Question about HP Computers & Internet
Recently changed to virgin broadband--when attempting to printing from internet only get computor data Can you help J Halliday
  • Puneet Jain
    Puneet Jain May 11, 2010
    Check out the Printer settings to be defaults.
    May be some confliction with the Broadband and Printer, if both are connected via USB.
    Let me know about the Operating system with Service pack and also about the connection for both.
  • 90 Answers
Check the printer setting selecting the background (embedded backgroud) in Option of printer properties.
Also try after resetting to defaults. If it is coming blank paper on online printing. otherwise, try to print a PDF file or already saved webpage and let me know.
Posted on Nov 01, 2008
Can I use Belkin 802.11g Wireless G Range Extender with virgin broadband?
This is a highly technical question. The technician that installs your fios can help you with an answer. If i'm not mistaken your new fios will come with a special router designed to change the data your recieving to acceptable format and communicate with your other devices. As I stated the tech who installs your fios can further instruct you as to the exact configuration. Hope this helps.
Sep 02, 2012 | Computers & Internet
My acer aspire laptop keeps losing the internet every couple of minutes and I have to disconnect and reconnect! It's so annoying, it even did it whilst writing this message! Everyone else in my house on...
AV U UDATED UR SYSTEM CHECK DEVICE MANAGER CLICK ON ACTIONS AT THE TOP SCAN FOR HARDWARE CHANGES ,RESTART UR SYSTEM ,SEE IF ANY CHANGE ,IF NOT WOULD SUGGEST SYSTEM RESTORE BEFORE U CONTACT VIRGIN ,HOPE OF SOME USE
Jan 08, 2011 | Acer Aspire 5536-5224 Notebook
I am with virgin broadband but to go onto the net i click on microsoft internet explorer which is provided by tesco. but how can i change this to virgin
tesco just put their logo on top of IE (I'm assuming you used to use tesco before virgin). you're still accessing through virgin now so should be no problem.
are you seeing any problems or is it just the annoyance of still seeing tesco in IE?
also what version of IE are you using?
Mar 29, 2009 | Microsoft Internet Explorer 7
Laptop finding router but no internet connection
If you can connect directly to your virgin Media Broadband and get internet then your laptop and broadband router is fine.
The wireless router appears not to have a DNS entry and you will need to add that manually.
I suggest that you connect directly to the Broadband modem, be sure you can get onto the internet. Once you have confirmed you can get onto the internet you need to get the dns information from your Broadband modem for later.
once connected directly to the broadband modem, click start>run> then type "CMD" then click open. you will get a prompt type the following and record the DNS Server ip addresses.
"ipconfig /all" then hit enter
this will display your ipaddress information but mostly you need the DNS server ip addresses.
once you have recorded them rerun the install, but this time instead of at the end of the install where it shows the Wireless router information you can modify or change it and add the DNS server entries.
Also by default most wireless routers ip address is 192.168.1.1 and you can type that from a internet explorer and change it from there as well. I believe it's no ID or user name and the password is admin.
Good luck
Jan 28, 2009 | NetGear WGR614 Wireless Router
11g wireless adsl modem router tew-435brm
virgin media is dsl not adsl which is the router you had
Nov 27, 2008 | Trendware TRENDnet TEW-435BRM 802.11g...
I have recently moved house from a virgin broadband connection taking my router and lap top with me. My new home has existing virgin broadband. Having plugged everything in as should be my laptop finds the...
Try reseating te broadband connection to the router.
It soundslike your router works if it connects to your laptop with a great signal. But its not sending any information through.
Try reseating. if it does not work. you might need to do a fresh reinstall of the router. Usually the broadband connections attach itself to a mac address of a network card. If you recently put a new router the network cards MAC address is different and it might not send signals through. like for me for cable i have the same issue.
Try this let me know how it does. If any problems please let me know.
I hope this helps
Please Rate.
Sep 18, 2008 | Belkin Computers & Internet
I cant get virgin netgear router to connect to my medion laptop, i get to the last part of the installation process when it says attempting to connect to newtork and it comes up move your connections...
Have you accessed and setup your wireless part of the modem?
To access the router settings menu, you will first need to log into the Wireless router following the steps below:
Open Internet Explorer
In the address bar type the following address:
192.168.0.1
You will be prompted to enter a Username and Password to access the interface, please use the following default details:
Username: This can be found on the bottom of the router
Password: This can be found on the bottom of the router
From the list on the left hand side, click on ‘Router Status’.
Within the Router Status section there are two areas you will be able to access:
Show Statistics
Connection Status
The Router Status page gives you a detailed status overview of the connection configured on the Wireless router.
Click ‘Connection Status’ to see more information on the broadband connection.
If you have already configured your broadband, you are able to establish/terminate the connection by clicking Connect/Disconnect.
You can also click ‘Show Statistics’ to show you current connection speed and more information on your Broadband connection.
Clicking on Basic Settings enables you to check all the Internet settings of your Broadband connection. Including the Login name (username) and password, IP address and type of connection.
Clicking on ‘Test’ will perform a standard check of your Internet connection and settings.
ADSL SETTINGS
The ‘ADSL Settings’ section provides you with some more information about your Internet connection. These are:
Multiplexing Method
VPI
VCI
WIRELESS SETTINGS
This section gives you full information regarding the Wireless connection. From here, you can change security settings, the SSID (Name) of the router and the access control list. Options list from:
Name(SSID) virgin broadband (default)
Region Europe(default)
Channel 11(default)
Mode g&b(default)
Enable Wireless Access point
Allow broadcast name
Security options (None, WEP and WPA)
- hope this helps
Jul 03, 2008 | Computers & Internet
Computers & Internet Logo
62 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
