Question about Kitchen Ranges
Probe light on - and beeping. How do we turn it off?
I was cooking this evening (had the oven and stovetop on) and out of the blue the probe light on the display panel came on and won't go off. It beeps until I hit the cancel pad and then starts up again 30 seconds later. It is driving us insane.
    Sergeant:
    Champion:
  • 324 Answers
Sounds like you may have a shorted key pad.
Posted on Nov 01, 2008
F10 oven code frequently beeps,often after cooking is over and oven is coolind down at different temperature settings tempermental some times it works sometimes it does not.
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It suppose to be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
Jul 15, 2011 | Frigidaire Ovens
The thermostat light does not stay on during cooking.the cooker does not get hot enough to cook properly.the light goes on and off during cooking.I think it should be constantly on.The cooker is a hotpoint...
Hello there and thank you for choosing fixya.
This is a very common issue with these appliances
Normally the temperature sensing probe is the part that fails and when it does the oven will heat up only some and the probe will indicate that it is at the right temperature thus turning off the light
when in fact the oven is not fully heated up
So i would first inspect the temperature sensing probe/ thermostate and if it looks really old or greasy i would highly suggest replacing it ok normally they are around 45 dollars or so ok?
Keep me posted on how this is going so i can give you any help that you may need
Best regards MIke
Jun 29, 2011 | Ovens
Probe light stays on so I can't cook
Hey i just got knocked out of the session can you please get back in to the session
Nov 26, 2009 | Thermador SEC272BPSS Electric Double Oven
Jenn-Air SCE 30600, oven error codes F1 and Probe
An F-1 error code on your model means the element was energized when it should not have been, A shorted interconnect harness or failed power relay board.
A probe indication could be a failed meat probe jack or bad harness in a unit that has one. In a unit without a meat probe, suspect a bad board.
Both conditions would warrant bringing in a tech.
Before you do, turn off the circuit breaker fot 3 miutes and turn it back on. This will reboot the boards. If problem persists, the call a service tech.
Nov 04, 2009 | Jenn-Air SCE30600 Slide-In Electric...
Superba convection oven probe display problem
I had a similar problem today with my KitchenAid Superba wall convection oven (2002 model). I was roasting tomatoes at 225 degrees F for 3 or 4 hours when the control pad changed and showed that the probe was in use (never have I used it and had to look for it). I, too, tried to plug in the probe and take it out, but nothing changed. My worry was that I could no longer use the timed bake function. After trying to reset by turning off the oven at the breaker, with no change, I turned on the oven to 400 F and left it on for 10 - 15 minutes hoping that the high temperature would dry out whatever moisture that must have gotten in the place where the probe connects. Then I turned it off and just waited. After a half hour or so the control pad cleared and nothing showed (that is what you want when the oven is off!). Everything is back to working now.
Sep 08, 2009 | KitchenAid KEBC107 Electric Single Oven
I get an "F1" code on my Maytag range.
you need a new temperature probe. its usually located in the upper left hand corner in the rear of the oven.
Mar 19, 2009 | Maytag MES5570 Electric Kitchen Range
Kichenaid electric stove
the probe is put into the oven to sense heat and to prevent the oven from oveheating during normal operation. the reason the probe is beeping is because it's dislogged or needs to be replaced.
the only way to make the beeping stop is to disable it but i wouldn't recommend it.
have a technician run a diagnostic on the stove. sounds like the probe needs to be replaced.
Jul 09, 2008 | Jenn-Air JES9860 Electric Kitchen Range
F3 and F5 signals
could be a probe thats that brass looking rod you see when you open the oven f3 is oven probe code it controls the temp some of them you can take the two screws out on the in side and pull the probe out far enough to get to the connector to change some you have to pull the oven
Sep 10, 2007 | GE JKP15 Electric Single Oven
KitchenAid superbra range KGST307
I am not a repair man or anything, just an owner with the same gas range slidein appliance. What we have found to work was 1) plug in the probe into the socket in the oven 2) Turn on oven with the probe set at the minimum 160 degrees. and oven temperature to 325 degrees. 3) click start 4) wait for oven to reach probe temperature. 5) oven will then beep show end 6) Click cancel 7) open door and remove probe. 8) wait five minutes before trying to use again. I hope this helps you it has work for us so far. 6)
Aug 27, 2007 | KitchenAid KGST307 Gas Kitchen Range
Kitchen Ranges Logo
276 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
