Question about Microsoft Windows 98 for PC
Missing Control Panel+Run Command+Active Desktop
Problems occurred after replacing a dead HP monitor with Compaq. Restoring registry helped reinstate items, but were deleted again after ad/spyware removal program. Registry restoring attempts were tried again but failed. Now, I'm unable to locate previous dated registry cab to restore to previous operable level.
Please help. Any info will be greatly appreciated.
Does your computer have a systems restore option . If so try to set it to a date before these problems occured and it should fix itself....Click on start, then accessories, then system tools, then system restore. Pick a date before the problems started an restore to that point. Should do the trick.....
Posted on Oct 31, 2008
    Novelist:
  • 208 Answers
HI! QUESTION. HAVE YOU, OR CAN YOU RE-INSTALL WIN98 FROM CD? IT SOUNDS LIKE THE BEST SOLUTION MIGHT BE TO DO A RE-INSTALL OF THE ENTIRE WIN98 FROM THE CD. IT SOUNDS LIKE THE FILES MISSING MIGHT HAVE BEEN PERMANENTLY DELETED AND IF YOU CAN LOCATE THEM ON YOUR COMPUTER, YOU MAY HAVE TO RE-INSTALL THE 98 OS TO GET BACK RUNNING. ONE THOUGHT, THIS MIGHT BE AN EXCELLENT TIME TO UPGRADE TO WIN XP,SP2 WHICH IS AN EXCELLENT PROGRAM AND HAS BETTER RESTORE FEATURES. I PERSONALLY USE XP,SP2 ON MY ONE DESKTOP MACHINE AND IT RUNS MY WIRELESS NETWORK AND HAS BEEN VERY STABLE. I REALLY HOPE THIS HELPS YOU. IF YOU HAVE MORE QUESTIONS, PLEASE REPLY. I'LL HELP.
Why cd rom is not showing
Where is it not showing? Under 'Computer' where you see your hard drive and other partitions? Or have you checked the device manager, and it's not showing there?
This looks like an issue that's being caused due to a modification or corruption of a few registry keys.
You can try the following to see if it works:
Note: This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs.
    1.Press 'Windows key + R', type in 'regedit' (without quotes) in the run box and hit enter.
    2.Locate and click the following registry key:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
    3.If you see UpperFilters in the pane on the right side, right-click UpperFilters, and then click Delete.
    4.Click Yes to confirm the removal of the UpperFilters registry entry.
    5.If you see LowerFilters in the pane on the right side, right-click UpperFilters, and then click Delete.
    6.Click Yes to confirm the removal of the LowerFilters registry entry.
    7.Exit Registry editor and restart your system.
    GuruAid
May 11, 2014 | HP Compaq Presario PC Desktop
Five beep in Hp compaq 530
1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occur while restoring, flashing or updating the BIOS : Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful
Apr 21, 2011 | HP Compaq Business d530 Ultra-Slim PC...
The problem with sound (cod 10 error). compaq nx7010
A Code 10 error usually occurs due to:
  • Missing device driver
  • Malfunctioning device driver
  • Incomplete device driver files
If the device due to which the error has occurred contains the value FailReasonString in its hardware key, then this string is displayed as an error message. Otherwise, the device displays the following error message:
This device is either not present, not working properly, or does not have all the drivers installed. (Code 10)
Most of the time, you can resolve this error by updating the device driver for the faulty device. To update the driver, select the System option from the Control Panel. In the System Properties dialog box, select the Hardware tab, and then select the Device Manager button. Scroll through the Device Manager window and identify the faulty hardware device. Right-click on this device and then select the Update Driver command. Next, follow the screen instructions to update the driver of the selected device.
Causes of System Errors
System Errors Usually Occur due to:
  • Device driver conflicts
  • Corrupt or damaged software files
  • Malfunctioning hardware
  • Corrupt or damaged system registry
  • Virus or spyware infection
Steps to Prevent System Errors
With a little vigilance and extra precaution you can easily prevent most system errors. Some of the tasks that you can perform to prevent system errors are listed below:
  • Keep your operating system, device drivers, and software applications updated with the latest hot fixes, security releases, and updates.
  • Run regular antivirus and anti spyware scans to keep your PC free from harmful and disastrous malware. Always keep these software updated with the latest security releases so that your system is always protected against malware infections.
  • Avoid opening attachments of unsolicited emails and visiting dubious websites.
  • Do not download freeware and shareware from websites whose authenticity you aren't sure of.
  • Be very careful while downloading ActiveX controls from various websites. ActiveX controls provide their master with complete control over your system and therefore, a malicious ActiveX control can cause severe damage to your system and may also enable a hacker to steal your personal information.
  • Last but not least, perform regular registry maintenance to ensure that your registry is free from errors. 90% of all system errors are connected to the system registry in one way or another. You can easily perform registry maintenance with the help of a registry cleaner such as RegGenie. This software will provide you with a simple-to-use graphical interface and enable you to scan and clean registry errors in just a few mouse clicks.
System errors are common on Windows systems and can occur due to a number of reasons, including problems with device drivers, hardware, software applications, and the system registry. Code 10 is one such system error that occurs due to problems with a device driver. You can fix this error by updating the faulty device driver. Preventive maintenance with the help of antivirus software, registry cleaners, and a certain amount of vigilance while working on the Internet can help you keep your PC free from system errors.
Additional Recommendations...
Driver Update: Many errors are related to driver problems such as obsolete, outdated or incompatible drivers. A driver update tool is recommended to scan your system for corrupted and outdated drivers and to ensure that all your drivers stay up-to-date.
Jan 15, 2011 | HP Compaq JBL Pro (401508-001) Computer...
Heyy,, err how do i get the sound back on my laptop if when i go in control panel the sound,audio and game control options are not there Hope you can help thanks
Insert operating system disk in drive.
Click Start. Click Run. Type
cmd
Hit Enter.
type in command prompt
sfc /scannow
Hit Enter
System file checker will replace the missing files. also run registry cleaner reginout it will work for you
Sep 25, 2010 | HP Pavilion dv6000z Notebook
Installation error --- Error Code 2203 Please help, thanks
It's long but this should get your problem resolved and I would appreciate a Four thumbs up if it helps you ,If u have connected your printer only through the USB then leave out the last step.
Fatal Error 2203 - Windows XP
Windows Vista.
Giving permissions to C:\Program files folder may sometimes be difficult but here is the resolution.
Perform L3 uninstallation.
Delete digital imaging folder from C:\program files\hp folder.
Delete digital imaging folder from registry.
Deleting registry key below:
Registry Path - HKEY_LOCAL_MACHINE\SOFTWARE\Hewlett-Packard\Digital Imaging
On completing the above steps
Note: * Do not Restart the computer.
Click Start and type Run command in start search bar.
Right click command prompt and Run as Administrator
Type the following command
Net user administrator /active:yes
The above command will enable hidden account in Vista Operating system. Once enabled,
Once Restarted, "New user account will show up on logon screen called "Admin" and no password required."
Once logged in to Admin account
Reinstall the software.
After successful software installation, Please use the below command to disable hidden account feature
Net user administrator /active:no
1.uninstall the complete HP software, run windows clean up utility
2.under msconfig, disable MSconfig's sevices(non microsoft)
Aug 19, 2010 | Office Equipment & Supplies
Missing CD DVD driver
The issue could be due to missing or corrupt CD/DVD drive drivers. If you are using Windows XP OS, then go ahead and peform the following steps:
=== Backing Up Registry and Registry Key ===
CAUTION: The registry contains critical information and a
registry backup is essential. An incorrect registry
entry may cause serious system problems or prevent the
computer from starting. You will not be warned of any
incorrect registry entries. If the registry is not
backed up, the only way to recover the system is to
reinstall the operating system. Do not double-click the
Backup.reg file on the desktop unless you intend to undo
the changes you are making to the registry.
1. Click Start and select Run.
2. Type Regedit in the Open field and click OK.
3. Click "File" in the menu.
4. Click "Export" from the drop-down menu.
5. Click the down arrow beside "Save In" and select Local Disk(C:).
6. Type Backup.reg in the File Name field.
7. Click Save.
=== Deleting UpperFilter and LowerFilter Registry Keys ===
1. Click Start and click Run.
2. In the Open box, type regedit and click OK.
3. Click the plus (+) sign beside HKEY_LOCAL_MACHINE.
4. Click the plus (+) sign beside System.
5. Click the plus (+) sign beside Current Control Set.
6. Click the plus (+) sign beside Control.
7. Click the plus (+) sign beside Class.
8. Locate the {4d36e965-e325-11ce-bfc1-08002be10318} key and click it.
9. On the File menu, click Export.
10. In the File name box, type savedkey and click Save. It is better
to save the "savedkey" to the desktop.
11. Click the REG_MULTI_SZ data type UpperFilters (found in right
window pane) and then click Delete on the Edit menu.
12. When you are prompted to confirm the deletion, click Yes.
NOTE: If this data type is missing, continue to the next
method.
13. Click the REG_MULTI_SZ data type LowerFilters (found in right
window pane) and click Delete on the Edit menu.
14. When you are prompted to confirm the deletion, click Yes.
15. Quit the Registry Editor and restart the computer.
May 24, 2010 | HP Compaq nx7300 Notebook
How to fix error 512 for evo d310 I replace chassis, rear chassis, or front chassis fan but still error I wont to fix it not show any error thank
Error 512 is a common Windows error. Error 512 is usually caused by missing system files, wrong system settings or a corrupted registry file. Run a registry scan to check for registry errors & other system problems. 90% of the time this will fix the cause of the error.
Optimize PC programs might do the trick, some are free to download.
Jan 13, 2010 | HP Compaq Evo D310 PC Desktop
Computer Not Starting
OK, put Windows CD in let it load all drivers, hit F8 when asked, then it'll find windows on your hard drive and will ask you if you want to repair it or replace.
Repair it. You'll not going to loose anything.
Mar 26, 2009 | HP Compaq dc5000 PC Desktop
Compaq Presario ,C 501NR/CEL 430/512/80/COMBO/1 ,Notbook After start, a message appears on screen as: Run DLL Error...
I suspect that file is malware. If you can download an a/v program to anther computer then install it on CD or USB drive, you can run that program and remove any malware. Restoring the system to a date prior tho the problem can work too.
Dec 17, 2017 | Compaq Computers & Internet
Problem with video card, only show compaq screen
First connect llaptop to another monitor and open this pics!Display Settings have to be like in this pics and i hope it will help u...
http://img442.imageshack.us/img442/4357/videocardrh4.jpg
http://img442.imageshack.us/my.php?image=videocardrh4.jpg
Oct 11, 2007 | HP Compaq Evo n610c Notebook
Microsoft Windows 98 for PC Logo
124 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
