Question about ASUS P5N-E SLI Motherboard
Power cutting out
Was using my computer earlier. I moved case to the side to plug in head phones and the whole thing switched off.
Checked cables, turned it on, power supply and fans came on for a few seconds then off again. After a few tried all came on and it started up.
2 minutes later it turned off again.
Opened it, checked all cables, and turned on. Mother board made a low pitch beep (not normal one) the power supply and fans burred away happily, but the computer didn't start up/no signal to monitor.
Then I smelled burning.
Machine is less than a year old.
Power Supply - Antec neopower blue 650w modular
Motherboard - Asus Pn5-E (650i)
Graphics card - Zotac 8800GT 512
  • 94 Answers
Sound like processor has bit the dust, Attack supplier as you have on year warranty
Posted on Oct 31, 2008
Creative inspire 6100 no sound just humm
try replacing the audio output cable that feeds the speakers. the computer reads it plugged in by breaking the circuit when its empty. check the entire length of the cord for cuts and breaks, and check the plug ends. best test is using a multimeter and checking each section of the plugs for continuity.
Dec 16, 2014 | Creative Labs Inspire T6100 Computer...
No power in hp 1020 plus
I'm guessing you have checked the fuse in the plug top,so have you
checked the cable for a break in it, some times cable damage can
be caused by the silliest of things such as standing on it ,catching
it when hoovering or changing things around or maybe it got kinked
If you are not sure,try this, change the fuse with one from a working
appliance ie. a table lamp that way you know that fuse IS working,
now starting at where the cable enters the printer gently move the
cable up /down and side to side while watching and listening for lights
or sound , work your way along the length of the cable to the plug ..
Something else ,molded plugs can and do go wrongto fix this, cut the
plug of and fit a standard 13 amp plug,however check the fuse rating
in the old plug ,if it is a 3 or 5 amp fuse it is recomended you replace
it with the same size fuse as this protects your printer from damage ,
it does not give it more power lol. goodluck ...T.C.
Mar 31, 2013 | HP LaserJet 1020 Printer
Can I get a new mother board for my HP Pavilion Slimline s5120f computer, so I can reinstall my old hard drive with out losing my software.
Yes you can install a hard drive on any computer as long as it has the same power and data connections and plugs.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards If your current hard drive is on the fritz, or you have an older drive with data you need to retrieve, it's a fairly short process to swap out an existing drive with an old unit lying around the house. To replace the hard drive you need to be comfortable taking apart your computer and working inside its case. The hard drive is located in the series of metal drive bays located underneath the computer's side access panel.
Shut down your computer's operating system. Disconnect the power cable from the back of the computer case and unplug any other cables, such as for the monitor and mouse. Set the computer case gently on its side on a stable work area such as a desk or table. Check the far left end of the case to determine if the side access panel uses screws or a release button. Remove the two screws with a Phillips screwdriver, if they are present. Instead press in the plastic release button, if one is present. Push down the side panel and slide it off the computer. With some models you may need to instead lift the panel to the right until it locks at 90 degrees. Check the metal drive bays near the front end of the case and locate the one containing the rectangular metal hard drive. Unplug the data cable and the power cable from the ports on the back end of the hard drive. Remove the screws holding the hard drive to the metal drive bay. Set the screws aside in a container so they don't become lost. Grip the back of the current hard drive and slide it out of the drive bay. Slide the old hard drive you want to use into the drive bay, and ensure the power and data cable ports are facing into the computer's case. Plug the power and data cables you removed earlier into the corresponding ports on the back end of the old hard drive. Replace the screws removed earlier to hold the old hard drive to the metal drive bay. Replace the computer's side access panel and tighten the screws in place, if it used them. Reconnect the computer's power cable and the other cables you removed earlier. Press the computer's power button. Hope this helps.
b>
Dec 26, 2012 | Computers & Internet
What is the correct battery for the BIOS memory for a Gateway model 4025GZ notebook ?
http://cgi.ebay.com/GENUINE-ACER-250-REAL-TIME-CLOCK-RTC-CMOS-BATTERY-/250619795738?pt=Laptop_Batteries&hash=item3a5a1a991a
Method.
When your Gateway computer is switched off, it still keeps track of various system information such as the date and time, thanks to a small battery that never powers off. The size and thickness of a dime, the CMOS battery can run out and need to be replaced. You can swap out a dead CMOS battery with a new one by removing the Gateway computer's side access panel.
Difficulty: Moderate
Instructions Things You'll Need:
  • Phillips-head screwdriver
  • CMOS battery replacement
  1. 1
    Shut down the computer. Remove the power cable from the back of the computer case. Disconnect the cables for the monitor, mouse, keyboard, and printer.
  2. 2
    Set the computer case over on its side. Use the Phillips-head screwdriver to remove the two case screws at the far left end of the case.
  3. 3
    Slide the side access panel to the left and remove it from the computer case. Find the CMOS battery port, which will be located to the lower left of the processor in most Gateway computer models.
  4. 4
    Lift up the plastic clip holding the CMOS battery in place. Slide a fingernail under one side of the battery and lift it off the motherboard port.
  5. 5
    Check the orientation of the new battery and compare it to the CMOS motherboard port. Push the new battery into place in the same direction that the old battery was facing. Push down the plastic clip.
  6. 6
    Set the side access panel back onto the Gateway computer case and reattach the case screws. Plug in the Gateway computer and power it on.
Jan 01, 2011 | Gateway 4025GZ Notebook
My MX700 canon printer is flashing the on ff green light and the gold alarm light and say error code 6A80. My book says to unplug all power and the plug back in but it is doing the same thing. Thanks for...
The printer head has locked itself and won't move.
I have found a solution for you on the Internet - here are the details :-
I was able to unlock the print head - just with a small piece of foil.
Cut a 3-5cm wide stripe from a sheet of overhead-foil (90um thickness), move it below the print head, and move it to the front and upwards, to the back and upwards. Remove the foil. After switching the printer on - it will work as before and be able to move the head. No need to disassemble the whole MX700!
Leo.
Nov 21, 2010 | Canon PIXMA MX700 All-In-One InkJet...
How do i replace the switch on my system
Dear sir,
Welcome to Fixya
No worry ! I will help you!
According to you, your PC switch is faulty.I am right?
Before replacing switch,you have to confirm the problem is from switch side,or from any other side. To confirm this, remove side cover of your PC cabinet,search for front panel connections of mother board,check for loose contacts.If it is correct,remove power button jack from the board.Take one plat head screwdriver, short +ve and -ve ends of MBD frontpanel power ON switch terminals.If your PC starts normally, PC switch is faulty,you have to replace switch.If PC fails to switch on problem is not from switch side.
Steps To Replace PC power ON switch.
Remove both side covers of cabinet then,remove front glossy panel which is having power on switch. After removing glossy front panel,open the lock of power ON switch,then replace it with new switch.
I think it helps
If you have any problem regarding this issue leave a comment. We are happy to assist you,
Have a Nice Day!
Mar 27, 2010 | Gateway GT4022 PC Desktop
Right Phone out.
First check the cable, by moving it up and down. Especially around the jack plug. Breaks in the cable or jack are very common. If in doubt cut the ******** and fit a new one. If the break is higher up, you might need to replace the whole cable. In which case you will have to take off both headphone cushions and undo screws in each side. Then solder the new wire on.
Jan 26, 2010 | Sony MDR-V150 Professional Headphones
Can't get computer to see USB 2.0 BYTECC ME-350V3U2 when connected and powered on.
if you try it again and again, and the computer does not recognize it then go for a new one.
Oct 18, 2009 | Computers & Internet
Gatewaymodemfor20004dx2-66
More info please, laptop, desktop, cable-modem, or dial-up, brand of computer is usefull too. If cable modem, use a LAN cable(LOCAL AREA NETWORK) it looks similar to a phone cord, and plugs into the back of a desktop, or side of a laptop.
For more than 1 computer, you'll need a router of some kind.
Internal dial-up modems are a whole nother thing, if you need one of these you may want to take it somewhere and have a pro put it in, especially if its a laptop.
Dec 01, 2007 | VIA JKP11516e: 1U Rackmount 15" LCD...
No power
During moving the power connector which looks like a big telephone plug or a data plug may have been wrenched loose, from the internal connector, inside the plastic plug. Use the power plug from the other phone to test. There is no battery in the phone to charge. If changing the power adapter and plug fixes the problem have you telephone company check the connector or go to radio shack and buy a plug and a cheap tool to replace the plug.
Mar 08, 2007 | Polycom VoiceStation 100
ASUS P5N-E SLI Motherboard Logo
93 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
