Question about Singer 7422
Beeping Sewing Machine
My Singer model 7422 sewing machine will not sew. It will only beep. I can turn the end knob and it will sew just fine. When I push the pedal it just beeps. HELP
  • 2 more comments
  • dowhatgeorge Nov 05, 2008
    TA DA This fixed my problem. Thanks a million!!!!!
  • Anonymous Mar 13, 2014
    broken handle for model 6038 singer sewing machine
  • Anonymous Mar 19, 2014
    The Singer Stylist machine beeps a C2 code when sewing a button hole.
  • Anonymous Mar 30, 2014
    My machine is not sewing, i've rethreaded, i've cleaned as described with dmc floss, checked the BH is in the correct up position, maching beeps twice and does not sew
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. The beeping sound is a warning message. Secondly Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
Posted on Nov 03, 2008
  • Pat Prunty
    Pat Prunty Mar 10, 2014
    It worked = thank you so much.
Trying to thread bobbin and viewed manual several times. singer model 7258. screen first flashes C3 and then ][. cannot find troublr shooting codes in manual.
Why do I keep getting a C3 error (accompanied by lots of beeps) when I turn on my machine?The C3 error as well as the beeping when you turn on your machine indicates the foot control plug is not fully pushed into the sewing machine. Turn off your sewing machine and push the foot contol plug into the machine fully. Turn your sewing machine back on.
Oct 22, 2017 | Singer Sewing Machines
Why won't my bobbin winder work
It could be the belt has snapped, or something else it out of adjustment. You can either get it fixed, or purchased an inexpensive bobbin winder for under $25 from WalMart online.
Oct 18, 2014 | Singer Advance 7422 Electronic Sewing...
I want to do a button hole on my singer sewing machine model 7422 i've got the manual and i've followed what it say's but it only beeps when i pressed the pedal to start sewing i followed the instruction...
I do not have a fancy Brother machine. From what I understand, you just need to do a zig-zag stitch around the "rectangle" that will become the button hole.
You could forego whatever instructions they provide and just set your stitch width as appropriate and then move the stitch type to a thin (close together stitching) zig-zag, just shy of "satin stitch" (which is just sewing back and forth all in the same place, and therefore--useful for embroidery).
Sometimes easy does it can be the ONLY way to get things done. :) Sorry I don't know more about your specific issue but maybe the old school way will help.
Mar 03, 2014 | Singer 7422
Singer 7462 will not pick up bobbin thread
You need to adjust the needle timing - called "timing the needle".
How do to that is usually included in the service or repair manual for your model of machine. There are various online shops where you can order this.
Also, the machine is pretty similar to the Single 7422, and there's an ehow article on how to adjust the timing on that model that you might find useful.
http://www.ehow.com/how_7799647_adjust-singer-7422-sewing-machine.html
Dec 01, 2013 | Singer 7462 Mechanical Sewing Machine
Start sewing and starts beep say e2
try rethreading the machine top & bobbin
clean under the needle plate & in the bobbin area for loose threads or lint
try changing the needle
May 20, 2012 | Singer 7422
Singer advance 7422 beeps when i am trying to sew
are you getting a visual signal on your LED display ?
have you tried turning the machine off & waiting a few seconds & turning it back on again
have you tried cleaning the bobbin area for loose threads & lint?
how many beeps are there?
do you have a instruction manual for the machine? if not singer has one for free pdf download
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 7422 ) & click search
Feb 01, 2012 | Singer 7422
Singer 7422 beeps and all lights come on when peddle is pressed.
There are several sensors on this machine that just start causing the machine to malfunction for no apparent reason. One is one the bobbin winder, one on the buttonholer, and one under the machine which workd with the feed. It is far from an exact thing. If you can get to them, sometimes loosening them, moving them about then tightening them seems to 'fix' them. Sometimes not. Wish we could be more exact in explaination but sometimes we will move them repeatedly then they start working. It is hit and miss.
Sep 06, 2009 | Singer 7422
Not Sewing
Nov 15, 2007 | Singer 7422
Singer 7422 Logo
1,337 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
