I am trying to install Print Artist Version 22. When I put the installation DVD in I get the following message "Error 131L source file not found: E:\print artist platinum data1.cab. verify that the file exists and that you can access" Can you help me?
I am having the same problem
Posted on Sep 19, 2010
My Print artist has stopped working. The Cd rom in my PC is broken so I can't reinstall. What can I do
Print Artist Platinum 24 has stopped working - Fixya
www.fixya.com/.../t13886156-print_artist_platinum_24_stopped_worki...
Aug 4, 2012 - either right click on the setup program and select run as administrator or log in using an administrator account on your PC to install.
Amazon.com: Customer Reviews: Print Artist Platinum 25
www.amazon.com/Nova...US.../B00EPACO3M
Amazon.com, Inc.Find helpful customer reviews and review ratings for Print Artist Platinum 25 at ... Installed this piece of garbage a week ago to start working on a project for a major .... Software performs quite well once the learning stage has been passed.
Support : Nova Development Technical Support
support.novadevelopment.com/
I have a version of Print Artist that came out before version 21. ... When working in the program, it freezes and shows a message "Not Responding" message at the top of ... When exporting a project as a SketchUp file, it has unwanted triangles.
Print Artist Gold 25
Jan 19, 2016 | Nova Development Print Artist Gold 24 no...
Error 1935 while trying to install Print Artist 25
Unlimiting the registry size could work:
Here are the steps:
1) Type REGEDIT in run
2) Navigate accurately to:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control
3) On the right pane, locate the following
Key: RegistrySizeLimit [Type: REG_DWORD]
4) Double-click on it.
5) On the dialog box, select DECIMAL radio-button
6) Erase the previous and enter the following number:
4294967295
7) Again select, HEXADECIMAL radio-button
8) Click okay and restart computer
9) Everything will be okay, ENJOY! try to install the package again.
gnaveendra@gmail.com
Feb 11, 2014 | Nova Development Print Artist Platinum...
Print artist platinum 22 does not want to install on our new computer with windows 7, is there a patch or some drivers that need to be installed?
Try launching the program in compatibility mode. If this is a disc you're trying to install from, click on Start, goto Computer, go into your DVD Drive, right-click the Setup's EXE file, then Troubleshoot Compatibility.
If this is just a Setup EXE file you are trying to load on your computer you can do the same. Just right-click and select Troubleshoot Compatibility.
When you're presented with a list of options, select "This program worked in an earlier version of Windows", then hit Next. Just follow the prompts and then try installing it again.
Feb 23, 2011 | Nova Development Print Artist Version 22...
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
Error while installing/ error 1305/reading from file c:\Program Files (x86)\Nova Development\Print Artist Platinum\Layouts\Postcards \GeGeneral Greetings\990Ball & Chain (8386).ppc.lyt. Verify that the...
error's like this are very common and most of the time are caused by microsoft windows updates,go to the site and check first for any updates that need upgrading that don't automaticly update and see what results come up? then you can try and do your install,good luck,garnedd.
Sep 12, 2009 | Nova Development Print Artist Version 22...
When attempting to install Print Artist Version 22/ Platinum Edition, I received the following message: Error 2350. FDI Server Error I tried re-installing and received the same message.
If you are using Windows XP install
windows installer 3.1
http://www.microsoft.com/downloads/details.aspx?FamilyID=889482fc-5f56-4a38-b838-de776fd4138c&DisplayLang=en
XML Services 6.0
http://www.microsoft.com/downloads/details.aspx?familyid=993c0bcf-3bcf-4009-be21-27e85e1857b1&displaylang=en
and .NET framework 3.5
http://www.microsoft.com/downloads/details.aspx?FamilyID=333325fd-ae52-4e35-b531-508d977d32a6&DisplayLang=en
Jul 11, 2008 | Computers & Internet
Boot Up error message
I have the same problem. I emailed Nova support and the first reply had a link to Dotnetfx3.0. He said install that and it would fix the problem. I'm running Vista and I discovered after trying to install this version of Dotnet framework, that 3.0 is already integrated into Vista. They should have known that because I told them what platform I was using in my original support request. The next suggestion was to install dotnetfx3.5 which I did along with it's service pack to no avail!! I really don't think their support staff is too computer savy! Their last response when I told them that didn't work either was pretty much "sorry". Anyway, I haven't given up and am concentrating on the dotnet connection. I'll post here if I happen upon a solution.
Jun 15, 2008 | Nova Development Print Artist Version 22...
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
