Mouse broke on pc so brought another, and another, but same problem at the end.( found new hardware - unknown device. windows found driver software but encountered a problem installing it) hav now bought 4 mouses all with same outcome, am running windows vista, but using a very old packard bell ball mouse which didnt need drivers please can someone help
  • JDTec
    JDTec May 11, 2010
    There may be a problem with the PS2 mouse port. Did you try a USB mouse?
  • 53 Answers
Drivers required for mouse operation will be provided in windows itself so u can try connecting your mouse via USB port(except ball mounted mouse)better use optical mouse ...even after this if it is not working then you need to reinstall the OS.
thank you..
Posted on Nov 01, 2008
The Device Manager on Windows does not find my webcam. Instead it says Unknown Device. Any one have a fix for that?
You need to manually install the driver for the webcam, go here - HP ProBook 4520s Notebook PC and select your operating system, then expand the Driver - Keyboard, Mouse and Input Devices section and your webcam driver should be there, download and install it, and then restart and that should resolve your issue
Jan 26, 2015 | HEWLETT-PACKARD ProBook 4520s
Hardware changes might not have been detected for windows 7
make sure devices are compatible with win7 and make sure drivers are present and can be found by operating system. devices can be added in control panel - Add New Hardware. If you have yellow exclamation marks in device manager for that device or unknown device, go to properties, update driver, and supply path to driver files.
Dec 02, 2012 | HP PC Desktop
Welcome found new hardware wizard,this notice has been stuck on my computer windows internet explorer all day.
If you have just recently connected a new piece of hardware, such as a printer or external hard drive, you will need to run the new hardware wizard so the computer can connect to this new hardware properly. If you haven't installed any new hardware, read the wizard prompt to see which hardware it is talking about and then you can download/find the CD for the drivers accordingly.
If you would rather just ignore this problem, just hit the cancel button every time it comes up.
Jun 08, 2011 | Microsoft Computers & Internet
My USB and windows vista does not recognize my new optical mouse from GE SKU# is 98543, my motherboard is an ASUS M2N-MX SE, my other optical mouse works fine but when i plug the RF receiver into the usb...
first check the battery inside the mouse make sure it is fully charged and well seated
make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
also click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark !or question mark ? or a red x right you will have options to update driver software,disable,uninstall,scan for hardware changes and properties hope this helps
Apr 01, 2011 | ASUS M2N-MX Motherboard
Just bought this wireless keyboard and mouse...the shift button does not work
if you can provide more information about the keyboard make and whether you have installed the drivers or not.
Solution :
1. Right click on MY Computer or Computer and click on properties
2. Click on Device Manager ( Hardware )
3. from the list, click on + sign on keyboard
4. check if the keyboard name is listed / also check if there is no yellow exclamatory mark in the list as unknown device.
5. right click on the keyboard name ( wireless ) and click uninstall
6. Reboot the PC ( With the keyboard CD Driver disk in CD ROM )
7. Continue with the New Hardware found Screen to re-install the drivers for Wireless Keyboard / Mouse
Jun 16, 2010 | Rosewill (RKM800BLK) (AKMA8C35IBLACK)...
I have a Toshiba Tecra M8 and the touchpad stopped working. I can still use a USB mouse, but i've tried the FN F9 key to make sure that the touchpad is enabled but it still isn't working. Are there drivers...
Check in the device manager and see if the touchpad is listed under pointing devices.If it is not there try add hardware and see if it detects the hardware. If it is there check to see if it says device is working properly. Sometimes touchpads require software to operate properly so check and see if software was uninstalled. You can also download the drivers/software from Toshiba, try removing the touchpad in the device manager and then re-booting the computer. When windows re-boots it should start installing new hardware found. Use the driver/software you downloaded from Toshiba. If none of these work your touchpad may be bad.
Sep 05, 2009 | Toshiba Tecra® M8-ST3093 PC Notebook
Problem in bluetooth.
Please check whether you have all the drivers or not.
Click right mouse on my computer > Properties > Hardware > Device Manager
You would find yellow signs in front of unknown drivers.
In my case, SP32883 (Support Software for HP Integrated Bluetooth Module with Wireless Technology) worked for me.
Mar 31, 2009 | HP Compaq Presario V3000T Notebook
How to download vga driver
I will try to answer this one, but i don't know whether you are looking for drivers for a special card or you are searching for your motherboard on-board video drive.
case 1: on-board drivers can be found at the manufacturer's websites, in case you network is slow, you can use someone else's network. just go to the website, lookup support, lookup your hardware or motherboard model and the driver for the mobo, will fix chipset, audio, video issues.
case2: higher end graphic card such as nvidia or ati or intel can be found at the manufacturer's website also, or on the cd that came with the graphics card. in case we are talking about a laptop here, then you should go to the laptop's manufacturer and lookup your hardware. all manufacturer's usually have most drivers on their web page within a month of the release of that certian unit. Toshiba tend to take longer.
Case 3: which is more technical, in case you don't know who is the manufacturer of the actual part, go to device manager, find the unknown device or uninstalled device, right click on it, choose properties, detais tab, hardware id( i have actually seen people using software to get information that windows already offers. why buy "unknown device" and everest just for that) copy and paste that string on google and it will show you where the driver is, specially for intel based hardware. good luck hunting drivers.
Neim Le Legionaire.
Oct 19, 2008 | Balance CP4401 PC Desktop
I recently bought a HNC model CTGJD2028 3D Optical USB Plug and Play Mouse for my Compac Deskpro EN running XP Pro. Plugged mouse into usb port. Get a Popup Bubble – Found New Hardware – Mouse. Message...
UPDATE YOUR WINDOWS SOFTWARE FROM MICROSOFT OR YOUR VENDORS SITE, THERE MAY BE MORE SOFTWARE PATCHES FROM THE VENDOR TO FIX THAT TYPE OF PROBLEM
Aug 11, 2008 | Computers & Internet
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
