Question about Intel Socket 478 CPU COLLING FAN & HEAT SINK up to 3.2GHz
How to change
Socket 478 cpu heatsink fan
    Scholar:
  • 96 Answers
Hi
Replacing the heatsink fan on a PC is not a difficult job, but it pays to be thorough, especially with cleaning the top of the CPU die before replacing the fan.
Don't be mean with money when choosing a new cooler either. With CPU coolers you get what you pay for. I personally always use coolers from a company called Zalman.
Ok ..with that out of the way ..the basics are ...remove old cooler..
They are either held on by a sprung clip that fits across the cooler and locates in lugs on the cpu socket surround, or they are held by screws that go through the motherboard.
Clean the top face of the cpu die carefully making sure to use a blunt implement ..... scratches on the machined face will lead to premature failure due to overheating.
If the cooler you buy has a "thermal pad" stuck to the face of the heatsink, then remove this too and clean up the heatsink face. Use good quality thermal paste on the top face of the CPU die, then fit the new cooler. Getting the right amount of thermal paste is a bit of an art .... too much is a bad as too little. The paste is NOT a glue. The paste simply fills in any imperfections on the machined surfaces of the cpu die and the heatsink to aid heat transfer.
Does this sound complicated? It isn't really. The key is not to rush it and make sure the surfaces are completley clean and the thermal paste applied correctly.
Here is a link to one tutorial on fitting cpu coolers that you might find useful:
http://www.jsyte.com/tutorials/replacehsf
Posted on Dec 31, 2008
Replacing the heatsink,will it stop it from shuting down? if i use desk top fan blowing onto the inside its ok and works. i also have had blue screen come on
YES! The dissipation of heat is crucial. Thus making a heat sink / fan indispensable. That is most certainly the cause of the blue screen.
Furthermore, expect the system to fry in the near future without a working fan.
Oct 16, 2012 | Packard Bell Cpu Cooling Fan Heatsink...
Is ABIT SG-71 a Pentium 4 motherboard and what are the specs, the does and donts
The ABIT SG-71 is an Intel Socket 478 that could take a Pentium 4 or Celeron CPU (533/400MHz) designed for the 478 socket. It could support up to 2 GB of DDR 333 memory.
This motherboard may not be worth putting in a new CPU; it is over 10 year old technology. It's very old and slow compared to even two year old CPU and motherboard options.
(if you do want to replace the CPU, remove the old hardware. Use extreme care not to bend any pins on the CPU. Add new thermal paste to the top of the CPU and then put on the heatsink. Connect the CPU fan to the CPU fan header.)
May 05, 2012 | ASUS Computers & Internet
Right i need the size or model for the cooling fan that all intelboard mode E210882
The Heatsink/Fan combo is based on the processor socket used.
After a few search hits, I have seen E210882 on Intel based motherboards, that use two different processor sockets.
The Socket 478, and the LGA 775 processor socket.
The socket for the Socket 478 has the pin holes. The Processor has the pins. (478 of them)
http://en.wikipedia.org/wiki/Socket_478
The socket for the LGA 775 processor socket has the pins. The Processor has the pin holes. (775 of them)
http://en.wikipedia.org/wiki/LGA_775
Identify which processor socket you have, buy accordingly as to the Heatsink/Fan combo.
One example of a Heatsink/Fan combo for an Socket 478 processor socket,
(Only Intel uses the Socket 478 for their Processors),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=578161&CatId=795
One example of a Heatsink/Fan combo for an LGA 775 processor socket,
(Only Intel uses the LGA 775 socket for their Processors),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3302824&CatId=1588
Remember to observe Anti-Static Precautions, Thoroughly clean the top of the Processor's case, and aplly fresh new thermal paste.
(A Processor is the most susceptible hardware component to Static shock)
[ Example of thermal paste,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3071621&CatId=503 ]
If you would like advice on how to properly clean the processor's case, properly apply thermal paste, and/or what Anti-Static Precautions are, post in a Comment.
Nov 07, 2010 | Intel Motherboard
I have ASrock P4vm800,Prescott800,Pentium 4 Pro.But i need a help.When it is powered up nothing happenes except the system unit ligth up,& chassis font panel ligth is blinking Continously.Cpu fan...
There is a verity of things you can check & or replace. You mentioned the CPU fan is not turning. This is very very important.
This suggests possible CPU fan is defective. Average life span for a CPU fan is 5 years or 50,000 hours. Your MB uses Intel PGA socket 478. For a replacement heatsink & fan assembly open the link provided;
http://www.amazon.com/Thermaltake-A4012-Cooler-Intel-Socket/dp/B000FEW8JW/ref=dp_cp_ob_e_title_0
A new heatsink assembly will come with a new fan attached to the heatsink.
It should also come with new thermal past or thermal tape attached to the bottom of the heatsink assembly.
As to the front panel LED light blinking continuously.
If the LED light is red in color this means your primary hard disk drive is trying to load windows.
My suggestion is for you to replace the CPU heatsink assembly first.
No need to remove the CPU from its socket at this time.
If you never replaced the Heatsink & fan assembly watch the video included below;
http://www.youtube.com/watch?v=4OB1hxxKdec
Once completed your system should function correctly.
If it doesn't, post you’re finding here & I'll help you further.
Cheers'
Mike
Aug 10, 2010 | Computers & Internet
Socket 478 3 GHz Intel CPU overheating
Simply open/unlock the clips and pull the heatsink off. Then you will need to remove the termal compound from both on top of the CPU and from the bottom of the heatsink. Papertowel + rubbing alcohol works well. Then you will need to re-apply thermal compound before reseating the heatsink/fan.
Jun 14, 2009 | Intel Socket 478 CPU COLLING FAN & HEAT...
I need a cpu fan what size does it take
It goes by which socket you have. I am an Intel connoisseur so my knowledge ends with Intel PCs.
If your processor is an early Intel Pentium 4, you will want a socket 478 CPU cooler.
If your processor is a late Intel Pentium 4 or Intel Core 2 Duo/Quad (~2ghz+) you will want a socket 775 CPU cooler. Luckily this socket is still in wide use and many can be found locally or online.
If your processor is an Intel Core i7, you will want a socket 1366 cooler.
Just go to a local PC store and ask for an LGA478, LGA775, or LGA1366 CPU heatsink.
Apr 11, 2009 | Gateway GP PC Desktop
Fan and heatsink
Just ask for the fan & heatsink for the 478 socket. Its easily available in the market../
Nov 16, 2008 | Intel D845GRG Motherboard
Upgrade CPU In my SAMBA SM-1845
Hi, as long as both chips are slot 478 it should work fine, you wont need to change any bios or jumpers, just open up the computer, remove the heatsink, lift the lever and remove the CPU.
Insert new processor.
you will need thermal grease at this point, you need to apply a little amount onto the cpu, and make sure the old thermal paste is removed from the heatsink and then refit the heatsink & fan.
other option is fit the new cpu and purchase a new heatsink & fan, they usually come with the thermal grease, a new heatsink will cost about £10 or themal grease by itself will cost about 2-3 pounds.
just make sure you have new thermal paste before you remove the heatsink as the processor will get damaged otherwise..
Hope this helps
John
Jul 31, 2008 | FIC Samba SM-1845 (SM1845GV) Barebone
The cpu heatsink clip has come apart, would like to know how to fix. the model is hp pavilion 734.uk
http://cgi.ebay.com/Intel-Socket-478-HEATSINK-RETENTION-BRACKET-Module-ONLY_W0QQitemZ170211538308QQihZ007QQcategoryZ14293QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
That's what usually breaks if you have a 478 pin cpu. Should be available in any computer shop. If the actual metal bracket on the heatsink broke you will have to buy a new fan/heatsink. Both solutions are cheap.
Apr 24, 2008 | Computers & Internet
Heatsink Removal
This is an easy one. :)
I am assuming that you're asking about removing your typical P4 HSF.
Direct from Intel's very own website! :)
http://support.intel.com/support/processors/pentium4/sb/CS-007989.htm#Removal
Good luck and please be careful. *nods*
Cyryl
Nov 04, 2007 | Intel Pentium 4 Socket 478-Pin Cooling Fan...
Computers & Internet Logo
391 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
