Question about Ultra LCD30-500 Television
Turn on unit, no picture, no audio
Screen flashes on, can see intial script, then picture goes black and no audio.
  • mascyl Apr 01, 2009
    same, I get an initial split second pic of a logo nice and crisp then blank or black. This only happens when I turn it off then back on and then only sometimes.
I have the same make and model lcd t.v. and it too went black. It however is not the adapter. All you have to do is take off the back cover, after you remove the speakers and stand. Then once you get that removed you will see a shinny metal cover on the left side. You have to remove the three silver tiny screws, and remove that cover. you will see the inverter(it looks like a mother boared). Remove all the wire connections carefully, and don't forget the black one at the bottom. Once you have done that there are 3 more silver screws on the left of the inverter. Remove them also. Then the inverter can be removed. Take a knife and scrape the contacts where each wire plugs in. There are 2 in each one exept for the 2 on the right. Just gently scrape them, and look for any bent ones and if any are found straighten them. Then carefully put it back together and it will work like new. If the red light is on the bottom of the screen it means there is power to it. to your amasement it will work!!! If any questions please feel free to email me @ rborders32@yahoo.com
Posted on Feb 26, 2009
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV audio display is black; audio works fine. If I turn TV off and then back on the picture does display for a few secon
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
Sep 06, 2012 | Samsung Televison & Video
Sanyo model 42848
This could be a faulty back light lamp.It is located right at the back of the screen It is an cold cathode lamp supplied by a high voltage from inverter board .Inverter board has a input voltage of 24 volts inverted into 300 volts AC this lamp lights up the screen...
You need to open the back cover to check the lamp.....
Jun 06, 2012 | Televison & Video
TV is connected to cable; when we have a picture it is terrific. There are several times during the day when we have audio but screen is black. Unplugging and waiting an hour or more sometimes helps but...
Return it to Amazon.com.Get a replacement tv.This tv have problems with it 1 or 2 long LCD inverter boards,it dying going to be dead.That why u have only a flashes of a picture only a few second,than died,just black screen lelf and have sound.Or talk to Amazon.com customer serviced to get ur tv a warrenty repair.
Nov 14, 2010 | Sansui HDLCDVD325 32 in. LCD TV/DVD Combo
Picture blacks out but audio is still on.
Immirella, If you don't have extended warranty you will need to repair it yourself or contract out the work. This seems like (from your description
) that one or more of the units DC voltage sources on the "switch-mode-power-supply has failed and is now in partial shutdown mode. Yes, the unit still has operating voltage source for the digital, tuner, and audio circuits. You may or may not see an image on the screen if you hear audio and shine a very bright flashlight 1 inch from the lcd panel. You should pay a visit to YOUTUBE (just FYI) to check-out repair video clips of LCD monitors and LCD tv's. Your unit (FYI) is classed as BLACK SCREEN of DEATH. Same as any other brand of LCD monitor or tv. Call a local repair tech for more info. Good luck. 12fixlouie
Jan 30, 2010 | Proscan 32LA25Q 32 in. LCD TV
47in Phillips-tv picture goes black still has
Could be the signal board has a bad cap, in this case it sounds like you are getting intermitten power to the inverters....when the tv goes down and of course you have audio....Shine a flashlight on to screen and see if you have a picture...look carefully. If this is the case..you have the above problem!
Nov 23, 2009 | Televison & Video
65" Mitsubishi Projection Television keeps flashing black screen
check your closed caption, long time ago there were 4 cc options. Turn it completely off, that might get rid of it.
Jul 18, 2009 | Televison & Video
The monitor goes on but no picture. when i turn
RAM problem. Fix the RAM properly in the RAM slot.
May 07, 2009 | Olevia LT26HVX 26 in. LCD Television
When i take a picture with flash, the screen goes black and a red light flashes
after i take a picture on my nikon coolpix the screen goes black for about 30 seconds before you can take another picture.
Feb 10, 2008 | Nikon Coolpix S1 Digital Camera
Flashing light
this unit will have what is called ik protection wich means that the picture tubes are constantly monitor with this system all the way to the video procesor so the picture will desapear to a black screen even if the audio is ok,there may be a solution if contract a tech like me to adjust the bias so that compensates the drives to the pictures tubes since 1 or the 3 pt are week at this point.
Dec 25, 2007 | Sony KP61XBR200 TV
No picture on Westinghouse W32701 LCD Model
Screen goes black, sound unaffected. Can be remedied by turning off and immediately back on, but it will do it again and again and again.
Nov 11, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Televison & Video Logo
124 people viewed this question
Top Ultra Televison & Video Experts
Jaime Hernandez
Vernon Taylor
Are you an Ultra Televison and Video Expert? Answer questions, earn points and help others
