Question about Refrigerators
Defrost heater wont heat up
I have the familiar issue with frost build up on the evaporator, which if unfrosted causes the fridge to stop cooling properly.
The heater works fine once connected directly to 220V, and reads about 130 Ohms.
The thermostat reading when closed is 0 Ohm.
The defrost timer operates fine - when moved manually to defrost mode it stops the compressor/ fan of the fridge. After about 30 minutes it automatically advances to cooling mode.
At defrost cycle I disconnected the heater to test the voltage across its relevant terminals and the reading is 206 Volts. This seems odd to me, as I expected the 220V reading. When the heater is connected the reading across it during the defrost cycle is 0 Volts.
I would appreciate any help.
\please feel free to contact me at roym123@walla.com
  • roym123 Nov 01, 2008
    Hello drcool
    I was talking about the bi metal thermostat, the same one in series to the heater. One of my firsts tests shorted the bi metal out (with no success in the heater).
    So I just tested this again with the heater (test point 1) and the bimetal thermostat (test point 2) unplugged, and manually rotated the deffrost timer to heating mode. Once rotated to heating mode I get the 206 Volts reading across these two test points (where the heater an bi metal combo used to be plugged).
    From your earlier reply can I assume a roblem in the actual wiring of the system? Are there additional elements (other than the wires themselves) that might be faulty?
    I tried to get the Amana BX518 wirimg schematics yet no luck there...
    Thanks,
    Roy
    Thanks drcool,
    I beleive my problem is solved!
    When I checked the common wire for continuity from the defrost timer to
    the heater I noticed it was not continous. When I went on to figure
    why I noticed that the common wire was blue, yet the wire connected to
    the heater was gray. So I followed the gray wire, and saw that a
    second thermostat connects the grey and the blue.
    I assume this is the faulty device in my system - still needs verification.
    When I shorted the heater gray with a blue wire (had a convinient
    hookup to an unused icemaker plug), and advanced the timer to defrost
    mode - finally the heater cam to life (burnt my finger in the process
    of checking... :-) )
    Thanks a lot,
    Roy
  • 958 Answers
So you seems to have done your homework. all the inputs are great.
you said you have 206 volts at the heater connection prior to connecting the heater.
and would become zero once the heater is connected.
so you have a loose connection from the timer to the defrost thermostat then to the heater.
does the defrost thermostat you are talking about is the same as the bi-metal that we used to refer in our technical language.( it is the part that would open up as the temperature inside the evaporator rises to a certain level.)
because if you are referring to the fridge thermostat which controls the compressor. ( this is also 0 ohm when closed), then the problem could be in your bi-metal.
this is the part in between the timer and the defrost heater.
it terminates the power once the temperature of the evaporator coil is about 5 degrees Celsius.
here's what you can do.
run the fridge for a day ( so that we would be sure that the bi-metal is close) then put the heater in place, turn the timer to heating mode by turning it slowly.
then place the test leads across the bi-metal, if you can measure 220 volts then that is the problem.
it is not shorting out even with a freezing temperature. you can further test the system by putting a jumper wire between the bi-metal and you heater should be heating up now.
tnx 4 using fixya,
drcool
Posted on Oct 31, 2008
  • francis rivero Nov 01, 2008
    ther should be no part at all of course connection sockets which could get corroded and fail.
    do a resistance check of all the wires from the heater pion of the timer, to the bi metal and to the heater then back to the common of the circuit. that should be the complete circuit of the heater.
    tnx 4 using fixya,
    p.s. don't forget to rate as you please.
    drcool
Hotpoint Future fridge freezer - freezer working well but top of the back of the fridge has a large build up of ice ??? And doesn't appear to be keeping the food cold enough
here are lots of things that can cause cooling problems. One of the most common causes of poor cooling in a frost free refrigerator is a defrost system failure. In such a case one or the other compartment may appear to be keeping proper temperature but that too may change in a short period of time. The fridge compartment's temperature rise is usually (but not always) the first to be noticed. Frost" and "Ice"
There is a difference between "frost" (a white, snow-like substance) and "ice" (usually clear and solid). When referring to what is seen during an inspection, please keep this distinction in mind as the possible causes for each are often very different. The Defrost System
Inspecting the (usually rear) wall of the freezer compartment for a frost build up is necessary. (In the case of many GE top freezer models, check the freezer's bottom panel.) If there is a frost coating on it, it is often a sign of excessive frosting beneath it. Sometimes however the evaporator cover panel will actually need to be removed (see the illustration below) before an excessive frost build will visible.
The refrigeration system's evaporator (cooling) coil is usually in the freezer compartment. This evaporator will periodically frost over and have to be defrosted by means of a heating system. When the defrost heating system fails, the frost can accumulate to such a degree that airflow throughout the appliance is hampered. There may be just enough air circulation to cool the freezer section but that will eventually stop too.
Sep 28, 2016 | Hotpoint Refrigerators
Refrigerator stopped cooling. As close as I can tell the fan in the freezer part was frosted up for a length of time and has possibly ruined the fridges cooling fan? Kenmore model 106 freezer on top.
If the fan in the freezer stops, then coll air from freezer will not pass from freezer section to fridge section.In that case, the freezer section will get over frosted but fridge section will not get cold, because cool air will not pass from freezer to fridge.The fan is there for two things, 1) for cooling the heating evaporator coil and 2) For flowing the cool air from freezer to fridge.---------- If the frost is getting collected and fan is getting stuck up in frost, then this is the problem.The defrost cycle is not running, the cooling cycle is running.---------------
This problem is called defrost problem.-------------
So first thing you try is , perform, manual defrost reset procedure.---------
The manual defrost reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. Then check,if same frost is getting collected, then its defrost problem,. If it's again building up ice that means the unit is not defrosting. It's starting the cooling procedure, and then while defrosting, it's not working. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Sep 18, 2011 | Kenmore Refrigerators
My model 249 has stopped working there is a click when you turn it on the the cold wont work
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working.
* Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn't work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Hope this helpout solving the problem.......
May 17, 2011 | Sub-Zero Refrigerators
My 5 year old GE GSH22JSRSS Stainless Steel Side by Side Refrigerator recently stopped cooling. I noticed a build up of frost on the freezer, so unplugged the fridge and let the ice melt away. After this,...
The problem you describe is that your defrost circuit has failed. The fridge should stop the compressor periodically and turn on the defrost heater to melt the frost buildup. Since the frost in building up on your coils, the fan can't blow the cold air into the fridge compartment. It defrost is controlled by a module that turns on the heater. Most of these failures have to do with the defrost heating element burning out. It can be replaced by someone who has some mechanical ability.
The coil and heater is located in the back of the freezer compartment behind the panel in the back. You can obtain parts from appliance repair outlet or online like appliancepartspros.com or repairclinic.com.
Dec 07, 2010 | GE GSH22JSRSS Stainless Steel Side by Side...
The freezer and frig both stopped cooling we turned them both off but nothing happened
Step 4 - Volt Test
Hope this help in solving the problem......
Oct 25, 2010 | Whirlpool Refrigerators
I have a two year old frigidaire wine refrigerator that stopped cooling after we moved.
Step 1 – Find the Problem
* Evaporator fan – Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper – Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils – Check to see that the condenser coils don’t have a dust build-up and that the condenser motor is working.
* Compressor – Make sure your compressor is working with on and off clicking noises.
Step 2 – Frost-Free Failure
Step 3 – Find the Timer
Step 4 – Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven’t got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn’t work.
Good luck in solving the problem.....
Aug 15, 2010 | Frigidaire Refrigerators
Not cooling
Step 4 – Volt Test
Take care......
Aug 14, 2010 | Kenmore Refrigerators
FRIDGE IS NOT COOLING
hello,
Step 4 – Volt Test
Good luck.....
Aug 14, 2010 | Frigidaire Refrigerators
I have a Maytag top refrig. not cooling. electronic dual cool, modle #MF2560HES.
Step 4 – Volt Test
hope this helpout........
Aug 12, 2010 | Maytag Refrigerators
Fridge not cool enough but frosty at the back
Since you are getting frost in you frost free refrigerator, tell me that the defrost circuit has a problem. It is made of a defrost timer/module, defrost heater and defrost thermostat. What should happen is that the defrost timer should periodically turn off the compressor for about 30 minutes and turn power to the defrost heater via the thermostat. The heater is attached to the evaporator coil and melts any frost build up on those coils.
It sounds like the defrost circuit has not been working for a while because the ice build up is not allowing the air to circulate around the coils to cool the refrigerator. The typical failures to the defrost circuit are the defrost timer motor fails to advance, or the defrost heater burns out. Hope this helps you.
Jul 14, 2010 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
398 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
