Question about Kenmore 23822 Top Load Washer
Kenmore Washer Model # 110.92582220
The washer stopped spinning mid cycle. Now it won't spin or agitate. There is some water in the bottom of the tub as well
    New Friend:
  • 3 Answers
I have this washer and it did the same thing. Turned out that it was the agitator mode switch -- the one for normal agitation, heavy duty and so on. The switch developed an open circuit, which stops the machine cold. I say forget the lid switch because this is a machine that agitates when the lid is open, gotta love it. I replaced the mode switch in about 15 minutes at a cost of about $30 or so and that was that.
Posted on Nov 13, 2012
Check rubber drive connector on yhe back of the motor or if machine is still full of water check lid switch.
Posted on Oct 31, 2008
dididsaythat
  • 291 Answers
SOURCE: Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Posted on Sep 03, 2007
  • 105 Answers
SOURCE: Kenmore 110 Series will not agitate, spin or drain but will fill
you may find that the motor is not going because of faulty capacitor or faulty timer
remove the motor from machine and try running with no loadif it works them maybe the pump is jammed or worse still gearbox is faulty
Posted on Jan 28, 2008
  • 351 Answers
SOURCE: Machine agitates but doesnt spin or pump out water
you will need lid switch 285671.. whirlpoolpartssurplus.com
Posted on Jun 24, 2009
  • 9 Answers
SOURCE: Kenmore 110.28922791-no agitation or spin
replace transmission
Posted on Oct 26, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore 90 series 11026912690, agitator makes loud noise
If the problem is just the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers (such as Kenmore) use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. These parts are commonly sold as part of their in-store inventory.
NOTE: Other causes can include a broken motor coupling, bad gearcase (transmission), or worn clutch assembly. It does not sound like the problem is associated with any of these components however.
If the motor coupling were bad, the washer would not spin at all (whether you held the agitator or not), but would still have the ability to drain.
If the gearcase (transmission) were bad, the washer would either not spin, or may spin with assistance (meaning, if you gave the drum a spin by hand to get it started).
If the clutch were bad, the symptoms would be similiar to that of the gearcase and the tub would probably also have problems stopping.
This problem sounds like it may only be associated with an agitator that could be loose, causing an off balance tub. Read through the information provided and let me know if you have any questions. I hope this is helpful to you.
Posted on May 28, 2010
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
Apr 21, 2012 | Kenmore Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Will agitate but won't spin leaving the water in the tub.
the transmission may have been damaged during the runaway.to much movement can cause it harm that is why they come with a shipping rod in them.
Aug 08, 2009 | Kenmore 22422 Top Load Washer
Stopped working mid cycle. The timer still counts down but does not fill, agitate, spin, drain. And before it stopped, the water that was draining out smelled really bad.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use quite hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 30, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Broken Washer
it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem. 0404472.jpg
worse case scenario is the transmission is bad, but this is unlikely.
Aug 04, 2008 | Kenmore 25862 Top Load Washer
Sep 02, 2007 | Kenmore 22422 Top Load Washer
Kenmore 23822 Top Load Washer Logo
224 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
