Question about Panasonic Lands Phones
Had service interrupted yesterday and had it restored today but i cant get my phone to work
  • 5 more comments
  • dee-hudson Oct 31, 2008
    My teleppone service was interrupted yesterday and i had it restored today but i cant get my phone to work i have the talking telephone model # KXTG6051S
    My teleppone service was interrupted yesterday and i had it restored today but i cant get my phone to work i have the talking telephone model # KXTG6051S it keeps telling me i have no link to base get closer when i do nothing happens
    My telephone service was interrupted yesterday and it was restored today. i have the talking phone model #KXTG6051S and the service provider is AT&T There is no dial tone and the words on my telephone keeps saying No link to base move closer to base when i do nothing happens
    I said i have a talking phone and the model # is KXTG6051S
  • dee-hudson Nov 01, 2008
    tried unplugging my phone still not working
    PLEASE TELL ME HOW TO GET MY PHONE TO WORKING AGGIN AFTER BEING INTERRUPTED My service has been restored phone still not working its a paasonic talking phone model# KXTG605S 5.8 ghz gigarange
    what if i tell you that my husband had unplugged the phone and hooked up the coffee machine in its place and all i did was look atthe phone jack and not the plug itself .would that make me stipid? lol my phone is working and i went through all this for nothing can i get my money back?
    President:
  • 2,712 Answers
Try this:1. Move closer to the base unit, and try again.
2. Make sure the battery is installed correctly and fully charged.
3. Confirm that the base unit’s AC adaptor is plugged in.
4. Unplug the base unit’s AC adaptor to reset the unit. Reconnect the adaptor and try again.
5. The handset’s registration may have been canceled. Re-register the handset:
a) Handset: { MENU} i { 0}{ 0}{ 1}
b) Base Unit: Press and hold {LOCATOR/ INTERCOM} until the IN USE indicator flashes.
After the IN USE indicator starts flashing, the rest of the procedure must be completed within 1 minute.
c) Handset: Press { OK} , then wait until a beep sounds.
d) { OFF}
Posted on Nov 01, 2008
    Guru:
  • 859 Answers
Your hand held unit needs to be resynced with the base unit channel to talk. To do this place the remote on the base unit. Remove power from the base unit, leave the phone line plugged in. Restore power to the base unit by plugging it in. After a minute or so, the base unit will power up and as the remote is in the base station, the two will sync up.
Now, having said that, there may be a menu item in your base unit display that you need to navigate to that actually says "Sync Remote to Base press Ok or Enter". As you navigate and find the words in your menu that are similar to what I just stated leave the remote in the base station cradle.
In all cases when a remote needs to be synced up to a base unit the remote has to be in the base unit cradle. You do not always need to find the menu item to activate it by pressing OK or Enter. But this varies among models and variations of models. This is how you will inevitably sync your remote hand held. So, give this your best effort.
Regards,
Worldvet
  • Glenn Rogers
    Glenn Rogers Nov 01, 2008
    All of use who had her check the plug or unplug the unit, etc. get to split the four bucks.
    WV
    Scholar:
  • 155 Answers
The normal procedure to reset the phone is to unplug and replug it after some time. also removing the battery from its back and reinserting resets the phone completely. and if that also does not helps then its a technical error in the phone and can be repaired by service center. thanks.
    Genius:
  • 1,447 Answers
Hi-
When you said you can't get it to work, do you mean your not getting any tone? or you can't use some features of the phone? can you receive calls? call your telephone line provider if you can't receive and make calls so that they can perform diagnostics to it.
Hope this helps
  • Panasonic Master
  • 13,433 Answers
Unplug the phone for few minutes and try again, what kind of phone do you have there? Please post more details, use the add a comment button.
Posted on Oct 31, 2008
    Brigadier General:
  • 3,614 Answers
May i know which model of panasonic model do you have. and also the network provider you are using.
an additional more info may help.
thanks
  • micromaster
    micromaster Oct 31, 2008
    try doing this:
    De-register all system handsets by:
    1. Unplug the base power plug.
    2. Press and hold the PAGE key.
    3. Plug the base unit power plug back in and con
    tinue to hold down the PAGE key for 10 seconds.
    4. This will erase all handsets registered to the
    base. The handsets will now prompt you to:
    5. Enter the 15 digit base unit ID code, located on the
    underside of your mi 6820. If you make a mistake,
    press the DELETE key to backspace (delete characters),
    then enter the correct information.
    6. Press SEL to complete the registration process.
    7. Once a valid base ID code has been entered, the
    display will blank for a second or two, and then
    show:
    8. If the base accepts the new handset, after several
    seconds the new handset will show:
    where X is the new handset number assigned,sequentially,
    by the base.
    Follow this few steps, this was intend to register again your handset into your base
  • micromaster
    the procedure above is a common steps to register panasonic phones to its base.. iand also may i know the model type of the base.?
  • 6,487 Answers
Can you please provide us the model number of this unit so we can help you better....
Not able to download from youtube . worked yesterday ?
Try System Restore to restore system to previous state.
This issue can easily be resolved at http://sureconsulting.in/
Sep 07, 2012 | Dell Computers & Internet
Hello i was using my Lg E500 laptop and when i was using the camera on msn messanger the cam was fine ... yesterday and today it cant find any camera !!! pls help : r0kk0ua@hotmail.com
Hi
I would try a system restore as i dont know what os you have i cannot tell you how to get to it
but if you type system restore into the start search for files and folders then it should take you there then restore back to a certain date then choose maybe yesterday or the day before or back as far as when it was ok this may just work for you it will then restart itself when it is done and will say either it has restored back to or it cannot restore back to
If it dosent you could also go to device manager find the webcam uninstall it then restart laptop and hopefully windows will reload it again correctly and you should then be able to use it again
good luck
Nov 15, 2010 | LG X-Note LM50 Notebook
Can't access phonebook
you need to contact Motorola service center
Feb 26, 2010 | Motorola Mobility RAZR V3i Cellular Phone
Testerday we connected to xbox live but today we cant connect why
Are you wireless or are you wired. If you are wireless, sometimes phone signals interrupt the wireless signals if you have a wireless phone nearby. Some wireless phones are very messy with the signals they send.
Jan 01, 2010 | Microsoft Xbox Console
I have a sony ericsson W595, it worked perfectly until yesterday. my phone died, so i put it on charge. It seemed to be working perfectly normal until i slide the phone up. The screen then went black. i...
HI FRIEND...
i think it crashed try formatting the phone or restore into,,,factory restore settings,,,
thatsall thank u
PLEASE RATE IT....
Nov 10, 2009 | Lands Phones
I have nokia n70..till yesterday it was working fine..it got switched coz its battery went off..today when i was chargin tried to switch it on..but the screen is nly white no display,its makind beep...
Power cycle the phone. Here's what you need to do:
1. Remove the battery.
2. Remove the SIM card and the memory card.
3. Give for about 5 minutes and then put everything back.
4. Turn the phone ON.
If the problem still the same, you need to bring it to the Nokia Care Center for possible firmware upgrade.
Have a great day!
May 23, 2009 | Nokia N70 Cellular Phone
ur phone as been hucked and it will be not solove with ur known and u should go the nokia center and ask him to back repair it happen with some virus or some data has delected or try it u should remove the memory and sim card ok rate me please
Puk codes
need a puk code as my phone is locked an i called testra yesterday and they said there systems are down and to call todaY WELL I DID AND THERE NOT EVEN OPENED. i cant wait till monday i need to use my phone now help plz'''
Jul 12, 2008 | Computers & Internet
Fax dial tone
sure...check the line, with a phone..do you have call waiting or something like that enabled..that can cause some issues, with the tone interruption to the internal modem.
Nov 14, 2007 | Lexmark X9350 All-In-One InkJet Printer
Lands Phones Logo
171 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
