Question about Panasonic WORKiO DP-1520P All-In-One Laser Printer
Dp1820 I switched internet to wireless &my printer was not networking. So I ogt USB cable & got it to network. Now the scanner wont work....help!!
    Sergeant:
  • 284 Answers
Im sorry to be the one to tell you but the scanner is network only . you can try network again if you want and go here www.workio.com to get the latest drivers and progs
Posted on Nov 03, 2008
How can i setup HP Officejet 6830 to print with USB and wireless?
There is a solution for install the hp office jet pro 6380 with USB cable connection and wireless connection on your PC.
Follow the below steps:
Configure device:
• In your printer to select Network setup.
• Then select wireless settings.
• Check the wireless is on.
• Next to choose your network name as SID.
• Now you have to enter the wireless password.
Install wireless device:
• First, download the latest Mac OS X 10.10 driver for your printer.
• Run network install.
• Now you have to test wireless printing to confirm that functioning.
Install USB device:
• First, plug USB cable on your printer to the PC.
• Click the apple menu to select the system preferences.
• Select the print & scan option to check your printer name.
• Now click plus sign to select the add printer or scanner.
• Ensure that hp Officejet driver is selected.
If you still have any doubt or issues you can also contact our customer support to help you regarding your HP printer issue @ +1-800-836-3987 or visit 123.hp.com 6830 oj.
Jul 21, 2017 | HP Office Equipment & Supplies
Why doesn't wireless scanning work if initiated from the PC or from the MF212w printer?
hi . I'm almost sure that the toolbox only work on USB. for network scanning there is another aplication I thin is color network scan gear
Mar 14, 2016 | Canon imageCLASS MF212w Network-Ready...
Where can I get a network set up cable for canon mx 410 printer?
The network is wireless. The only cable that connects other than power is the USB cable for direct connection to a computer. That is the network setup cable. Any Type A to Type B USB cable can be used for the setup.
Aug 23, 2014 | Canon Black Pixma Mx 410 Scanner
Check connections
The connection of the USB cable
Verify that the USB cable is connected between your Brother machine and your PC.
The connection of the LAN cable (if applicable)
Verify that the network cable is connected between your Brother machine and access point and the machine is powered on.
1.Access point/router
2.Wired Network machine (your machine)
3.Wireless capable computer connected to the access point/router
4.Wired computer connected to the access point/router
The connection of the Wireless network
2.Wireless Network machine (your machine)
Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother MFC 7840W Printer
Canon MX892 - when I scan, an error code 2156 comes up saying scanner is turned off or usb cable unplugged
Hi.
Try to check up first scanner power cable and network wireless router.
If it are running running good. your scanner have defective parts. like
IC chipset.
Second option : try to general cleaning your Canon PIXMA MX892 Network-Ready Wireless All-In-One Printer. using vacuum.
Hope can help you.
Sep 15, 2012 | Canon PIXMA MX892 Network-Ready Wireless...
I have a new HP laptop and want to install my printer. I have a pixma MP150 All in one. Will it work on a wireless laptop?
The printer does not have a wireless network feature. If you connect it to a wireless print server, you will need to check if the print server is compatible with your laptop's OS. (If you have Win7 on all computers, the homegroup should let you share the printer via your network.) If you use one of the network options, the scanner may only work with a direct USB connection.
It will work with any supported OS with a USB connection. Drivers are available here: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp150#DriversAndSoftware . Install the software before attaching the data cable. If you forget, the scanner features may not work (a generic driver gets installed). If you do install the generic driver, uninstall it and then unplug the data cable before rebooting and installing the Canon driver.
I hope this helps.
Oct 18, 2010 | Canon PIXMA MP150 All-In-One InkJet...
HOW DO I USE A WIRELESS PRINTER WITH NO ROUTER. I WANT TO PRINT FROM TWO COMPUTERS, THAT BOTH USE DIAL UP INTERNET
You can attach the printer directly through USB cable to your computer and print, or you can connect the printer and your computer to the same wireless network and then print using the wireless and your connection.
Internet is not necessary, only a communication path needs to be established. For this whether its your neighbor's wifi network, your own wifi network, a usb cable connection between your pc and printer etc printing will be accomplished.
Dec 30, 2009 | Brother MFC 240C All-In-One InkJet Printer
Printer is not working
The Pixma MP210 does not support a wireless connection. It has a USB port. Some wireless routers do have USB ports and can thus share the printer. Similarly, there are print server options that can be connected to the USB port. However, these will not work with the scanner functions of the all-in-one. Also you would need to confirm that the print server you choose is compatible with the Pixma MP210.
The fastest way to print right now is to connect the USB cord to the laptop. Wait for the drivers to be installed and then send the file to the printer. Moving the cable will let both computers use the scanner features of the all-in-one. A manual USB A/B switch might allow you to share the printer with fewer chances for a damaged USB cable. However, these usually don't support the scanner. Scanning requires bi-directional communication between the printer and the computer. A bad USB cable can turn an all-in-one into a single function printer with a direct USB connection.
Once the MP210 driver is on both systems and they are connected to the same network, you may be able to set up the desktop as a print server for the laptop. This will depend on the OS on both systems. Something like the Windows Homegroup easily allows printer sharing when enabled for systems with Windows 7 and newer on a private network. Both systems need to join the same homegroup. One system starts the homegroup. Then you have to type in the password on the second computer. This works even with one system connected to the wireless network and the other connected to a wired port on the router.
On Vista and XP, you could enable printer sharing as well in the Network and Sharing center. See https://www.wikihow.com/Share-a-Printer for the steps With Windows OS versions, the scanner functions will only be available on the computer with the direct USB connection.
I hope this helps. Please add a comment with the OS versions on both the desktop and the laptop if you need more specific advice.
Dec 22, 2017 | Canon PIXMA MP210 InkJet Printer
Photosmart C4380
delete the old installation and reinstall the printer again and do the reconfiguration for either USB or wireless. It worked for me when I did this. The scanner begins to work and no more 'no USB or wireless connection' msg anymore. :~)
Jul 02, 2008 | Office Equipment & Supplies
Scanning from wireless laptop
First of all, just use a USB cable, there not that expensive and it will be alot easier.
If you must use wireless. The laptop is trying to connect directly to the scanner or is there a print server somewhere, is there internet being used, is it connecting to another access point or wireless router?
Thes questions need clerifying.
Again. Wirless is supposed to be easy but we all know it isnt always true.
I would either Hardwire into the network or printer or connect direct to the scanner VIA USB.
May 31, 2008 | HP Photosmart 3310 Printer
Panasonic WORKiO DP-1520P All-In-One Laser Printer Logo
141 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
