Question about Toshiba Satellite A215-S7422 Notebook
Computer dead despite working power supply (power and charger LED are off)
Computer has shut down suddenly and can't be switched on again. Power LED and charger LED are off despite the fact that charger is working and giving 19V (checked with voltmeter). Computer remains dead
    Scholar:
  • 136 Answers
Try removing the battery. It might be damaged and overloading the laptop. Also, before you replug the AC cord, press power for at least 5 seconds.
Posted on Nov 02, 2008
  • David Aug 15, 2013
    I have already tried reseting like that no it did not!
My computer shuts down without any warning at all. The problem has occurred 4 times this week when charger is unplugged but power icon still shows me approximately 50% battery. Sometimes computer lets me...
Check you power settings. It is possible that it is set to shut down at 50% battery power.
If it is overheating, that too will cause a shutdown. What is happening at the time of shut down? Are the vents on the laptop being blocked in any way?
Sep 04, 2011 | ASUS Computer International U35jc A1...
My lenovo G550 appears not to charge when the charger is plugged in despite turning the mains power on and off to see if power is getting though and the blue neon light showing on the mains...
Hi m529,
I see you are having issues with you G550 charging.
You mentioned that the light on the charger is lit up but then it suddenly switches Off, and you also mentioned that the charge still has a light but the power is somewhat low despite of a fully lit up charger Light.
Have you tried draining the power from the system?
  • Remove the battery and the Charger or AC Adapter as well call it from the G550 then press and hold down the power button for 10-15 seconds to drain power from the system motherboard.
  • Once drained connect the AC adapter but do not connect the battery yet, then turn the Laptop ON to see if the system will power ON using the AC adapter/Charger if it powers up then there is no problem with the AC adapter/charger.
  • After testing the AC adapter if it is working power down the Laptop doing a normal shut down.
  • Once shut down or turned Off insert the Battery back in the Laptop then turn the Laptop ON using the battery only without the AC adapter/charger see if the system will turn ON using the Battery only.
  • If the Laptop powers On using the battery alone with out the AC adapter then the battery is most likely working as well on the issue.
  • Now power down the Laptop then connect the AC adapter to the Laptop with the Battery in the Laptop as well then turn the system ON again see if the problem will Occur again having the battery and the AC adapter/charger if the Problem happens with both Battery and AC adapter on the Laptop then the problem is the Motherboard, most probably the motherboard is having issues relaying power from the AC adapter to the battery and may be sent to the Depot for repairs.
I suggest that you call Lenovo for further information about your system, if you still have warranty and is still in the one year period then your system will be covered for any repairs needed - you can call @ 1 877 453 6686 for troubleshooting, you will be asked for a serial number Located underneath the Laptop on a small white sticker that states s/n meaning serial number.
I hope that this Helps.
Have a nice day,
mvincentc
Jun 18, 2011 | Lenovo G550 PC Notebook
Green led on the back of the tower flashes when plugged in but not getting power to on/off switch thus computer will not turn on.
Sounds like the main psu has gone. Try unplugging from the mains comepletely for 5 mins, reconnect and try again. If it is "dead" or it powers up than immediately shuts down again.....it's your main internal power supply. If you are not affraid of electronics, you can buy them on ebay (just check the spec of the original first), if not, your nearest computer repair center should doi it for anything from around £50
Best Of Luck
Sep 03, 2010 | Computers & Internet
I was just browsing around and suddenly it switched off, after that i cant switch it on any more.it doesnt give any sign at all no LED blinking or anything like that?i was using it without battery straight...
either your charger/power "brick " has died or the connection on the laptop form the power has broken.. .
best to try going to radio shack, to get a replacement power source,, ask them if you can try it out. ..first to be shure its not you laptop thats dead. .
dont spend more than 50$ on a power supply, , unless its one ofthose multipurpose all in one for multiple item power supplies. ..
Nov 17, 2009 | Sony VAIO VGN-N250E/B Notebook
ASUS A8JP Will Not Power On
"When the charger is connected to an AC source, the green LED shines steady and bright."
are you talking about the led on the AC-adaptor? cause if its that led that dims down, its a defective ac-adapter (even tho you still might not believe me). replace it and try again.
how would you know that the battery is fully charged?
please rate my solution after you have tested if it works out for you :)
May 19, 2009 | ASUS A8Jp Notebook
Psu shut down
99% TIME IT IS A FAULTY FAN GOING OUT.
REPLACING THE FAN INSIDE THE POWER SUPPLY WILL RESOLVE THE PROBLEM.
P/S ARE CHEAP, JUST BUY A NEW ONE OOR REPLACE WITH ONE YOU HAVE ON HAND
CANDYMANGANDY
Jan 27, 2009 | Antec Solution SL400 Power Supply
No booting
plz try with new power supply
May 22, 2008 | Computers & Internet
Gogear became dead suddenly
Battery is too low for player to charge. There is a firmware fix for this at www.p4c.philips.com
Fix cannot be applied until player is working again.
If you know someone who has the same player, put their battery in your unit to power up and apply firmware update to fix problem. Then swap batteries back again
Another way to get the player working is to remove the side panel to disconnect battery. Plug in the mains charger and reconnect the battery. You may need to do this several times before the player springs into life.
If this doesn't work try disconnecting the charger and battery alternately and wait 5 secs between attempts.
Dec 30, 2007 | Philips HDD070 MP3 Player
Failure to switch on
fails to switch on again despite repeated attempts.
this is due to power supply failure.
please call skilled tech to fix it.
Oct 14, 2007 | Televison & Video
No power
Did you try removing the power for about 10 minutes, then trying again?
do you get any lights or sounds after trying that?
Oct 11, 2007 | HP Pavilion a775c (A775CB) PC Desktop
Toshiba Satellite A215-S7422 Notebook Logo
319 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
