Question about Proscan PS32500 32" TV
No audio Audio was working one minute, then nothing. checked input (DVD vs. cable box), audio processor settings (stereo vs mono), SAP setting, and turning volume up on cable box, etc... NOTHING! a "click" sound comes when you adjust up or down. Possible audio processor problem???? What else can I check?
    Genius:
  • Proscan Master
  • 1,689 Answers
Make sure that the sources have audio to begin with. Carefuly check all menus and setups.
Yes. It is possible that the audio circuits in the TV have a fault.
Jerry G.
Posted on Apr 29, 2008
Brand new, connected to new cox cable box, video works great but no sound
if just running HDMI cable try adding audio cables too, check all your volume and mute settings in the system setup.
If you have audio on most channels, but have silence on some or all of your local network channels, you may have the Secondary Audio Programming (SAP) turned ON. Complete the following steps to turn off SAP.
  1. Press the Settings or MENU button on the digital remote.
    Result: The Settings screen displays.
  2. Choose from the following options.
If... Then... Disable SAPdisplays Press the Select button. Choose SAP Languagedisplays Use the left or right arrow buttons to choose the English setting and press Select. PREFERENCESdisplays Scroll to the Language option, select Audio, then select the option labeled Primary or the one labeled English. If the above quick fix doesn't work, there may be a problem with MTS, Stereo, or another SAP issue. Try the following:
  • Verify in the program listing guide that the program has MTS, Stereo, or SAP features.
  • Check to see if the MTS, STEREO or SAP light on the TV or VCR is on.
If the light is not on, try the following:
  • Push the MTS, STEREO, or SAP button on the TV or VCR.
  • Adjust the fine tuning on the TV set to restore the stereo or SAP.
http://www.cox.com/residential/support/tv/article.cox?articleId=81da8760-5c47-11df-ed4d-000000000000
Jan 20, 2016 | Televison & Video
We bought a universal remote to increase our access to cable channels. Some of the channels display the symbols S.A.P. and have no volume. How do we disable the S.A.P so we can hear the volume.?
S.A.P. Means Secondary Audio Program.
SAP, Mono, Stereo, Etc. You should be able to switch this from your remote. Even universal remotes should have this button to adjust sounds. Otherwise you need to go into the TV menu (not the remote) and change it from there. The only way you can change it on those channels is to switch manually. Happens a lot on these older TVs. No worries. Very common.
On many sets, the audio channel can be switched by remote control or through a SAP switch located around the tuning panel or "on screen programming." Usually, there is a setting labeled SAP, AUDIO SELECT, B-AUDIO, MTS, or MENU. By changing the setting, you should be able to select SAP. Not all TV sets are alike, so you might want to check your instruction manual for all the details.
Mar 10, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Under the channel it says SAP and no sound comes out on some channels,on other channels its says stero and works fine how can i fix the problem
I found this information in the manual, and perhaps it will help:
1 Switch the audio.
• Every time you press [AUDIO], the audio will
be switched as below.
MAIN : Outputs main-audio
SAP : Outputs second audio channel
MONO : Outputs mono-
Also the manual says this about SAP:
SAP
(Secondary Audio Program)
Second-audio channel delivered
separately from main-audio channel.
This audio channel is used as
an alternate in bilingual broadcasting.
Here is a link for the manual, in case you want to go over the settings. I'm thinking this is a setting problem in the menu, but it can be a physical problem with a cable line.
http://dukeelectronic.com/Manual/IWT3206.pdf
Of course it could also be a trickier problem, but check your settings, check the cable line with another TV if possible, and then contact ILO Support for help, in the event nothing fixes it.
Good luck, and hope this helps.
Dec 01, 2010 | iLO IWT3206 TV
No sound on some channels, other channels fine
Your SAP/MTS function is most likely turned on. This feature has 3 modes: Stereo, Mono and SAP. Stereo and Mono are easy to understand, it's the SAP that can get you. SAP stands for Second Audio Production. It is used to provide weather, information or an additional language translation of a program. Some broadcasters simply transmit the mono audio over the SAP audio channel when the are not using it for other purposes. Other broadcasters simply do not use it, which does not give you any audio. Look on your remote for a SAP or MTS button. If you do not see one, look in your TV user menu for this feature. If you are using a cable box, look in the audio menu of the cable box. You are looking for something set to SAP... just change it to STEREO. I hope this was helpful.
Mar 26, 2010 | Televison & Video
Using my universal remote contol,lost sound on 2 TV channels
The solution is to change the audio input from SAP (secondary audio programming - default on TV sets sold in Canada) to Stereo or Mono. Your remote will need to be able to access the "Menu" settings screen for your television set.
May 07, 2009 | Samsung TV Remote Control
Audio with digital channels, no audio with analog channels
I was getting a constant mono setting for all channels with no option to set it to stereo. I called Sharp, and they said that in order to receive stereo sound, you cannot use a standard coaxial cable. You need an S-Video or HDMI cable. This not only resolves the mono audio issue but also resolves the analog (vs. stereo) issue. Hope this helps!!
Feb 10, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No sound on 1 channel
Check Your Audio Setting While On That Channel Access Your Tv Menu And Find Audio Change Between Sap Stereo And Mono Probably Will Fix It May Not.
Jan 05, 2009 | Broksonic SC20145 20 in. TV/VCR/DVD Combo
Missing Audio
your remote should have a audio setting button to go from stereo/mono/sap. Also, there should be a setting within the menus... you just have to find it.
Dec 16, 2008 | Sharp Aquos LC-13SH3U 13 in. EDTV-Ready...
No sound on about half of the channels
Press the menu button on the remote then select #1 AUDIO once in that screen select #3 AUDIO PROCESSOR thats where you will have the selection of MONO, STEREO or SAP.
Mar 15, 2007 | GE 46GW947 46" Rear Projection Television
No audio on select channels
Go into the TV's menu and see what type of audio mode its set on. If it says sap turn on to stereo or mono. If it says stereo, set to mono. Also try to unplug set for 12 to 24 hours.
Sep 03, 2006 | Sharp 25R-M100 25" TV
Proscan PS32500 32" TV Logo
156 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
