Question about Canon Cameras
My Canon A510 batteries die out at a very fast rate after recharging. They are Ni-Mh batteries. Could this be a camera problem? I have purchased new batteries in the past and the problem still exists.
  • Canon Master
  • 4,738 Answers
See the following advisory for the Canon A530/A540. Pay close attention to the exposed battery door spring in the picture. The A510 has a similar possibility of the spring slipping out from under the plate, thus shorting the batteries. If it did, you can easily fix it by removing the three screws on the plate, and readjusting the plate so that the spring is again underneath the plate where it belongs. Or use a small piece of tape between the plate and spring to prevent it from shorting on the plate.
If the spring is NOT exposed, how old are your NiMH batteries? They really aren't meant to last more than a year or two. Also, Alkaline batteries are just eaten alive by the A510, so don't recommend using them as a benchmark to judge performance.
Posted on Nov 01, 2008
I have a Fuji A170 digicam. I use UNIROSS rechargeable Ni-Mh batteries. My problem is after inserting 2 fully charged batteries, the power drains off after clicking only 8-10 photos. Pls help.
Digital cameras are famously demanding on batteries, and the early Fuji ones were notorious. Ni-MH rechargeables are definitely the way to go, but you don't mention the capacity rating of the rechargeables you are using.
NiMH batteries with a capacity of 2700mAH or more are available, and these will obviously last longer per charge than those rated 1600mAH or so. However, all things come to an end, and while Ni-MH cells are supposed to be rechargeable hundreds of times under ideal conditions, in real life they will lose a bit of capacity every time until they become a bit short of puff.
Nov 10, 2010 | FUJIFILM A170 Digital Camera
What kind of rechargeable battery goes in the Kodak Easyshare Z710?
Z710 can use:
KODAK Rechargeable Ni-MH Batteries (AA Size): These Ni-MH AA batteries last up to twice as long as alkaline batteries when used in your KODAK Digital Camera and KODAK EASYSHARE Ni-MH Rechargeable Battery Pack: Provides exceptional capacity with its 2.5 hour fast charge cycle time; can be recharged up to 1000 times in the EasyShare Camera Dock or EasyShare Rapid Charger.
For more information on your camera plese follow this link:
http://www.kodak.com/global/en/service/products/ekn032171.jhtml?pq-path=9374
Dec 17, 2009 | Kodak EasyShare Z710 Digital Camera
The batteries die in less than 45 min
you didn't put what type of battery you used.
Well What can i recommend is that you need to purchased the recommended battery for the camera AA NI-MH or the KAA2HR type of rechargeable battery, Now if you don't want to use a rechargeable battery you may try to use kodak Oxy alakaline battery.
Nov 14, 2009 | Kodak Easyshare C813 Digital Camera
My camera just does not seem to hold a good battery charge. I use fully charged batteries and this also happens with Duarcell too. I am only using the camera in the "on" selection.
Some digital camera **** the life out of batteries, especially the older ones, even when off. It stores info like date and time etc. I take the batteries out when I am not using it for a while. True it is a pain resetting the time but it saves the batteries. Also go for the top line rechargebles,
Oct 30, 2009 | Kodak EasyShare C875 Digital Camera
Battery life of kodak easy share is 2 pictures ... if that
Please check what type of batteries are these.
Z1085 will only work with LITHIUM AA's, Lithium CRV3 (you have to make sure it's not Ni-mh crv3) and a rechargeable KLIC 8000 Lithium-ion battery pack (the blue one). It will not work with any other type of rechargeable battery but KLIC 8000. If you're trying to use ni-mh rechargeables, it will really not work.
Aug 23, 2009 | Kodak EasyShare One Digital Camera
How 2 charge a kodak with rechargable batteries!!!
get a charger for the rechargable batteries. Charge the batteries and then put them into the camera. You cant really chare the camera..
May 02, 2009 | Kodak EasyShare C613 Digital Camera
Batteries keep dying
hi
wat batteries are u using?
I have the same model, have been using rechargeable batteries as well as duracell. works good
dun buy those cheap batteries, $1.00 types, they are not enough to sustain the power requirement
Dec 04, 2008 | Canon PowerShot A720 IS Digital Camera
Cannot power on to take photos
I found that one has to use their batteries of at least 2100mAh and NI-MH. I recharged my batteries removed the new ordinary alkaline batteries I had put in and BINGO IT WORKED. Just to prove the point I put in another set of Alkaline batteries No good. It must be that NI-MH Batteries rated at 2100mAH have more power (or one can draw more currentat start up) a battery guru could maybe veryify my conclusions. Anyhow try NI-MH batteries and see how you go. Best of luck fredlich
Aug 15, 2008 | Sony Cyber-Shot DSC-P93 Digital Camera
Battery life expectancy
Olympus Ni-MH batteries will last approximately 60 to 80 images and can be recharged about 500 times. The Olympus CR-V3 long-life lithium batteries provide power up to 2 times that of Ni-MH batteries. The CR-V3 long-life lithium batteries are NOT rechargeable.
Aug 31, 2005 | Olympus D-460 Zoom Digital Camera
Battery
Aug 31, 2005 | Olympus D-400 Zoom Digital Camera
Cameras Logo
55 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
