged. Either clog, I am told by my help repair guy can cause the sensor to think that there is still too much water in the tub and so will not allow motor to activate spin.
~ If the water level control contact is bad, it may also stop the filling ok, but not tell the washer to start agitating.
well.
Posted on Nov 01, 2008
    Genius:
  • 1,011 Answers
Dear,
do you hear a low hum from pump? if so something may have pump blocked new style pump has 3 torx screws in bottom remove them and clean pump old syle was a lost cause drive splines in pump would strip and motor would not drive pump
regards,
    President:
  • Whirlpool Master
  • 2,651 Answers
Id have to agree, that sounds as if theres an issue with the keypad, always wanting to restart a spin only cycle, replacing te console/ keypad, would be your fix, id agree with the target practice as well though, it is a nightmare machine..one im sure whirlpool wishes it never had produced
Posted on Oct 31, 2008
  • Whirlpool Master
  • 19,396 Answers
It was not the timer, before replacing the control assembly you should have checked all possible faults.
Stuck on 7 mins means that it is stuck on rinse, sometimes it does not drain read here :
Washer stuck on 7 min - FixYa
or
Stuck at 7 mins left
Test the drain pump and the inlet valve by ebnergizing them, see if there are objects stuck in the pump.
Check if the drain hose is obstructed.
Thanks.
  • 958 Answers
Hi, i think you could have the touch pad problem. that is always an issue with the calypso. it would be just very hard to test all buttons if they are opening up. normally the problem is a stuck button.
kindly check all buttons if they are not sticking.
tnx 4 using fixya,
drcool
    Scholar:
  • 155 Answers
check out this link
exactly for your problem.
  • 8 more comments
  • fixexpert Oct 31, 2008
    you can just directly click the link and go to trouble shoot page in that link and all it is given in it.
    thanks.
    OPTION DESCRIPTIONS
    Soil Level
    Soil Level adjusts the amount of nutation or spray wash time in the selected cycle. It is valid for all
    cycles except Extend Spin and Rinse & Spin stand-alone cycles. Soil Level changes the 7-segment
    display in 1-minute increments, looping back to the minimum time once the maximum time has been
    reached. The following table shows the time display in the 7-segment display for a given cycle and soil
    level. These are total estimated times for the entire cycle.
    End of Cycle Signal
    There are three (3) volume levels for the End of Cycle Signal, HIGH, LOW and OFF. Pressing the END
    OF CYCLE SIGNAL keypad toggles between these options by lighting one of the LEDs and beeping the
    corresponding end of cycle signal at the volume level selected. The LED remains lit during program
    mode and running mode until the cycle is complete.
    If OFF is selected, no end of cycle signal will beep, but all key and warning beeps are active.
    The end of cycle signal is set at a short high pitched, followed by a longer lower pitched tone, repeated
    four times.
    Changing Cycles and Options
    You can change Cycles and Options any time before Start is pressed.
    • A short tone sounds when a change is selected.
    • Two short tones sound if an unavailable combination is selected. The last selection will not be
    accepted.
    Changing Cycles after pressing Start
    1. Press STOP/CANCEL twice.
    2. Select the desired wash cycle.
    3. Press START.
    The washer restarts at the beginning of the new cycle.
    NOTE: If you do not press the Start within 5 minutes of pausing the washer, the washer automatically
    shuts off.
    Changing Options after pressing Start
    You can change an Option anytime before the selected Option begins.
    1. Press STOP/CANCEL.
    2. Select the new Option.
    3. Press START to continue the cycle.
    CYCLES
    Use the cycle pads to choose the right washer cycle for the type of fabrics you are washing.
    • For most loads, use the default soil level recommended in the preset cycle settings.
    • For heavy soil and sturdy fabrics, use a higher soil level setting.
    • For light soil and delicate fabrics, use a lower soil level setting.
    If you select EXTEND SPIN and do not select a wash cycle, you will get a 7 minute, high speed spin
    cycle.
  • fixexpert Nov 01, 2008
    The automatic service diagnostics mode is a short demonstration to provide an automatic check for
    major wash functions.
    The automatic service diagnostics mode is activated by pressing:
    SOAK - SOIL LEVEL - SOAK - SOIL LEVEL
    within five (5) seconds while the machine is in Standby Mode. The 7-segment LED will display the
    countdown of the time remaining for this test in seconds. A Soil Level LED for each dispenser will be
    lit while the valve is actuated.
    The manual diagnostic mode will enable activation of specific machine functions without having to run
    a cycle. Each function test will time out in three (3) minutes. To enter the manual diagnostic mode:
    1. Press: SOAK - CYCLE SIGNAL - SOAK - CYCLE SIGNAL
    “dt”.
    2. Press the WATER TEMP keypad. The 7-segment display show “00”. See Nutate and Recircul
    ate Test on next page.
    In this mode the Peekaboo function is disabled. Opening the lid will stop the drive motor and all
    functions.
    Sales Demo Mode
    The Sales Demo mode is activated by pressing:
    SOAK - WATER TEMP - SOAK - WATER TEMP
    within five (5) seconds. “Sd” should be displayed in the seven-segment display when activated and the
    following cycle should progress. The STOP/CANCEL key can be used to return to standby mode at
    any time during the cycle. No options are active during this cycle.
    If the lid is opened during this cycle, the Peekaboo function will be active. This cycle should not require
    the lid switch to be opened afterwards to run another cycle, (i.e. no “LS” check).
    IN THE UNITED STATES:
    FOR PRODUCT SPECIFICATIONS AND WARRANTY INFORMATION CALL:
    FOR WHIRLPOOL PRODUCTS: 1-800-253-1301
    FOR KITCHENAID PRODUCTS: 1-800-422-1230
    FOR ROPER PRODUCTS: 1-800-447-6737
    FOR TECHNICAL ASSISTANCE WHILE AT THE CUSTOMER’S HOME CALL:
    THE TECHNICAL ASSISTANCE LINE: 1-800-253-2870
    HAVE YOUR STORE NUMBER READY TO IDENTIFY YOU AS AN AUTHORIZED SERVICER
    FOR LITERATURE ORDERS:
    PHONE #: 1-800-851-4605
    IN CANADA:
    1-800-461-5681
    THE TECHNICAL ASSISTANCE LINE: 1-800-488-4791
    _____________________________________________________________________
    Brigadier General:
  • 3,614 Answers
This possibly a bad contact on the panel board, thats why the system malfunction by itself. better to check on the every switch contact and clean for any moisture on the board.
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 | Dryers
Calypso will not advance past wash cycle. I have a Calypso GVW9959K washer that displays no error codes and will run all functions in test mode. Problem is - it will run forever in the wash mode (clock...
If the machine is filling and washing but not advancing then the timer mechanism is not fuctioning. There is no codes so all other parts must be working, likke the pressure switch. You might test the door or lid switch this can sometimes hang these up. to test simply jump across the switch with a jumper wire. Basically
  • If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  • If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  • I am supplying the service manual for this machine. Please be careful when attempting any repair and always make sure the machine is unplugged before starting any repair. This manual include service guides for testing components as well if your capable of these tests. The link will lead you to the manual. These manuals are not easy to come by due to the fact they are meant for service personell who make a living on these so it is inclusive and should help you in you issue.
  • https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
  • May 13, 2011 | Washing Machines
    Have a Whirlpool GEQ9800LW0 and it won't start. When I set the timer and push the start button nothing happens. The timer still makes it's usual clicking sound but the dryer won't start. What needs...
    Check power to the inlet valve, if absent let the program move forward and if the motor does not work either it is possible that thetimer though ticking is not contacting.
    So go back to check for the wash cycle, when start is pushed, inlet valve on, water comes in, water fills , triggers level sensors,washing starts with motor on.
    If there is no voltage on any parts ,the timer contactor is faulty
    Sep 19, 2010 | Whirlpool GEW9200L Electric Dryer
    Won't fillCalypso whirlpool washer model#GVW9959KQ1 LD on display
    LD is long drain error, the machine does not fill because it is in fault mode, but error is on drain system.
    If there is a drain problem, the parts that must be checked are drain hose, pressure switch, drain pump assembly, timer control.
    Check if the drain hose at the back is kinked or blocked.
    Test the pressure switch, blow into the small hose, and use a multimeter to check if switch has continuity.
    Remove access panel and get to the drain pump hose to check for ablockage. You will need to disconnect the hose and collect the water.
    Keep a container ready to collect water when you undo pump hose.
    Ifall the rest is OK, test and eventually replace timer board.Problemwith water pump are far more commonly causing this problemsthenfaulty timer board.
    Parts and diagrams available here.
    Oct 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
    Kenmore elite calypso doesn't respond to buttons except cancel
    I've had a similiar problem on my calypso. In my case the key pad would go dead after washing or pushing stop after a few minutes. If I unpluged the unit for a few minutes it would work again. This would appear to be in the controller board. I removed the board and inspected it finding no problems. After re-installing the board the washer appears to be working again. My conclusion is that there is a loose connector/connection. I'd suggest you remove and re-install all the connectors on the controller board. This is the board closest to the power chord.
    Good Luck, George S.
    Sep 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
    Timer dosent count down
    HI, this is a simple fix here, you will need to replace the timer/control module. this will fix this issue. this specific device is ruined and, unable to initiate the wash cycle correctly due to circuit damage.
    May 18, 2009 | Whirlpool Calypso GVM9959K Top Load Washer
    Lights,tries to run
    Sounds like you have a bad control board but could also be a pressure switch problem. You would have to have a technician check it out. The calypso machines were discontinued after a class action law suit. They have multiple issues and are not worth repairing. Save your money and buy a new machine.
    Jul 30, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
    Whirlpool calypso
    Jun 27, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
    LTE6234 Whirlpool Twin Thin Timer Broken?
    Check for voltage at the water inlet valve with the timer dial pushed in or in an off position. If no voltage replace the water valve. If you do have voltage you'll have to trace the circuits back from the water valve to the line. One point of demarcation is the water level switch. Pull the violet colored wire and see if it still fills while off. If it does it's likely the timer's bad.
    Jan 31, 2008 | Whirlpool LTE6234D Top Load Stacked...
    Whirlpool Calypso - Will not start
    You ever hear of dog years? Well Calypso follows those same guidelines. So your machine is 35 years old. These are the Edsel's of washing machine fame. I had a Calypso for 6 1/2 years. 3 pumps, numerous circuit boards, drive motors, phone calls and arguements with Whirlpool, along with machine downtime. I finally junked it and bought a Whirlpool Duet 9200 HT (get the made in Germany machine). A world of difference in wash quality. Fresh smelling unballed clean clothes. The Calypso was removed from the market and the subject of a class action lawsuit. Just Google it and start reading. Get comfortable first. There's a lot to read.
    Nov 06, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
    Whirlpool Calypso GVW9959K Top Load Washer Logo
    163 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
