Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
My television is buzzing
My television works fine the picture and sound is ok but it buzzes every time i turn the tv on
  • Anonymous Dec 12, 2008
    i have a toshiba rear projection tv and it works fine except for the buzzing noise even when off.
  • Samsung Master
  • 8,617 Answers
If the buzzing is continuous, its most likely a defective color wheel.
Posted on Oct 31, 2008
I have a loud buzzing noise on my Toshiba DLP 46" projection TV. It is not the fan, it works fine. In fact the TV works great and has a good picture. The buzzing used to go away after awhile. Now it...
In some cases the buzz is external. The vibration of the unit may just cause a tray, flat surface, or other surrounding attachments to rattle and buzz. Look for anything that may be loose or laying on or about the TV.
Dec 09, 2014 | Toshiba 46HM94 46" DLP Projection TV 46" -...
The tv made poping sound & it lost the picture but the sound was ok, their is buzzing sound coming from inside the tv, after about a min. the set turn off & red light stays on. reset tv, same...
This model is prone to a lot of problems to the point where a year or so ago they offered a chassis replacement on an exchange basis.
I would with rear cover removed try to localize first where the sound or buzz is coming from: The ballast? the Light engine? The power supply?
I can help but as I said this model has a LOT of chronic problems.
Steve
Nov 01, 2011 | Mitsubishi WD-52525 52" Rear Projection...
I'm experiencing a loud buzzing (fan?) sound that just started recently while watching my HLP5674W. The picture is fine, but the sound of what may be a fan or something like that is very loud and will...
Loud sound would be coming from defective color wheel that is mounted i light engine, next to lamp housing. Replacement of color wheel is required expertise/ experience and professional will do that for you in correct and in safe manner.
Contact local tv repair shop to get color wheel replaced in tv.
Thanks.
Oct 19, 2010 | Samsung HLP5674W 56" Rear Projection...
Buzzing sound + Tv picture is very weird.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} CHANGED Z SUSTAIN BOARD.PICTURE PERFECT.APART FROM WHITE DOTS.. AND ALSO ALL FUSES AROUND IT .THINK IT COULD BE DUST OR FINGER PRINTS ON RIBBON JOINTS,,WILL RE CHECK AND WIPE F/PRINTS TO SEE IF ANY CHANGE.
GOOD LUCK
May 23, 2010 | Polaroid TLA-01911C TV
Picture ok but loss of sound with high pitched buzz
Power board have problems.Take the tv aparts put some super glues on all around the transformers.Will help lower the buzz alots or stop it completely.
Feb 17, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Apr 10, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Buzzing and poor recption
I wish I had a solution--My DVD picture and sound is fine, but it takes about 30-40 minutes to get any kind of picture but it is broken--not clear at all - and the sound is all garbled, totally stops for seconds to minutes a a time. It is only a little over a yr old. I finally isconnectexd today and am going back to my cheap-o but dependable tv.
Aug 08, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Light engine problem?
sounds like your ballast is bad let me know your model number and I should be able to help you
Apr 11, 2008 | Mitsubishi WD-52627 52" Television
Buzzing after 1 hour
Is the buzzing coming from the back of the TV, staying loud even when the volume is turned all the way down, or is it coming from the speakers?
Sep 04, 2007 | Mitsubishi CK-35306* TV
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
83 people viewed this question
Henry  Thomas
Henry Thomas
