Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Picture shrinks and expands
My picture shrinks and expands.i have a 9p6040 c102
  • rgp617 Nov 13, 2008
    I have a model 9p6044 C102 with the same problem. Can I order the parts/repair kit to fix the problem? Please assist me with solving the situation & contact me at rgp617@aol.com.
    Who should I call or what web site can help me get results?
  • Philips Master
  • 5,568 Answers
Not positive but this sounds like the impending failure of a specific power supply, namely an output providing deflection voltage to the CRTs. This may be simply a circuit on the main supply or could be a separate supply on a different board than the main supply.
If it is not affecting brightness and contrast, it isn't likely to be the primary supply that is failing. I'm pretty sure it will continue to degrade.
Posted on Oct 31, 2008
  • Philips Master
  • 3,459 Answers
I had the exact same problem. The screen would shrink then expand. After thrity minutes it would correct itself. Then one day it just broke - no sound and no video. You can find a repair kit here http://www.TvRepairKits.com . Hope this helps.
Posted on Nov 02, 2008
  • Edward
    Edward Jan 11, 2009
    Common problem on this model of Magnavox TV sets. The screen will shrink then expand. After about 10 minutes it may or may not correct it self. After a few months of bouncing in and out the TV will just stop working. You will have no audio or video. You can find a repair kit herehttp://www.TvRepairKits.com . Hope this helps.
  • Edward
    Edward Feb 04, 2009
    Goto the site www.TvRepairKits.com. They have put together a repair kit for this problem.
I have a Philips Magnavox 9P6040 C102
Yes the coolant in the CRts need replacement. You can get the Phillips CRT Coolant repair kit at the following link which contains the coolant and instructions.
http://servicemanuals.vstore.ca/
Aug 24, 2009 | Philips Magnavox 9P6034C 60" Rear...
No picture or sound
Put the old chip back in...does the shrinking/expanding problem return? If so the new chip may be faulty.
If the problem stays the same - no audio/video  - check your soldering, cables, etc.
Nov 02, 2008 | Televison & Video
Phillips 9p6040 c102
I had the same issue. The screen would shrink and then expand over and over. After thrity minutes it would correct itself.
After a few months of doing this it just broke - no sound and no videe but the power light was still on.
I searched these forums but did not find clear instructions or kits on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.
To help others I documented the fix and created a repair kit and step by step quide on how to fix the problem. You can find it here. http://www.magnavoxhelp.com
Jan 13, 2008 | Philips 9P6040C 60" Rear Projection...
9p6040 c102
Visit www.TvRepairKit.com for a repair kit. Its a common problem and an easy fix.
Jan 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
The picture is fuzzy and shaped like a hour glass
Dec 02, 2007 | Philips 9P6040C 60" Rear Projection...
Philips Magnavox 9p6040 c102
IC's on convergence bd. 1st try opto coupler philips part# 483520988561 actual part# to buy HCNW136 some replace all 3 IC's philips# 483520987834 actual# MC34065p and philips# 483520987712 actual# SC78104 search google to buy.Datasheets at datasheetcatolog.com
Nov 28, 2007 | Philips Magnavox 9P6034C 60" Rear...
9p6040 c102 60" television - has power, no sound or picture
Screen shrinks and expands and wams up after 10-20 minutes and then went out completely? Power light still comes on and remote still works? This is a common problem for this model and is most likely related to a bad chip. A tech will charge you over $300.00 to fix it but you can buy the repair kit including the chip, step by step instructions and repair manuals for under $40.00 if you are willing to do a little soldering. Go to http://www.magnavoxhelp.com/ and enter your model or chasis number and order the kit. This will not fix color problems!
Sep 20, 2006 | Philips 9P6040C 60" Rear Projection...
Phillips Magnavox 60" tv
If your video is shrinking and expanding its the opto IC. You can get a repair kit from www.magnavoxhelp.com
Sep 11, 2006 | Philips 9P6040C 60" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
251 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
