The lcd tv screen has 3 small cracks and from one there is only a black strip underneath
  • josephgubbay Oct 31, 2008
    can this be repaired?
    how much would it roughly cost to repair for a 40 inch lcd tv?
  • 320 Answers
It can be repaired, but only by replacing the LCD panel. The glass in the panel has conductors "etched" into the surface. Break the glass, break the connection. You will probably discover it is cheaper to buy a new TV than to pay to have the panel replaced. If this answered your question, be sure to rate it. Thanks and sorry about your luck.
Posted on Oct 31, 2008
  • Any Guy
    Any Guy Oct 31, 2008
    A 40 inch panel is probably in the $1000 - $1500 dollar range, depending on the brand. There is also a "core" charge added to this that could be as much as $1000. The reason for the core charge is that most manufacturers want the old panel back, because, depending on the problem, the panels may be able to be repaired. Unfortunately, with a broken panel, the manufacturer does not want it back, because it cannot be repaired. So you end up paying the core charge as well.
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
Is my Android tablet LCD screen cracked as well as the digital screen?
and you just learned a 45 dollar lesson . they are not made to sit on .
Aug 06, 2015 | Xelio P1001A-BK 10.1" 4 GB Black Tablet...
Display divided into 3 parts
LCD screen cracked, and Three even strips going across? Doubtful. Haven't seen it but I always have my mind open.
Three strips that are irregularly shaped? Look like glass that has cracked?
'Jagged edges'?
LCD screen is broken.
Three even strips indicates to me, that there may be a problem with the Video Cable. Then the screen Inverter is next in the diagnoses.
My money is on the Video Cable.
ALL power removed, Anti-Static Precautions FOLLOWED, I would check out the graphics chipset first.
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the laptop.
Left rear side. This is an example of a VGA Cable, and VGA connector. (VGA port on a laptop ),
http://en.wikipedia.org/wiki/VGA_connector
(Color of connector does Not matter. It is generally Blue, though)
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
2) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
There are at least 3 display options available;
1) Laptop internal monitor ONLY
2) Laptop internal monitor AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold down on the Fn key, and at the same time tap once on the F5 key. (The F5 key is the Display Toggle-Over key)
No display on external VGA monitor?
Hold the Fn key down again, and tap once more on the F5 key.
Is the display on the external VGA monitor, the same as the internal monitor of the laptop?
Problem is the graphics chipset.
Display is fine on the external VGA monitor?
Problem is the Video Cable, screen Inverter, or LCD screen.
Video Cable:
A) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/big/Toshiba-Satellite-A105-14.jpg
Switch Cover removed, Keyboard removed. Shows you where the Video Cable plugs into the motherboard.
B) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/big/Toshiba-Satellite-A105-21.jpg
Palm Rest Cover you can see the white rectangular connector, for the motherboard side of the Video Cable, at the top left.
It's above the black cable, and near the screw hole.
The Video Cable leads from the motherboard, up through the left Hinge, and into the Display Assembly.
From there it connects to the screen Inverter, and back of the LCD screen.
http://www.ebay.com/itm/Toshiba-Satellite-A105-6017B0050801-LCD-Video-Cable-Genuine-OEM-Laptop-TESTED-/290754851160?forcev4exp=true&forceRpt=true
In the photo, (You can hover your mouse cursor on it to enlarge), the right side connector plugs into the back of the LCD screen.
The black connector to the far left connects to the motherboard.
The small white connector at the top with the Red, Green, Black, etc wires, connects to the screen Inverter.
(The small Black cable, that comes out from the black motherboard connector, is a Ground wire )
Due to the close proximity of the Video Cable to the left Hinge, it can be pulled on from just normal opening, and closing of the laptop over time.
This means the Video Cable connection on the motherboard side could be loose, or the LCD screen side, or both.
The diagnoses is to PHYSICALLY check BOTH connections. A loose connection at the motherboard, or at the back of the LCD screen could be so small in distance, that you will not see it with the human eye.
Could also result in damage to the Video Cable.
View the Video Cable with the Switch Cover removed, and see if there are any obvious signs of damage to the sheath of the cable.
If there is there could be damage to the tiny wires inside the Video Cable. (Stretched/Broken)
Use a multimeter set to OHMs, to check all wires inside the Video Cable for continuity, or have a 'Mom and Pop' computer store check it for a few bucks, or replace the Video Cable.
Video cable connections are tight? Video cable continuity check checks out OK?
Screen Inverter.
The test for a screen Inverter is to use a sensitive multimeter.
Read fairly expensive.
http://www.fonerbooks.com/test.htm
Not having access to a sensitive multimeter that you can use, means just replacing the screen Inverter. Seems like 'part changing', and it is, but you have to work with what you've got.
http://www.sparepartswarehouse.com/Toshiba,Satellite,A105,Laptop,Inverters.aspx
Find THE model number for your laptop, and the correct screen Inverter. A screen Inverter, and an LCD screen are a MATCHED unit.
Screen Inverter is checked out to be OK, or replaced, and symptoms are still the same, the problem is the LCD screen.
Remember, the first part of the diagnoses was to see if the divided parts were EVEN going across, or jagged and irregularly shaped.
Jagged in shape, and not even strips going across, means cracks in the LCD screen.
Replace.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
[ Main article for A and B links above;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm ]
For additional questions please post in a Comment
Regards,
joecoolvette
Oct 22, 2012 | Toshiba Sattelite A105-S2051 Notebook
My 3 year old daughter was wiping our 50" Sony SXRD LCDTV with Lysol wipes. I didn't see where on the tv she was wiping, but know the bottom corners of the tv are totally blacked out and a black...
It sounds like she may have cracked the LCD display.
LCD (liquid crystal display) are very delicate nad any impact, even by a three year old could damage the screen beyond repair. Could you please submit a photo of the screen when on?
Oct 12, 2017 | Televison & Video
KDL46W4100 no picture small white crack is visible when turned on. Crack got longer and eventually went across entire screen. People have told me the lcd is broken and it's not worth fixing - ie the part...
Yes, thats correct.
If lcd tv screen got hit by some thing then lcd panel got cracked and does show distorted lines or cracks instead of picture and lcd panel have to be replaced that would cost you 70% to 80% of new tv price.
New TV is better option.
Dec 16, 2009 | Televison & Video
I think the inside panel is cracked
Yes lcd screen is cracked. No way to repair, other than changing screen. Cheaper to buy new tv.
Jul 20, 2009 | Vizio L32 32 in. LCD HDTV
Broken LCD tv screen.
The reapair will exceed replacement cost of the set.
Apr 23, 2009 | Televison & Video
Change of CMOS battery in IBM Thinkpad 1400 2621
This battery is hidden under the keyboard slightly up and to the right of center of the keyboard. To get it out is a pain.
Start with the computer sitting flat, lid closed, lid latchs facing you.. just like you were getting ready to open and use it.
Spin it around, rear ports facing you. Right above the external video port, on the right hand side, there are two screws, at a diagonal UP from the port itself, very close to the bottom edge of the LCD. Remove them. There is a small notch between the screws, using a small flat-blade screwdriver, pry up in the notch and pop the platic backing free from the rear of the laptop. DO NOT open it more than a small crack, you are just popping loose a small plastic tab. Open it too wide and you will lock it closed again or break the plastics when you open the LCD lid.
Spin the machine around again, and open the LCD carefully as far back as it will go normally. Find the Power Button. The Power button is to the far right of a plastic 'strip, with 4 other buttons on the far left. There is a small clear plastic strip overlying this button 'tray'. Find the small notch in the bottom edge of the clear plastic strip, use the flat-bladed screwdriver, and gently pry up, popping the plastic strip out of the tab holes in the tray. Under this plastic strip is a black adhesive 'strip' that has a house, magnifying glass, etc. markings on it, and 'i Series' or somesuch printed on it.
Using a razor blade, peel up the black adhesive strip on the left and right ends of the button 'tray'. You will find two small silver screws. Remove these. Then using your screwdriver, or as I did, a dental pick, *gently* pry up the entire tray from the BACK edge of the tray, and by lifting up the left side of the plastic tray. You will have to work it out from under the edge of the LCD bottom on the left side. DON'T yank on it, there is a small cable attached to the bottom of it. You will be able to rotate it toward you and roll it over, exposing the small latch holding the cable in place. Its a small, press-fit latch like what holds a keyboard cable in place. You'll need to work it open by lifting the left and right edges till the latch becomes loose. Pull the cable straight out of the slot, remove the entire plastic 'tray', and set it aside.
On the far upper right of the keyboard there is a small metal tab holding the right upper edge of the keyboard. Reach around to the back of the computer, right-hand side rear, find the little square thumb-notch, and pull it out. The latch on the upper right edge of the keyboard should retract. Now, while lightly pressing down on the keyboard, push the keyboard away from you. It should slide backwards and the front tabs on the front keyboard edge will pop out of the slots. Lift up the touchpad area, popping up the bottom edge of the keyboard, clear of the plastics, then pull the keyboard slightly toward you. It should pop loose all the way around. DO NOT yank on it, there are 3 small cables attached underneath. You wil need to lift the keyboard up enough to reach the cables and pop the lockdown tabs loose, then pull the cables straight out of the slots they are in. The cable slots are attached to the motherboard, the cables are attached to the keyboard.
Removing the keyboard will expose a flat silver panel underneath. There are 5 screws holding down the panel, 4 in a 'box' configuration on the left, and a single one on the right, and several slide-tabs around the edges. Remove all 5 screws, then slide the whole tray to the right, while lifting up. The entire tray will pop up, with the video card heatsink attached on the left-underside of the tray. Set this aside. Directly in the middle of the big hole you now have is the battery. Its smaller than a standard desktop motherboard battery, looks like a small silver button. Gently pry up on the bottom-left edge of the battery, very carefully or you will break the plastic clips holding it in place, and pop it out.
All done. Reverese order to put it all back together.
Feb 21, 2009 | IBM Thinkpad I1400 2621 Planar TV...
Cracked screen - c653
I've the same problem and was able to remove the screen easily: The connector strips can be unsnapped by pulling ahead the little black parts on the left and right.
But where did you get a replacement for the cracked screen?
Mar 12, 2008 | Kodak EasyShare C653 Digital Camera
700w lcd replacement now is black screen
Yes, most likely you have missed the proper technique of installing the ribbon strips correctly into the connection block.
I did the same thing and it took me three tries to get it right... I stumbled on this by playing with other ribbon strips on the phone that I could access better and found that there is some sort of “step” or “threshold” inside of the connection block that makes you feel like to have "seated" the ribbon strip at the bottom of the block when in fact you have to push harder to actually push the ribbon into the block fully and make contact with the connectors, and then snap the locking bar down.
It's an easy mistake to make since the connection block and ribbon strip for the screen are hard to get hold of with your fingers... try using some tweezers or small long nose pliers to hold the ribbon and seat it fully.
Now I still am trying to figure out how to unlock and install the touch screen ribbon into the connection block… it’s really small and does not seem to what to unlock to allow for a full installation of the really small ribbon strip and lock it in, so I used a piece of duct tape to hold it in place and it works fine… not my perfect fix on this one, but my ph works…
Robert R.
Oct 03, 2007 | Palm Treo 700w Smartphone
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
