Question about GE WSXH208A Front Load Washer
GE washer spins slowly -Clothes still wet
Our washer stopped workinf a month back. We found a bad belt replaced that, and then the spin cycle is now slow. The motor comes on for theww seconds ten off for three seconds. It does this for the whole spin cycle. I have had the belt on and off and it functions the same. The washer functions normally other than that. Any suggestions? Al Gray
  • Alan Gray Sep 22, 2006
    Hey Guys I found the problem!!!
    A Rat chewed through the yellow wire. I was looking a little closer and found the yellow wire chewed through. It was on the bottom of the bundle and I could not see it before. After splicing the wire, the motor ran for three seconds in one direction then stopped for three seconds then reversed directions and sped up and completed the spin cycle.
    Thanks for your input.
    Al Gray
If you disconnect your motor pump coulping and your motor runs ok you have something in your pump,usually you can see this because the coulping is twisted, good luck
Posted on Sep 20, 2006
  • 22 Answers
Doesnt make any sense why the motor goes off and on. If I read your email correctly. some typos on your email. but, sounds like the belt is too big. Or the spring device that keeps the belt tight is not working properly. You need to make sure what ever it is that keeps that belt tight is working properly or not damaged. The belt is very important to making the spin work good. Match it up with your old belt. The old belt will be slightly longer because of being stretched over a period of time. Get your unit number and model number and go to your nearest dealer and get the correct belt.
Posted on Sep 18, 2006
How to fix my Ge washer THAT SPINS SLOWLY AND DOES NOT DRAIN CLOTHES COMPLETELY.The clothes are still wet at the end of the cycle.
Wild guess, It's Out of balance, as a result, it's smart enough to stop spinning. To check, try to rebalance. Maybe overloaded. Remove clothes but fill with water and see if it will spin out. Second guess, belt drive on the bottom of the machine is worn, or belt tensioner is off or bad bearing. Also, possible the motor has a problem and shuts down because it's overheating a bit. If this is the case, though unlikely you will need a service man, but not cheap. If it's an old machine you might consider a replacement.
Dec 21, 2014 | GE Washing Machines
My machine is spinning, but clothes are still very wet, have to drain and spin at least twice to get them dry enough to put in the dryer
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Feb 08, 2011 | GE Washing Machines
My washer spins out very slowly and the water drains but the clothes are very wet.
f the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing.
Nov 30, 2010 | Westinghouse WWS833ES Super Capacity Top...
Towels come out soaking wet, too wet to put in dryer. When placed back in dryer, noticed the spin cyle runs slowly, never spinning fast. The drum itself isn't solid, but oscillates when spinning.
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 01, 2010 | GE WSXH208A Front Load Washer
Washer does not spin out the clothes to dry
Hi There
I found this for to read to help you on your problem hope this helps.Let me know how it goes.
Thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Washing Machines
The spin cycle spins very slowly and the clothes come out extremely wet (drippping wet). How do I troubleshoot this problem?
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Jul 14, 2009 | GE Energy Star WCVH6260F Front Load Washer
Only spins slow
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
May 06, 2009 | Washing Machines
Won't spin out clothes after replacing belt
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
May 03, 2009 | Crosley Washing Machines
Kenmore front load washer will not spin. Clothes come out wet.
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Mar 02, 2009 | Kenmore 43142 Front Load Washer
GE WSXH208A Front Load Washer Logo
986 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
