Question about Canon Office Equipment & Supplies
The Waste ink absorber is full. Contact the service center for replacement of the waste ink absorber "I don't know where the ink ab sorber is located. Please help me!" I need my printer.
  • 3 more comments
  • schrimper Oct 31, 2008
    I can't find the solution you sent me. Schrimper
    The item is a Canon Pixma ip 1500 Series printer. I hope this helps you.
    My Canon Pixma ip 1500, Serial#FCNO7174 printers Waste ink absorber is full And I don't know where it is located and how to replace it. My printer does not work at all. Please help me. Schrimper
    This is a Canon Pixma ip 1500 series printer. Serial#FCN07174, also another #K10240, does this help.
  • schrimper Nov 01, 2008
    I'm sorry but I can't seem to fi9gure this out. Please cancel my charge for this.Thank you. Schrimper
  • 52 Answers
Hi!
try this trick if it works on your printer:
1st: press the switch button (dont remove your finger) and pull out the power cord of the printer
2nd: put back the power cord of the printer; then you can see the green light blink and remove your finger on the power button
3rd: you may switch the printer on.
i hope this trick works on your iP1500, though it didn't clean you waster absorber but it will make your printer work again.
Posted on Nov 01, 2008
    President:
  • 2,712 Answers
You get this message when the waste ink absorber is filled with ink. You need to clean this out.
1. To remove the pads:
Open the cover and power on he printer. The print head will now move to the left side. Once they reach the left side, disconnect the power. You should now be able to reach the pads, and can gently lift them out with a pair of tweezers.
2. Cleaning the pads:
Place the pads under running water and squeeze out the ink. Once dry, let it dry out completely before replacing them in the printer.
3. Resetting the waste ink counter:
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
Everything should be back to normal :)
    Guru:
  • 859 Answers
This is easy to resolve you may vist my tips I've posted on cleaning ink pads and resetting your printer if you are receiving error code U163.
All my tips on this can be found here, where many people have had good results.
Regards,
Worldvet
Posted on Oct 31, 2008
  • Canon Master
  • 19,396 Answers
DO THE FOLLOWING:
STEP 1:
- Disconnect printer from AC power
STEP 2:
- Press and HOLD the POWER button, and
connect printer to AC power
If that does not work you will need to clean the absorber.
To clean the absorber start the printer with the cover open until the head moves to the left side, then disconnect power cable so that the heads move away from the pads.
Lift up the two pads and rinse them under the tap, until they get white again. Then dry them before putting them back in the tank.
  • Canon Master
  • 6,487 Answers
You can follow the steps from this link on how to resolve this problem, hope it help you http://www.fixyourownprinter.com/forums/inkjet/41348
    Sergeant:
    Champion:
  • 347 Answers
Hello schrimper,
If you could tells us the model and brand of your printer, i could guide you step by step on how to solve yoru problem
good luck,
Dahaka
  • Santiago Vallejo
    Santiago Vallejo Nov 01, 2008
    Hello schrimper ,
    Please click Here and follow this instructions, you will then be ale to reset your printer to normal plus you will have the ink tank empty (that way, if in the future the error happends again you will have a fresh empty tank to absorb the ink, and not a desk to absorb the ink)
    Good luck,
    Dahaka
    Scholar:
  • 155 Answers
It is located at the base of the printer.in the form of sponges and they needs to be replaced.there is also a reset method to make it proper. please give me your printer model number and company name. thanks.
  • 4 more comments
  • fixexpert Oct 31, 2008
    the sponge which collects the extra ink from the cartridges gets full and then there is no capacity to absorb the extra ink it shows waste ink absorber full.
    and the printer needs to be opened and the sponges needs to be changed.
    thanks.
    rate the solution if it helps you.
    feel free for further queries.
    thanks.
    STEP 1:
    STEP 2:
    Cleaning the absorber was also easy. Power up with the cover open until the head moves to the left side then disconnect the power cord so the head is now positioned away from the pads.
    The two pads can be lifted up easily with a pair of sharp tweezers then rinsed in running water. They will become white again and can be blotted with paper napkins then air dried in a warm location ( use an industrial oven set to 40°C). The wells in the rubber holder can be cleaned with cotton swabs before returning the two pads (left side first, then press down the right side).
    A waste ink absorber is a pad that soaks up waste ink.
    An absorber can only hold a certain amount of ink, too much ink leads to spillage and it shows waste ink absorber full.
    also try this two methods this sometimes resets the printer and the waste ink absorber message get cleared up and printer starts working again.
    try this both methods 1 by 1 one of them should also help you.
    Step 1: Manual for Service mode (1st method)
    1. Unplug POWER and USB cables.
    2. Open door, PRESS and HOLD the POWER button.
    3. Connect the POWER cable.
    4. Close door, then release POWER button.
    5. Power ON your printer a usual (It should not blinking anymore)
    Step 1: Manual for Service mode (2nd method)
    2. PRESS and HOLD the POWER button,
    3. Release the the POWER button
    4. Power ON your printer a usual (It should not blinking anymore)
    mostly this should work .just try this 3-4 times.
    turn off the mains power, then hold the power button down and turn the mains on again. Then simply press the power again .
    feel free for further assistance.
    thanks.
What is e 27 and e 8??
Those two are error codes, and they mean the following:
E8 - The waste ink absorber is almost full. Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and machine maintenance.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations, etc.
E27 - Manual does not specify what this means, but tells you what you should do: Turn the machine off, and remove the power plug from the outlet. About ten minutes later, plug it in again, and turn the machine on. If the problem is not resolved, the machine may require servicing. Please contact your local Service Center.
You can read more about the error codes on Canon website.
Dec 02, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Computer says"Waste ink absorber is
What is the make and model of your printer (I'm guessing it is a Canon?)
May 06, 2008 | Office Equipment & Supplies
"ink absorber is almost full, contact service center" - what does this mean?
Inkjet printer has waste ink absorber inside, sponge alike. The function of waste ink absorber is to localize and keep waste ink safe inside the printer and does not harm the electrical parts.
Waste ink is produced from print head cleaning process and borderless printing. When capacity of the ink absorber raise to about 90% then warning message appears.
You need to bring your printer to the nearest service center to get waste ink absorber replaced.
Source:
Printer Clinic: Printer Tips,tricks,troubleshooting
E-manualshop: Online source of service manual
Aug 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Printer won't print. Says to contact service
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 10, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Triangle and ON/OFF switch both flashing. Window reads 'CHECK PRINTER'. What exactly do I check? Window had been reading 'WASTE INK NEARLY FULL' for a fortnight, but I couldn't find out how to deal with...
The waste ink absorber is getting full.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations, etc. http://support-nz.canon.co.nz/contents/NZ/EN/8000137103.html
Nov 09, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Printer light is blinking in orange & green
bassically your printer has come to the end of its life, you can either buy a new printer or contact the service center...
Jul 13, 2009 | Canon MultiPASS F60 All-In-One InkJet...
Its appear " The ink absorber is full. Contact the service center."
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
May 11, 2009 | Office Equipment & Supplies
The waste ink absorber is full.
You have to contact the Canon agent to get the waste absorber replaced. or you can continue it with pressing resume everytime.
Apr 23, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Printer says ''waste Ink absorber is full'' see service center
This is what the manual says: Ink used for cleaning is absorbed in a waste ink absorber placed in the machine. Press [OK] to cancel the error so that you can continue printing. Once the waste ink absorber becomes completely full, printing cannot be done until the waste ink absorber is replaced.
Canon recommends to contact a Canon service representative as soon as possible.
Nov 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
115 people viewed this question
old marine
old marine
