Question about Frigidaire FEQ1442ES Electric Dryer
Control panel should there be continuity at the back connections of the control panel. One is for red and the other for black wire input. thanks
    Sergeant:
    Champion:
  • 324 Answers
There will be continuity if you are reading through the heating elemant,It all depends on where you are reading it.
Posted on Oct 31, 2008
I have a vsx44 pioneer and i plug my subwoofer do not work my sub has 2 wires and i have an adapter to plug at the receiver
Is the adapter on the back of the receiver a yellow one (like a tv's red/white/yellow)? And the sub itself is a 2 wire (red/black)? If the subwoofer is just a speaker with no electronics and you answered yes to the first two questions then continue reading...
Problem: New receivers suck and are made for subwoofers that are self powered. The subwoofer input on the receiver only puts out a low signal. The subwoofer itself will amplify the the signal.
Solution: Find a receiver that supports the older subwoofers or do like I did... buy a used 3D surround system for around $10 on eBay, if you don't have one laying around. Be sure to find one that shows a picture of the back so you can verify that it has the 2 wire inputs and supports a subwoofer. Once you have it, connect a cable from the receivers subwoofer output into the surround systems input. It will be only one wire so plug it into the left (white) input on the surround box. You can also use a splitter to get both left/right inputs.
This will enable your subwoofer to be used again and will also give you alot more control over it. Turning off the surround sound box will allow you to keep the bass off when needed. You will also gain individual volume control over your subwoofer this way. I hope this helps!
Mar 01, 2015 | Pioneer Elite 7.2 Channel Network Black AV...
Jet sound equalizer js 214 wire color code
Black wire is ground, Red with 5a fuse is hot. Green/black is L Ground BTL, Grey /black is right ground BTL, the RCAs are left and right low level inputs. Then there is the 5 pin connector. It has a red wire for +12v, two black wires for input grounds, a green wire for left Hi input and a gray wire for right high input. If you install using traditional common ground high level, then you don't used the two BTL wires. Just connect the wires from your 5 pin connctor. If you use the low level RCAs for inputs, then you only need to connect the red and black from your 5 pin connector.(Plus the main red and black) Make sure the switched on the bottom of your EQ are set correctly. COM for common ground and LOW for RCA input or High for Green/Gray wire input. If you are using a floating ground the select BTL and connect the two BTL wires to the floating grounds of your stereo. There is also a line input adjuster so you can adjust your input sensitivity to match your reciever. I have the owners manual if you have any other questions.
Feb 01, 2012 | Car Audio & Video
Case has 1 small speaker in front but dont know where to connect to motherboard. speaker have 1 black & red wire on small female plug
Input the speaker's jack to the mother board,from back side or the front panel,which is green socket.
Hope this helps. Let me know if you need more information Thanks
May 11, 2011 | Intel Motherboard
Do you know how to get sound back on when you switch to av1 picture fine but no sound thanks
Make sure that you have the audio input hooked up to the correct input (AV1). For the AV1 channel there should be either RCA (yellow, red, and white) or S-Video (generally a black plug) plus the red, and white from the RCA. Make sure the red and the white are both connected to the AV1 Input. Hopefully this solves your problem.
Thank you
Feb 28, 2011 | Sony Televison & Video
My machine wach but do not spin a the end.
Note: This solution is intended only for asker qualityisc as per Live Chat session discussion. Error code reads E47 which means the Control board thinks the PTC circuit (wax motor) is open.
Unplug the machine then remove the spring-loaded wire loop that holds in place the front of the bellows over the lip of the door opening in the front panel.
Using needle nose pliers, start where the spring and wire are connected at the bottom of the bellows and pull the wire out of the groove of the bellows then pull the bellows off of the lip of the front panel.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine and disconnect the electrical connections.
Measure the resistance of the wax motor. The normal resistance is around 1500 ohms. Shorted or open circuit wax motor means the door lock and switch assembly needs to be replaced.
Simply
replace the door lock and switch assembly (part #131763202) if the wax motor reads shorted or open to address the issue. But if the wax motor resistance is normal, check the continuity of the door lock and switch assembly wire harness, particularly the wax motor wire harness. Start with the continuity of the red/black wire of the wax motor harness to each of the red/black wires of the door lock and switch assembly harness. They should all have continuity; otherwise, replace the harness.
Remove the top panel to access the control board if further continuity test is necessary or if the red/black wire of the wax motor harness has continuity with the all other red/black wires of the door lock and switch assembly harness.
Remove the screws attaching the top panel to the rear of the cabinet then lift the panel off. The console can be removed from the cabinet to completely access the control board connections, particularly the door lock and switch assembly harness connections. Check the continuity of the red/black wires at the door lock and switch assembly to the red/black wire of the harness connected to connector J2 on the control board.
The problem is in the control board if the wax motor is good and the door lock and switch assembly wire harness has all the necessary continuity. The only viable solution, should that be the case, is the replacement of the control board.
Oct 03, 2010 | Frigidaire GLTF2940ES Front Load Washer
Need to determine wiring connections from camera to dvr for Samsung SSC DVR
Hi
Thanks for using FixYa. Please see the link to hook up DVR with camera---
Hookup Camera with DVR
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 16, 2010 | Samsung SSC DVR Digital Video Recorder...
I have a Philips 32'' LCD, when I hook a DVD it plays in black and white. It will play in color in side connecter only. Please help
The side connectors are usually composite connectors meaning the have a Yellow-video Red-right audio and White-left audio connectors. Now when you are connecting them to the back and you connect the Yellow wire from the DVD player to a component input which have Green,Blue and Red connectors to the green connector, you will get a picture, but it will be in black and white. Please take moment to rate my answer. Thanks...
Nov 22, 2009 | Philips 32PFL3403D/27 32 in. LCD TV
Motor for my vulcan convection range was disconnected for moving by previous owner. There are 4 leads on motor, red and 2 black, and only one red lead (marked #1) still has label. The stove leads are still...
Red wires are usually the in and out for the centrifugal switch. the black wire that goes to the panel inside the motor is likely the 120 connection, the panel is the start switch for the start winding of the motor. This black wire should be connected to the 120 (from inside oven) and one of the red wires (three wires together). The other black wire of the motor should be connected to nuetral (you will have to determine which of the wires you have left coming from the oven is nuetral) the other red wire should be connected to the wire that feeds back into the oven for gas valve/thermostat controls (you may be able to trace this wire by hand to see if it goes to thermostat and gas valves). Hope this helps.
May 03, 2009 | Vulcan 36LC Gas Kitchen Range
House has two black and one white. dimmer has one black, one green and one red. WHat connects to what? THanks
Black wires are the hot side the power line, white is the neutral, and green is ground. On your dimmer, the black wire is for the AC input and the red wire is the output to the lamp you want to control.
If you are replacing an old switch with the dimmer, the two black wires will be connected to the screw terminals on the switch. One of those black wires is the AC feed to the switch, the other black is the one that goes to the light fixture. You'll need to determine which is which so you can hook the dimmer up correctly.
For a few dollars you can pick up a tester that lights and chirps when it's near a hot wire. Turn off power to the light circuit at your circuit breaker or fuse panel. Remove the old switch and disconnect the wires. Make sure the bare ends are not touching anything and turn the power back on. Hold the tester near each of the black wires. One of them will cause the tester to light up and the other one will not. The unpowered wire is the one going to the light fixture. This one connects to the red wire on the new dimmer. The hot wire is the feed that connects to the dimmer black wire. The green wire on the dimmer connects to the other green wires already in the box. Turn the power off again and make your connections using UL approved twist-on connectors (wire nuts), which probably came with the dimmer. Fit the wires and dimmer back into the switch box, secure it with the mounting screws, replace the cover plate and turn the power back on.
Voila! You'll have a working dimmer. A Google search for "installing dimmers" will turn up several links to sites with good pictures.
Apr 11, 2009 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
Panel yellow light flashing and also nothing showing on screen"
Make sure outside box is in auto mode. If you pop the display off of the wall you will see four wires connected to the panel. Make sure all are connected. Next, go out to the panel by the pool and make sure the four wires are connected there. If his didnt work the next step would be to ohm out the wires. Disconnect the wires from both ends (house and pool), On one end twist the red and black together and the green and yellow together, on the other end (with a ohmmeter) check for continuity (red-black and orange-yellow). If they check out then you either have a bad display panel, or a faulty main logic board in the box by the pool. In this case just pray that it is the display panel.........
Mar 23, 2009 | Jandy Aqualink Rs4 One Touch Control...
Frigidaire FEQ1442ES Electric Dryer Logo
48 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
