Question about Danner Pond Pondmaster 500 Gph Mag - Drive Pump
Pondmaster Mag 3600gph pump
Pump suddenly stoipped working. took impeller assembly off to look for debrie none. still not working fish gulping!
  • 49 Answers
Is power to the pump insides; if the best thing is to re place it; I couldn't repair my same pump.
Posted on Nov 28, 2008
9.5 pump not working after running dry several hours by accident. Will replacing impeller make it work again?
Probably. As long as the motor is obviously turning and operating correctly. A dry impeller will burn up and lose it's seal along the interior of the pump housing.
May 24, 2011 | Pondmaster Impeller & Magnet for Pond -...
Pondmaster mdl 24 Series magnetic pump. re: Replacement impeller/magnetic shaft installation Question: What do I need to do to install the impeller ***'y into the pump housing to ALLIGN THE...
The bearing needs to be pressed onto the ceramic shaft before inserting the impeller into the housing. Then it just drops in (while trying to hold on to it the best you can to keep it from slamming in.). New bearings didn't come with the new impeller? If not you will have to carefully pry out the old bearing from inside the housing.
Aug 18, 2010 | Pondmaster Impeller & Magnet for Pond -...
Pondmaster 1200gph pump stopped working. Inside
Sounds like the impeller broke.
Just remove the 4 phillips head screws to remove the housing, then pull the impeller out. When replacing the impeller be sure to have a good grip on it as the magnetic attraction will pull it in pretty hard.
The pump may still be under warranty, if so call the number on this web page: You can also order parts from them.
http://www.dannermfg.com/contact.asp
Jul 08, 2010 | Pondmaster PM 1200gph Mag Pump Plastic...
LOW OUTPUT WATER PRESSURE
Pull the bottom strainer off and check to see if their is anything in the impeller.
Feb 14, 2010 | Pondmaster Mdwp30 - 3000 Mag - Drive...
My Pondmaster Mag 3600gph pump quit working too
welcome to pond life they rarely last more than 1 to 2 years
Jun 27, 2009 | Danner Pond Pondmaster 500 Gph Mag - Drive...
The pump does not work after power cycling
This is from Danner:
SERVICE AND MAINTENANCE
The housing should occasionally be removed to clean and inspect the impeller assembly. The impeller is the only serviceable item and can be pulled out of the body. If it is worn or broken the entire impeller assembly should be replaced. This will restore the pump to original capacity. Pumps taken out of service for an extended period with fluid inside run the risk of forming a crust which may prevent subsequent starting. Saltwater should be flushed out with fresh water.
IMPORTANT: FOR PUMPS USED IN SALTWATER OR HARDWATER.
Magnet impeller assembly must be removed approximately every 3 months for cleaning in white vinegar to remove accumulations of scale or calcium. Disassemble magnet from impeller by pulling them apart (it may take a strong pull). One end cap will come off. To clean the calcium scale off of the shaft and bearing inside the magnet soak in white vinegar for a few hours and scrape it off. Reassemble magnet/impeller assembly. Do not loose (sic) any washers located between end cap and impeller.
Hope this helps!
Bill
Jun 07, 2009 | Pondmaster Pond - Mag 18 Pump, 1800 Gph
Shaft fell out of Pondmaster 700 Gph pump.
DANNER MANUFACTURING, INC. 160 Oval Drive Islandia, N.Y. 11749-1489 Phone: (631) 234-5261 Fax: (631) 234-4778 e-mail: Sales@dannermfg.com
May 06, 2009 | Danner Pond Pondmaster 700 Gph Mag - Drive...
New pump not pumping
I can only imagine that something has jammed the magnet/impeller. take the screws off the volute and remove. Pull out the impeller assembly and inspect for possible source in magnet chamber and impeller housing. That is a very problem free model.
Mar 15, 2009 | Danner Pond Pondmaster 700 Gph Mag - Drive...
Pondmaster 250: Impeller or motor broke?
pondmaster 250 comes with a 3 year manufacturer warranty you should just exchange it for a new one. Overheating from low water sounds like the issue but as long as the shaft and housing are not scarred from debris they will replace without any questions
Nov 29, 2008 | Danner Pond Pondmaster 250 Gph Mag - Drive...
Danner Pond Pondmaster 500 Gph Mag - Drive Pump Logo
335 people viewed this question
Top Danner Garden Experts
Dennis Key
Dennis Key
john h
Are you a Danner Garden Expert? Answer questions, earn points and help others
