Question about Water Heaters
Teledyne spa heater
The pilot light is on and it heated up to 70 degrees and will not go higher. Is it possible to test a thermostat
Check the High Limit Switch.
Posted on Jan 14, 2009
  • 104 Answers
Turn up t- sta 5 degrees and let it cycle. test with thermometer.repeat until proper setting is obtained ,good luck
Posted on Nov 02, 2008
My Rheem gas hot water heater thermostat is not working. Pilot is lit.
That's the next step. Make sure the flame sensor on the pilot assembly is in the blue part of the pilot flame. If it isn't the gas valve will not open the main burner.
Mar 24, 2018 | Rheem Water Heaters
The pilot light on the water heater went out and the red light is blinking four times on the thermostat (Honeywell WV8860B1317). How do I get this to stop so that the pilot light can be relit?
The flashing light 4 times indicates high water temperature has activated the over heat sensor, and that the only remedy is to replace the gas control valve/thermostat.
Dec 08, 2014 | Water Water Heaters
Water heater burner wont light
Problem is not thermocouple:
Thermocouple should be finger-tight plus 1/4 turn
Overtightening will short thermocouple against gas control valve, and solenoid switch will not open, and no gas will reach pilot once red button is released.
Tip of thermocouple has to sit in the pilot flame.
If pilot flame will stay on, then thermocouple is good.
Problem is not solenoid switch.
The gas control valve solenoid opens and closes gas supply to gas control valve.
On mechanical gas control valve, when you push down the red button to light pilot, then you are opening the solenoid and letting gas flow into gas control valve.
When heat is applied to thermocouple, a small electric current travels to gas control valve, and this causes solenoid to stay open.
If you extinguish pilot, then no current travels to gas control, and solenoid clicks off.
You can hear it click, and this is how you test it.
However, since you are getting gas to pilot light, then the solenoid is not the problem.
This leaves 4 possible problems:
1) Bad gas control valve thermostat.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
2) Inadequate gas pressure. Call gas company.
3) Dirty combustion parts. Clean the burner with wire brush and water.
4) Clogged air intake on FV water heaters: Rheem FV gas water heaters have glass vial that will break if combustion is slowed by clogged air intake.
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Oct 06, 2012 | Rheem 40 Gallon FVR NATGAS Water Heater 6...
The pilot will light but as soon as the button is released is goes out
1) If water heater has electronic gas control thermostat, then the gas control needs to be tested and possibly replaced. Add a comment and describe electronic gas control.
2) If water heater has non-electronic gas control thermostats, problem sounds like the thermocouple. Problem could also be bad gas control.
Make sure end of thermocouple sits in the pilot flame.
http://www.youtube.com/watch?v=v0aBPsNg6vo
Buy thermocouple at local hardware. They vary by length, for example 18".
Thermocouple screws into bottom of gas control thermostat.
Finger tight plus 1/4 turn. No pipe joint compound or teflon tape on threads.
http://waterheatertimer.org/images/IMG_9146-gas-control-thermo.jpg
Heat from pilot flame travels to gas control thermostat.
Heat is changed into small electric current using a thermistor.
The small current tells gas control that pilot flame is ON, and so gas control keeps gas flowing.
If thermocouple is not working, or has fallen away from pilot flame, the gas control turns off gas to pilot.
This safety device is necessary so gas does not fill up house and cause explosion.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Aug 22, 2011 | Water Heaters
Reliance 606 natural gas water heater - model #640YORT - water does not stay hot. pilot has to be clicked to heat and then u can use hot water til tank empty and it will not continue to heat water.
If I understand correctly, the pilot light is not staying lit.
You light the pilot and water in the tank reaches temperature.
Once hot water is gone, then pilot light has to be lit again.
Gas pressure is good, and gas is flowing.
Thermostat is working at high end because it cuts off heating.
Vent is working because tank heats up.
Air intake is working.
Gas control thermostat might not be reading low temperature. Replace gas control valve.
Pilot tube might be dirty. Clean burner parts and combustion chamber, and air intake, and vent.
Backdraft might be blowing out pilot. Check for constant updraft by running water heater 5 minutes, and then light match under vent hood and see if smoke goes up.
Very hot air can put out pilot, especially when water heater located in attic. Add ventilation.
Improper vent might have water dripping back down into combustion chamber and putting out pilot light and rusting out the parts. Inspect for rusted parts and water.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
Aug 09, 2011 | Reliance Natural Gas Water Heater Control
The water is not getting heated
If it is gas, check if the gas valve is open and the pilot light is on. If it is electric, check the thermostat on the electrorod, it should be around 120 degree. Good luck!
Aug 04, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
Pilot light will not stay lit on GE 40 gal. gas water heater tank
You have tank-type gas water heater:
Gas water heaters need working thermocouple, adequate incoming fresh combustion air with no trace amounts of chemical, open vent to outside that drafts poison combustion product upward, clean burner tubes and combustion parts, correct gas pressure with no air in line, working gas control valve thermostat, no lockout condition such as tripped ECO caused by runaway heating and dirty combustion parts, and no lockout condition such as exposure to flammable vapors.
Open following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
http://waterheatertimer.org/images/Test-water-heater-vent-1400.jpg
Jul 30, 2011 | General Electric Water Heaters
Water heater will not work unless i push reset button will work for 24 hours or so then will stop working and i have to go out and reset it
The reset button or ECO (emergency cut-off) is a safety device.
The ECO trips and cuts off power to entire water heater when it detects temperatures over 150 degrees.
This prevents overheating and eventual explosion of water heater.
The ECO will trip for 4 possible reasons:
1) Bad thermostat. Water temperature inside tank exceeds 150 degrees F because thermostat is sticking in ON position, and thermostat does not turn off element correctly.
2) Loose wire inside or near upper thermostat that causes ECO to sense higher temperature
3) Bad element shorted to ground near center of element, and short does not cause breaker to trip
4) Factory-installed insulation and cover are removed from water heater >>> cooler air causes thermostat to read wrong temperature, and thermostat keeps heating water inside tank
Steps you can take:
First thing is to check if factory-insulation-and-cover are present.
Next look for signs of burning at or near screw terminals. Tighten loose wire if found.
Especially check the lower element screw terminals.
Take a photograph of the parts so you can see the parts larger on your computer, and compare parts more easily when buying new parts.
Next most likely suspect are the thermostats.
For around $22, you can buy generic upper-and-lower thermostats at Lowes or hardware store > then replace the thermostat(s) and see if problem persists.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If problem continues after steps above
You will need to test water heater parts to track down the exact problem:
You need a inexpensive multimeter from Radio Shack, and the steps are simple, and you will know everything about an electric water heater afterward.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Answer back if you encounter something not covered above, and I will help.
Oct 25, 2010 | RELIANCE ELECTRIC WATER HEATER
Reliance gas water heater 640ycrs pilot light will not stay after 1 heat period replaced thermal couple has gas thermal switch
if water heater will heat a tank of water before the pilot light goes out you need to replce the gas thermostat
Mar 04, 2010 | Reliance & 30 Gal LP Gas Water Heater
Poilot light is on but furnace will not turn on.
check diverter at pilot chech for lint could be gas valve re-light pilot
Oct 11, 2009 | RTO Home Heating Products 5.5HH240...
Water Heaters Logo
52 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
