I've had a Parasound HCA-1000A 2 channel 125 watt amp for over a year now and
I noticed tonight, while playing my Blade DVD, that the "current overload" L&R
LED's are slightly lighting up. I wouldn't be able to notice it unless I
dimmed my lights in my room.
I have the amp hooked into my Onkyo receiver to power my two left and right
Paradigm speakers. All my speakers are calibrated to 75DB (via video
essentials test tone) using a Radio Shack meter. I do not exceed "normal"
volume levels when playing movies. I just tried my Fifth Element DVD and a
DTS CD and the same thing happens when I put my receivers volume at around
-15.
According to the manual it says if these LED's are lighting up, that my
speakers impedance is too low, resulting in too much current draw from the
amps power supply. My receiver works fine with my L&R speakers plugged
directly into it.
Do I have a defective amp here?
Thanks,
Jeff
Rating: 0%, 0 votes
loose and the light from the other two can be seen from the overload light.
Just I thought but my 1000A doesn't do that.
Scott
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
problem. He called Parasound and they told him it could be a problem with the
grounding plate. Anyway, he's ignoring it and I think I probably will as
well...For now anyway.
Jeff
In article <U8nA3.9344$vx.74 @news1.rdc1.bc.home.com>, majes @home.com
says...
Rating: 0%, 0 votes
ohm low effiency Maggies with no problems ever.
Rod
Visit my webpage at
http://community.webtv.net/ROD BUI/HIFIGUYSHOMEAUDIO for a look at my
system, links, and DIY projects, mods, and tweaks!
### UPDATED AUG.19/99 ###
Rating: 0%, 0 votes
Sounds like.
Growing reports of parasound reliability problems have been noted here
before.
Steve Zipser (Sunshine Stereo) is a proven:
Zipser is a liar http://dejanews.com/=dnc/getdo c.xp?AN=369217967
Zipser is a scammer http://dejanews.com/=dnc/getdo c.xp?AN=368363274
Zipser is a cheater http://dejanews.com/=dnc/getdo c.xp?AN=374900703
Zipser is a THIEF http://dejanews.com/=dnc/getdo c.xp?AN=509980240
Post a New problem for Parasound HCA-1000A 2-Channel
Email this problem
Can you Help with these Amplifiers and Preamps problems?
remote codes for sansui audio...
