Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
No agitation There is no agitation and water turns on and it emptys out into the drain help!!
    Problem Solver:
  • 7 Answers
Pump stopped up, something jammed either in the tub or agitatator preventing spinning
Posted on Apr 30, 2007
Washing machine stuck between wash and rinse.
first remove agitator by taking top of agitator off and putting your hand down the centre of it and unscrewing the wingnut holding the agitator to the main drive shaft. once the nut is loose pull the agitator out and bail the water out by hand using a pot or jug. once the bowl is empty u can look underneath. to the right hand side front of machine u will see a red or black fan that is attached to the pump. turn the fan clockwise and then anti clockwise and hopefully that will unjam the pump. the fan should turn freely. then put machine back on its feet.refit agitator. turn on unit select spin and it should start draining.if it doesnt reply back and i will help u more. please turn off power to unit b4 u work on it. good luck
Apr 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
It will fill with water empty but not spin or turn
If I understand correctly ... If fills with water and drains fine but it will not agitate or spin? This sounds like a broken belt or a bad motor. I would recommend that you call a service tech. Let me know if I can help in any other way.
Mar 18, 2010 | Hotpoint WMA40 Front Load Washer
Agitates but won't empty the water or spin
Clogged pump/pump filter, slowclogged drain, kinked hose/hose too high.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 02, 2010 | Kenmore Washing Machines
My washing machine overflowed and would not drain. When it is on water keeps coming in even though the machine is full iof water but there is no movement of the agitator and I could not get it to...
H i there.....sounds like you've got either a failed water inlet valve....or a disconnected /ruptured capillary hose from the pressure switch to the tub....or a failed pressure switch........turn water to appliance off.....turn program selector to drain or drain /spin..is drain pump running...if not it may be blocked or burned out....or with machine empty of water.....turn program to spin....if no spin...check motor....
regards Sir Galahad
Aug 21, 2009 | Washing Machines
Whirlpool model gsl9365ez2 / doesn't agitate or spin
Check your drive coupler, its located between the motor and transmission
Mar 19, 2009 | Whirlpool Washing Machines
Kenmore mod 110 agitator turns while water fills tub
Check your pump and drain for a blockage.
You also could have a timer connection issue. Remove the timer wire connectors and reattach them.The timer simply has a quick connection block, sometimes they get a little loose and all you gotta do is push it all the way back in. Check for a loose lid hinge and safety switch also.
Feb 09, 2009 | Kenmore 24032\24036 Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
No agitation
is this a whirlpool/kenmore top loader if so your drive coupler is broken
Dec 31, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
42 people viewed this question
Sal De
Marvin
Marvin
jimorris77
