Question about Kenmore Refrigerators
Only fan working on my side by side
Last ice had built up on the ice dispensing chute and on the side vent leading refrigerator side last night everything started to defrost cleaned fan and coil from dust. now only fan kicks on. I have a side by side dispensing unit model # 596.50399001
  • 958 Answers
Wait for about 4 hours and plug it again. let the compressor cool down. it could have tripped it's thermal overload.
then observe if the compressor would start. it would vibrate, make a little bit of noise and heats up.
if it is trying to start and can not start, then it could be broke already.
tnx 4 using fixya,
Posted on Oct 31, 2008
Ice aker ks, but does not dispense ice. fgidaire gallery, sde by side
Good Afternoon friend, thanks for your inquiry!
I understand that your icemaker is not dispensing ice in your Frigidaire refrigerator. I would recommend checking the dispenser chute, if there is a blockage of ice within the chute it would not dispense. When you press on the dispenser do you hear a noise? If you do that could be the auger trying to push the ice out, if you do not hear a noise it sounds like it be a potential problem with the dispenser or control panel. I would seek assistance from a technician to come out and properly diagnose your refrigerator. I hope this helps. -Matt
Sep 26, 2014 | Frigidaire Gallery GLHS38EGSB Side by Side...
Underside of ice bin freezes up built up with frosty ice, dispenses no ice. numerous times we have defrosted with blow dryer, removed, cleaned bin, replaced; cleaned out ice that was built up in lower part...
W10224328 Dispenser Door Spring
The chute door is the reason your ice bin is freezing up and also the chute door being open draws warm moist air inside your freezer compartment causing massive amounts of frost and keeps the compressor runing all the time between defrost. You really n eed to get the chute door fixed. What is the correct model number? For the model KSRX25FT dispenser parts click HERE The chute door spring may be broken but you will not know untill you open the dispenser housing. I'm here should you post the correct model number or have questions, Sea Breeze
Oct 17, 2013 | KitchenAid Architect ® Series II KSRX25FT
The ice dispenser no longer operates and in the dark of night the light turns on and the dispenser flapper starts flapping wildly on its own adn making a loud grunting noise. Do we need an exorcist
Check your fan next to the compressor if it's running ,also check your evaporator fan if it's running.
If both fans are running and you still have ice built-up then you may have a refrigerant leak
Dec 21, 2017 | Maytag MZD2766GES Side by Side...
I have a GE side-by-side with ice and water through the door. The ice bin defrosts from time to time causing the ice to re-freeze in a clump once the temperature gets back to normal in the freezer. I...
Have you had a dispenser flapper replaced..if its not sealing (closed) properly it will lead to frost buildup in the location described..
You can check that by looking into ice chute form inside the freezer door and see if any light shines through
Jul 01, 2017 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
I purchased a new whirlpool conquest and have had on for two days. i have water coming out of the water dispenser but still no ice production. There is no water in the chute leading to the ice maker. ...
Maybe it won't call for water until it goes through the cycle. Try putting water in the ice mold and see if it starts working when it freezes and dumps the ice. Make sure the water line is open by swapping the wires on the dual water inlet valve. Then the water dispenser will send water to the ice maker and you'll know the valve and line works.
Sep 01, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice chute cloggs with solid chunk of ice over time
Have you had high humidity over the last few months where you live?
This could be normal under those conditions.
BUT.....make sure the door is closing FULLY at the ice dispenser outlet.
Aug 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
25 ft side by side fridge which does not dispense ice
use a hair blow dryer to warm up the chute and dry up any moisture then lube the chute with a cooking spray, pam is a good one.
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water leaks from ice dispenser
ice may be built up in chute. ice door in chute is not opening you may have to manually open inside chute.
Jun 22, 2008 | Kenmore 53092 / 53094 Side by Side...
Refrigerators Logo
57 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
