My vibe mono box 4 amp when used to play a vibe space 12" sub does not produce sound, it just produces nothing but a sound like blowing a rasberry on and off, its deffinately the amp as ive tested the sub, and ive taken the amp apart and can't see any burnt termianls or any surface damage to the amp. can you help me with a solution? have you come across amp blowing rasberries when attached to a subwoofer? cheers josh
SOURCE: Subwoofer not working
you have to reset the receiver, i had the same problem, works now, it's great, should be in the instruction booklet. I think it was, hold the power button while you disconnect it from the wall, not too clear but check the booklet in resetting system
Posted on Jan 12, 2007
SOURCE: Subwoofer Connection: Speaker wire to Mono RCA
The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
  1. Connect the mono RCA subwoofer output from your Sony with a 1xRCA-to-2xRCA splitter to both the left and right input of the cheap reciever's tape or aux input
  2. connect both speaker outputs of the cheap reciever to the speaker input on your subwoofer. make sure both black (-) outputs on the reciever connect to the black input on the sub, and the red outputs (+) on the reciever are both connected to the red input on the subwoofer.
  3. make sure the cheap receiver's volume is all the way down. turn your Sony up to about the loudest you'll listen to it. turn up the subwoofer amp until it's loud enough to sound good.
  4. leave the subwoofer amp alone, the Sony volume will all you ever need to touch from now on.
You can even now turn off your subwoofer / adjust the volume easily now!
Posted on Nov 11, 2007
OuttaControl
  • 4 Answers
SOURCE: Wiring 2 subwoofers to a mono amp?
The subs can be wired "parralel" or in a "series". it depends on the ohm rating of the speakers and the amp. Most amps can only go down to 2ohms (mono) so it depending on the ohm ratings of the speakers when wired in a series vs parralel that will decide how to wire them. you can always take the safe route and just wire the positives of each to positive on the amp and the negatives to the negatives on the speaker terminals. Do you have the speakers model numbers?
Posted on Dec 22, 2007
Hazardsneon
  • 100 Answers
SOURCE: Lanxar VW12D no sound after excess play
I'm not understanding what you mean by the "Sub doesn't even sound blown" if it doesn't play at all. One thing you can check is if you gently push in on the cone you shouldn't hear anything, if you hear a scratching noise and can feel resistance then you have a problem. If you have an OHM meter, you can check the voice coil impedance, it is a down and dirty way of checking to see if it is good or not. Measure all of the voice coils that you have and they should all read about the same, not necessarily exactly the same but pretty close. This test should tell you a lot. If it seems to test out fine there is something wrong else where. Let me know if you need more help.
-Andrew Hawkins
Posted on Apr 03, 2008
  • 236 Answers
SOURCE: Yamaha RX-V1200 subwoofer connection to Mirage BPS-150i subwoofer
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
Posted on May 03, 2008
What to do
well i don't know your budget, but if that's not really and issue, right now at best buy, alpine type E, 10" subs, peak is 750w and rms is 250w, each is 129.99. Alpine type R, 10" subs, peak is 1500w and rms is 500w, each is 199.99. These are the best subs i found at best buy. You could sell your current subwoofers and purchase those, and you'd save space and still get the lows you want. Goodluck
Jun 27, 2009 | Jl Audio 12W7 Car Subwoofer
No sound from subs
No sound is produced. ? The output disable mode is turned on. ? Refer to the instructions at ?Output Disable Mode? to turn the output disable mode off.
May 21, 2009 | Alpine MRD-M300 Car Audio Amplifier
Subwoofers pop then immediately produce no sound
Sounds like the two subs wired together might be too much of a load on the amp and it is shutting off. Try wiring the two subs in series. That will reduce the load on the amp but will conversely put out less power. Less is better than none though. In any case check your amp to see what the lowest ohm rating it can see, that ohm rating is where you want your subs and if faced with a choice of either going under (lower numerically) or over (higher numerically) GO OVER!-it is much safer.
Here's an article I wrote that can help explain how to wire the subs to the amp.
OHM LOADS, SUB WIRING, OHM RELATED POWER OUTPUT
SERIES SUBWOOFER WIRING
Wire the positive pole from one voice coil (using wire that is as thick or thicker than your wire from amp to sub) to the negative pole of the other voice coil (on the same sub). This will leave you with a positive pole from one voice coil and a negative pole from the other giving you the two leads that will be hooked up to the amplifier or other subs. When wiring in series, the ohms will go up numerically, and the load on the amp will go down. Almost all amplifiers power output will follow this rule, except some amps such as JL Audio's “Ohm matching” D Class amps.
PARALLEL SUBWOOFER WIRING
Wire the positive pole from one voice coil (using wire that is as thick or thicker than your wire from amp to sub) to the positive pole of the other voice coil (on the same sub). Then wire the negative to the negative in the same way. You can then wire to the amp or other subs. When wiring in parallel the ohms will go down numerically, and the load on the amp will go up. Almost all amplifiers power output will follow this rule, except some amps such as JL Audio's “Ohm matching” D Class amps.
MULTIPLE SUBS USING SERIES AND PARALLEL WIRING
In order to match your amplifiers ohm rating you can use parallel and series wiring together, just keep things even for power distribution and to avoid phase issues.
Example: I have two “Type X 12” subs” that have dual 2ohm voice coils and have to match my “Amplifier X” ohm rating of 2ohms mono. In this case, I would wire each subwoofer in series (giving me a 4ohm load), and then wire the two subs in parallel to get my 2ohm mono load. When wiring multiple subs just, treat each sub as a voice coil and wire accordingly.
POWER OUTPUT AND OHM LOADS
For example if “Amplifier X” can make 100watts@8ohms, it would make 200watts@4ohms and 400watts@2ohms. However with every drop in ohms the amplifier is put under more pressure. It starts to create a lot of heat, distortion figures begin to climb, damping rates drop, and some amps even throw power spikes when clipping. SO BE SURE TO CHECK YOUR AMPS RATING AND DO NOT EXCEED IT!
-Dynami
Apr 04, 2009 | Alpine Car Audio & Video
When volume turned up subs pop then immediatly produce no sound
u might have to turned your amp so u can play both subs your amp might be to small to run both subs at the same time an u gotta play around with the settings on your cd player so when u blasted your subs it has that nice bass to it not that poping sound.
Apr 04, 2009 | Jl Audio 13W7 Car Subwoofer
My twin jbl 12'' sub in a enclosure dont seem to be giving bass
Those 12's Need to be in a Ported Inclosure to release the Air that the Bass Produces. Use a 1 Inch Key Hole Bit and make 1 Hole at the Top Corner of Each Portion of the Box. Top Left and Top Right. Please Rate My Response! Thanks!
Feb 02, 2009 | JBL GT412 Car Subwoofer
Will this give me 400 watts on each
bignatedabal: You can't get something more out of a device than it's rating. In other words, if you have a 400W amp that's all it's going to produce. For example if you're looking to drive both sub spkrs @ 350W each then buy a sub amp with a rating of 700W @ 2ohms & connect your 4ohm spkrs in parallel to the amp. Each spkr will produce 350W of sound if everything is installed correctly.
1 thing to look for in amp mfg's. Look for those who rate their amps in RMS power. This is the true output rating. Many amps are rated in peak-to-peak which seems great but doesn't tell you the real story, unless you know how to do the math to determine the RMS. The better mfg's will take the time to test their amps & rate them properly. Also look for massive heatsinking (the cooling fins). I consider cooling fans to be a benefit as well.
If you have addtional questions, drop me a line.
peace-out
Jan 18, 2009 | Kicker ZX400.1 Car Audio Amplifier
Why aren't my games playing on the nintendo fc twin?
The FC Twin connects through an RCA connector, and can be hooked into a surround sound system. When using stereo and surround output from these systems, NES sounds and music may seem very different from their typical mono output. Using output modes that properly generate mono sound, either through a single center speaker or cloned to multiple speakers, the sound output sounds mostly identical to the original NES. The FC Twin does not produce some sounds faithfully, even with mono output; sound effects in the Super Mario Bros. series games will for example immediately seem different. Nevertheless, some later models of the console produce NES sound much more faithfully than units made closer to launch. Recent models produce sound with complete fidelity.
all this can be found here
http://en.wikipedia.org/wiki/FC_Twin_Video_Game_System
Jan 18, 2009 | Nintendo FC TWIN Console
Knocking noise with my kicker compvr 15"
comp VR 15s are rated @ 500W RMS 1000Peak.
The lanzar vibe amplifier is 2 x 600W RMS at 4 OHMS 2 x 1200W MAX at 4 OHMS 1 x 2400W MAX at 4 OHMS Bridged 2 x 1000W at 2 OHMS RMS.
Your subs are single 4 ohm subs.
If your subs are wired stereo, they both are seeing 600W. (more than the rated RMS)
Chances are, you have them wired parallel to a 2 ohm mono load - of which that amplifier is not rated. In theory, it will produce about 2000W @ 2 ohm mono for a short period of time.
Your amplifier is too powerful for your subs. Turn down the gain setting to 3/4 or purchase better subs. Also be sur the subs are inthe proper enclosure. It sounds as if they are excurting past their linear x-max and colliding with the rear bump plate. This will cause damage down the road if left as is.
Nov 26, 2008 | Kicker CompVR 05CVR84 Car Subwoofer
Best results
huge shared common space slot loaded box (size depends on sub 10", 12" 15" you need to clarify that please) the amp specs on earthquakes site say the phd5000 is rated at a max output of 5k watts at 1 ohm 3k watts at 2 ohm so, with 3 dvc 2 ohm subs you only have 3 options of which only 2 will be a usable solution:
1. 3- 2ohm dvc series at sub parralel at amp = about 1.33 ohms at the amplifier this is the best option to get the most power to the subs as each sub will produce a 4 ohm load then wire each one to the amp the amp sees 3 4 ohm parralel loads which = 1.33 ohm so based on the amp specs you would be close to 1200 watts per sub.
2. 3- 2ohm dvc wired in series at sub and all 3 subs series wired together very difficult to wireand will give you a 12 ohm load which is next to no power at all (not a viable solution)
3. 2- 2ohm dvc parralel wired to each other and then at amp the amp sees a 1 ohm load and makes 5k watts max but you can only (REREAD THAT LINE! ONLY USE 2 SUBS IN THIS WAY) WHICH GIVES THE MOST POWER BUT ONLY USES 2 SUBS
Jul 09, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Whats is the perfect amp?
I have 2 of these 12" running in a Large slot ported box with an:
"Ultra Linear UL2402"
600RMS X 2 @ 4Ohm (Stereo) 1200RMS X 2 @ 2Ohm (Stereo) 2400RMS X 1 @ 2Ohm (Mono)
Can be run in Tri-mode with 3 8Ohm subs, which these subs are. I have not tried this mode. This is
600RMS X 2 @ 4Ohm = Max RMS of your subs. You should run the max of your subs, less wear on the amp you are using , and i doubt you will ever need to turn it up far before it blows out your trunk or window :P
1200RMS X 2 @ 2Ohm = Blown Subs!
Has 4 x 25amp fuses, most will tell you this only has an RMS of around 845, an "ultra linear circuit" produces twice the output power over Modern amps.
Can had on Ebay for around $100. I bought mine for $101.
This Amp pounds, i could quickly tell a difference going from 300RMS X 2 @ 4Ohm with a Kenwood amp. I Had to turn all my settings down on the new amp to have a better balance in sound.
Jan 29, 2008 | Volfenhag ZX-4712 Car Subwoofer
223 people viewed this question
 Grubhead
Grubhead
