Question about Konica Minolta Dimage Scan Dual IV Film Scanner
Out of hard disk space
After scanning a slide in at 8bits using the duallauncher we get an "out of space error" . The program runs on C: drive with 17G of available space and the data drive has 35G of room. It used to run fine with even less available space. Could this possibly be a ram memory problem? Is there a workaround if it is mis-reading the harddrive space? My HP Pavilion pc runs W98 SE v4.10.2222a with 640mb ram. The manual only lists the minimum requirements which we easily meet. Removing unnecessary resident apps does not help. Thanks, Hal.
    President:
  • Konica Minolta Master
  • 2,022 Answers
Try to delete all temp file and reinstall your driver software disk may be your software is corrupted bcoz of that you geeting this error. bye
Posted on Oct 01, 2007
My computer is unresponsive or very slow nearly all the time now
When was the last time you ran disk clean up, scanned your pc for spyware and virus and finally defragmented the disks. Doing all three of these could have a big impact on the speed of it. Run all three in the order above.
Sep 30, 2013 | Microsoft Windows XP Home Edition
Tip
How to speed up your computer's performance?
<p><b>Information:</b><br /> <p>There are some few guidelines that you can follow to maintain your computer and keep it running smoothly. <br /> <p><b>Free Up Disk Space</b><br /> <p>By freeing disk space, you can improve the performance of your computer. The Disk Cleanup tool helps you free up space on your hard disk. The utility identifies files that you can safely delete, and then enables you to choose whether you want to delete some or all of the identified files.<br /> <p><b>Use Disk Cleanup to:</b><br /> <p>&bull; Remove temporary Internet files.<br />&bull; Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).<br />&bull; Empty the Recycle Bin.<br />&bull; Remove Windows temporary files.<br />&bull; Remove optional Windows components that you don't use.<br />&bull; Remove installed programs that you no longer use.<br /> <p> <br /> <p> <br /> <p><b>Tip:</b> Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.<br /> <p> <br /> <p><b>To use Disk Cleanup</b><br /> <p>1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Disk Cleanup. If several drives are available, you might be prompted to specify which drive you want to clean.<br /> <p> <br /> <p> <br /> <p>Disk Cleanup calculates the amount of space you will be able to free.<br /> <p>2. In the Disk Cleanup for dialog box, scroll through the content of the Files to delete list.<br /> <p> <br /> <p> <br /> <p>Choose the files that you want to delete.<br /> <p>3. Clear the check boxes for files that you don't want to delete, and then click OK.<br /> <p>4. When prompted to confirm that you want to delete the specified files, click Yes. <br /> <p>After a few minutes, the process completes and the Disk Cleanup dialog box closes, leaving your computer cleaner and performing better.<br /> <p> <br /> <p> <br /> <p><b>Speed Up Access to Data</b><br /> <p>Disk fragmentation slows the overall performance of your system. When files are fragmented, the computer must search the hard disk when the file is opened to piece it back together. The response time can be significantly longer.<br /> <p>Disk Defragmenter is a Windows utility that consolidates fragmented files and folders on your computer's hard disk so that each occupies a single space on the disk. With your files stored neatly end-to-end, without fragmentation, reading and writing to the disk speeds up.<br /> <p><b>Run Disk Defragmenter</b><br /> <p>In addition to running Disk Defragmenter at regular intervals, optimally monthly, certain events warrant running the utility outside of the monthly rule of thumb.<br /> <p>You should run Disk Defragmenter under the following circumstances:<br /> <p>&bull; You add a large number of files. <br />&bull; Your free disk space nears 15 percent. <br />&bull; You install new programs or a new version of Windows.<br /><br /> <p> <br /> <p><b>To use Disk Defragmenter:</b><br /> <p>1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Disk Defragmenter.<br /> <p> <br /> <p>Click Analyze to start the Disk Defragmenter.<br /> <p>2. In the Disk Defragmenter dialog box, click the drives that you want to defragment, and then click the Analyze button.<br /> <p>After the disk is analyzed, a dialog box appears, letting you know whether you should defragment the analyzed drives.<br /> <p><b>Tip:</b> You should analyze a volume before defragmenting it to get an estimate of how long the defragmentation process will take.<br /> <p>3. To defragment the selected drive or drives, click the Defragment button.<br /> <p>After the defragmentation is complete, Disk Defragmenter displays the results.<br /> <p>4. To display detailed information about the defragmented disk or partition, click View Report.<br /> <p>5. To close the View Report dialog box, click Close.<br /> <p>6. To close the Disk Defragmenter utility, click the Close button on the title bar of the window.<br /> <p><b>Detect and Repair Disk Errors</b><br /> <p>In addition to running Disk Cleanup and Disk Defragmenter to optimize the performance of your computer, you can check the integrity of the files stored on your hard disk by running the Error Checking utility.<br /> <p>As you use your hard drive, it can develop bad sectors. Bad sectors slow down hard disk performance and sometimes make data writing (such as file saving) difficult, or even impossible. The Error Checking utility scans the hard drive for bad sectors, and scans for file system errors to see whether certain files or folders are misplaced.<br /> <p>If you use your computer daily, you should try to run this utility weekly to help prevent data loss.<br /> <p><b>To run the Error Checking utility:</b><br /> <p><b>Important:</b> Be sure to close all files before running the Error-Checking utility.<br /> <p>1. Click Start, and then click My Computer.<br />2. In the My Computer window, right-click the hard disk you want to search for bad sectors, and then click Properties.<br />3. In the Properties dialog box, click the Tools tab.<br />4. Click the Check Now button.<br />5. In the Check Disk dialog box, select the Scan for and attempt recovery of bad sectors check box, and then click Start.<br /> <p> <br /> <p>In most circumstances, select Scan for and attempt recovery of bad sectors.<br /> <p>6. If bad sectors are found, choose to fix them.<br /> <p><b>Tip:</b> Only select the Automatically fix file system errors check box if you think that your disk contains bad sectors.<br /> <p> <br /> <p>Hope this will help...<br />
on Jan 17, 2011 | Computers & Internet
Tip
Information: There are some few guidelines that you can follow to maintain your computer and keep it running smoothly.
Free Up Disk Space
• Remove temporary Internet files.
• Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).
• Empty the Recycle Bin.
• Remove Windows temporary files.
• Remove optional Windows components that you don't use.
• Remove installed programs that you no longer use.
Tip: Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.
To use Disk Cleanup
• You add a large number of files.
• Your free disk space nears 15 percent.
• You install new programs or a new version of Windows.
Tip: You should analyze a volume before defragmenting it to get an estimate of how long the defragmentation process will take.
Important: Be sure to close all files before running the Error-Checking utility.
Tip: Only select the Automatically fix file system errors check box if you think that your disk contains bad sectors.
on Jul 05, 2010 | Computers & Internet
My pc is very slow
do a full scan of antivirus, if it doesnt help a fresh installation, if not then an upgrade is needed for the ram or processor for the performance !
Sep 30, 2013 | HP Pavilion Computers & Internet
Why is my lemon P7 is functioning too slow
your System may be slow due to following reason
- Too many programs running at startup or in the background
- Data Corruption, hard disk fragmentation
- Missing Windows updates or outdated drivers
- Not enough hard drive space, too many unused programs
- Left over programs, old cached and temporary files
So Follow these steps to fix computer problem::
- Delete all the temp files
- Remove unused programs
- install latest drivers from the manufacturer site
- Install and run antispyware software
- Free up wasted space with Disk Cleanup tool
- Defragment your hard disk drive
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of system slow
Sep 05, 2013 | Computers & Internet
Tip
5 ways to speed up your computer
By following a few simple guidelines, you can maintain your computer
and keep it running smoothly. This article discusses how to use the
tools available in Windows 7, Vista, and XP Service Pack 3 (SP3) to
more efficiently maintain your computer and safeguard your privacy when
you're online.
1. Free up disk spaceThe Disk Cleanup tool helps you free
up space on your hard disk to improve the performance of your computer.
The tool identifies files that you can safely delete, and then enables
files.
  • Remove Windows temporary files such as error reports.
  • Remove unused restore points and shadow copies from System Restore.
Tip:
2. Speed up access to dataDisk fragmentation slows the
Disk
When to run Disk Defragmenter
In addition to running Disk Defragmenter at regular intervals—monthly
is optimal—there are other times you should run it too, such as when:
  • Your free disk space totals 15 percent or less.
3. Detect and repair disk errorsIn addition to running Disk
If you use your computer daily, you should run this utility once a week to help prevent data loss.
Run the Error Checking utility:
  1. Close all open files.
  2. Click Start, and then click My Computer.
  3. In the My Computer window, right-click the hard disk you want to search for bad sectors, and then click Properties.
  4. In the Properties dialog box, click the Tools tab.
  5. Click the Check Now button.
  6. In the Check Disk dialog box (called Error-checking in Windows 7), select the Scan for and attempt recovery of bad sectors check box, and then click Start
  7. If bad sectors are found, choose to fix them.
Tip: Only select the "Automatically fix file system errors" check box if you think that your disk contains bad sectors.
4. Protect your computer against spywareSpyware
collects personal information without letting you know and without
asking for permission. From the Web sites you visit to usernames and
passwords, spyware can put you and your confidential information at
risk. In addition to privacy concerns, spyware can hamper your
computer's performance. To combat spyware, you might want to consider
using Microsoft Windows Defender, which is included in Windows, Alternatively, there are other free anti-spyware software programs available.
5. Learn all about ReadyBoostIf you're using Windows 7 or
Windows Vista, you can use ReadyBoost to speed up your system. A new
concept in adding memory to a system, it allows you to use non-volatile
flash memory—like a USB flash drive or a memory card—to improve
performance without having to add additional memory.
on Jan 01, 2010 | Computers & Internet
My computer is slow and lots of errors
install this http://www.malwarebytes.org/
and run full scan make sure you click the free one
Feb 18, 2013 | Dell Computers & Internet
On my Epson Scanner I get this error message: "There is not enough free space on the hard disk. Increase the amount of free space on the disk." I have over 40GB of free space on my hard drive. Do you...
1. Using the EPSON Scan software, edit the settings to see where the program is trying to save the file.
2. Might as well check what file type is the program currently is set to save.
Aug 24, 2010 | Epson Perfection 3490 PHOTO Flatbed...
How can i speed up my aircel internet on pc
5 ways to speed up your PCBy following a few simple guidelines, you can maintain your computer and keep it running smoothly. This article discusses how to use the tools available in Windows 7, Vista, and XP Service Pack 3 (SP3) to more efficiently maintain your computer and safeguard your privacy when you're online.
1. Free up disk spaceThe Disk Cleanup tool helps you free up space on your hard disk to improve the performance of your computer. The tool identifies files that you can safely delete, and then enables you to choose whether you want to delete some or all of the identified files.
2. Speed up access to dataDisk fragmentation slows the overall performance of your system. When files are fragmented, the computer must search the hard disk when the file is opened to piece it back together. The response time can be significantly longer.
In addition to running Disk Defragmenter at regular intervals—monthly is optimal—there are other times you should run it too, such as when:
3. Detect and repair disk errorsIn addition to running Disk Cleanup and Disk Defragmenter to optimize the performance of your computer, you can check the integrity of the files stored on your hard disk by running the Error Checking utility.
  6. In the Check Disk dialog box (called Error-checking in Windows 7), select the Scan for and attempt recovery of bad sectors check box, and then click Start.
    checkdisk.jpgExample of Check Disk Local Disk dialog box
4. Protect your computer against spywareSpyware collects personal information without letting you know and without asking for permission. From the Web sites you visit to usernames and passwords, spyware can put you and your confidential information at risk. In addition to privacy concerns, spyware can hamper your computer's performance. To combat spyware, you might want to consider using the PC safety scan from Windows Live OneCare. This scan is a free service and will help check for and remove viruses.
5. Learn all about ReadyBoostIf you're using Windows 7 or Windows Vista, you can use ReadyBoost to speed up your system. A new concept in adding memory to a system, it allows you to use non-volatile flash memory—like a USB flash drive or a memory card—to improve performance without having to add additional memory.
Jun 13, 2010 | Microsoft Windows XP Professional for PC
Konica Minolta Dimage Scan Dual IV Film Scanner Logo
94 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
George Mclaughlin
Clive
Clive
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
