Question about Kitchen Ranges
Our aeg halogen hob is stuck on L and it doesn't matter what we do we can't take it off this setting.
  • Anonymous Mar 11, 2009
    My mother in law has the same problem!
You have accidently put on the child proof locking system!!
To remove press the lower right hand + sign and the - sign together for a few seconds.
Get an instruction manual on line to check out the various combinations for your hob
Posted on Jul 20, 2009
What products can I use to clean my aeg hg795540xb gas glass top hob? The instructions say neutral products and no hob scrapers
Please, follow this link:
http://www.amazon.co.uk/AEG-Electrolux-50296742005-Ceramic-Cleaning/dp/B002LJDJ7Y
25358477-ou0pu244fjwiiyewsm5u145c-2-0.jpg 6. CARE AND CLEANING WARNING!
Refer to Safety chapters.
6.1 General information
• Clean the hob after each use.
• Always use cookware with clean bottom.
• Scratches or dark stains on the surface have no effect on how the hob operates.
• Use a special cleaner applicable for the surface of the hob.
Dado
Jan 06, 2015 | AEG Ovens
Clean my aeg hg795540xb glass gas hob
Customer always needs to follow the manufacturer's instructions about cleaning and maintaining the appliance. If there are some ambiguities then you should contact an authorized service center. I personally believe that it is not a good idea to clean hob with steam cleaner.
6.3 Cleaning the hob
• Remove immediately: melted plastic,
plastic foil, and food with sugar. If not,
the dirt can cause damage to the hob.
• Remove when the hob is sufficiently
cool: limescale rings, water rings, fat
stains, shiny metallic discoloration.
Clean the hob with a moist cloth and
some detergent.
After cleaning, rub
the hob dry with a soft cloth.
• To clean the enamelled parts, cap
and crown, wash them with warm
soapy water and dry them carefully
before you put them back.
Dado
Dec 31, 2014 | AEG Dishwashers
I have only used my large oven three times and already the inside glass is brown. I have removed it but failed to clean it using all the regular cleaning materials. Can you suggest any way of cleaning...
Use a Stanley (or similar brand) window scraper. Hold it firmly and always flat against the glass and scrape that browm muck away. Be careful not to let the points on either side of the blade to dig in as this will scratch the glass.
This type of cleaning is carried out on ceramic/halogen hobs so is ok to use on interior slass oven doors.
Hope this helps
Jun 15, 2011 | AEG D2100-4 Electric Double Oven
I have dropped a cup onto my ceramic Zanussi hob, is the slither of glass that came off able to be repaired ??
Just to clarify something, is your hob above a double oven D2100-4 because that is only telling me about your oven the hob will have its own Mod. no. But any crack to the glass on any Hob can weaken the glass and really should not be used due to the weight of Pots on glass if the glass did break it could be quite dangerous with all the electrics below.
Hope this gives you some help in the matter.
Good Luck.
May 06, 2010 | AEG D2100-4 Electric Double Oven
Broken glass AEG hob
If it is just the edge of the corner glass not a lot you can do if it is broken nearer the inside be very careful as the weight of pans can cause the break to spread.Check serial no. on base of hob body the first 2 digits are the year and 3rd digit is weeks in year.For example 92800055 that would be 2009 and 28th week equals july 2009.Any AEG unit has 2years full warranty.Check and you might be able to claim new glass.Hope this helped.
May 05, 2010 | AEG D2100-4 Electric Double Oven
Aeg hob
It is child lock.
Turn cooker on, press two + at front of oven, this will then take it off for that cooking session.
To turn child lock off switch on hob, and touch - for 5 seconds.
Sep 29, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
AEG 5 burner gas hob
there is a bypass screw on each gas valve. adjust so flame is reasonable when each burner is turned to low
Jun 15, 2007 | AEG 34942G-M Gas Cooktop
Kitchen Ranges Logo
230 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
