Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Receiver I read that people like myself have problems that their remotes dont work at a distance like they used to have and you have to get very close to the garage door for the remote to work. I read that the answers they give is interference, what about the receiver isnt that the likely problem to why people cant open the door from a distance????
  • 504 Answers
COULD BE A WEAK REMOTE BATTERY A BAD REMOTE OR A BAD RECEIVER.
YOU CAN BUY AN EXTERNAL UNIVERSAL RECEIVER. THAT CAN BE MOUNTED CLOSER TO THE DOOR AND IS CHEAPER THAN REPLACING THE CIRCUIT BOARD.
BUT REMEMBER, I HAVE SEEN A RV POWER INVERTER PARKED NEXT TO THE GARAGE STOP A NEW OPENER FROM WORKING AT A DISTANCE OF 5 FEET.
SO I ALWAYS SUGGEST TURNING OFF POWER TO EVERYTHING YOU CAN JUST AS A TEST.
HOPE THIS HELPS
Posted on May 29, 2010
BOSE LIFESTYLE TV SENSOR PROBLEM
Usually on any equipment with a remote---if you hold remote real close and it works you have either a dirty lens for the receiver or a defective infrared receiver in the unit-----odd that moving things would cause this.
If it is only the on/off function having a issue--that would rule out both of the possible solutions I suggested.
Be sure batteries are new/good and no indirect light is hitting front of unit where receiver is located.
May 18, 2012 | Audio Players & Recorders
I have dishnet with two TVs connected. The main one works fine no issues. The issue with the TV in the bedroom is that the remote control does not work well. The distance to the base is just a little...
Tries put somthings under the receiver box unit make it higher for a better signal ranges to receive the remote infer red signal to the box.
Mar 22, 2011 | Televison & Video
Remote start dont work in 2008 saturn vue and its not the batterys
The hood latch has a switch in it. The hood latch does not move the entire distance when the hood is closed and the switch does not close so remote start will not work. Everthing else appears to be OK. I have had two hood latch replacements on my 2008.
Nov 11, 2010 | 2008 Saturn VUE
TV does not detect remote control.
Remote control receiving sensor circuit problem in the TV. Mostly due to degradation of the sensor over a period of time.
Go close to the TV and see whether you get a response. If it responds try determining the distance back wards. If the remote works up to certain distance, the problem is weak sensor (TV).
If totally not operative it is sensor circuit problem. It could be sensor or it's associated parts.
May 24, 2010 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Remote will not work on #2 TV satilight
It could be the distance the remote is from the antenna. Try going to the receiver and pressing the guide button on said remote. Go back to TV 2 and see if it is up. If not go back to tv 1 and with TV1 ON AND TV1 REMOTE IN HAND press MENU-MENU. You will be able to see the remote addresses for the remotes toward the bottom of the page. With TV2 remote in hand press and hold the SAT button in the upper left of the remote until all buttons across the top illuminate. Now press in a two digit number between 2 and 15. Press the pound sign and the SAT button will flash thrice. Now press record a few times until you see the TV2 icon on the screen blink and the address is the same as you keyed. Exit out of the menu with TV1 remote. Go to tv 2 and try. You should be good to go. If your remote worked when you brought it close to the receiver you need to relocate the antenna on the back of the receiver to the room TV2 is in.
Thanks for using Fix Ya.
Feb 08, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Remote key sometimes works (low distance) sometimes not.
2001 Mercedes-Benz C240
Hello Dear,
today i tried to close the car using the remote all the doors closed but the rear right.
then i tried to close it manually.
when i tried to open the car all doors open but that rear right.
& the problem the door is not opening from inside or outside. even the window is not moving down also.
any help please cause tomorrow holiday & cant fix the car but if u helped me :)
Sep 22, 2009 | 2001 Mercedes-Benz C-Class
Antenna/distance
The receiver which is part of the logic board is going bad.
Jul 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Toshiba 32hfx71 / 36hfx71 remote control only sensing at one inch distance
Since the problem is common on two remotes, the source of your misery has to be inside your set, not with the remote. The receiver in the set may not be positioned as it should be since it is rare to have either end go 'a little bad.' They generally will fail totally instead. Any shop that services TVs will have a simple pen-like detector that will tell you if the remote is putting out enough signal to work as it should.
If your set has ever been repaired, the main board may not be sitting in the slots that act as supports.
You might try to hold the remote in several different positions; holding it below the IR window and pointing it upward, the same for each side and then above the window. If it seems to respond better from one or the other angle, then the receiver is not sitting square behind the window.
Oct 28, 2008 | Toshiba 32HFX71 32" TV
Door Remote
check to see if anything is blocking the beam that tells it something is in the way of the door closing. If there is nothing crossing the beam, make sure the beams are lined up properly. The four blinks are a safety feature so that you do not close the door on anyone or anything. Had the same problem myself once.
Jul 27, 2008 | Sears Craftsman LiftMaster Chamberlain...
TV and remote
Some suggestions: 1. Try fresh batteries in the remote. Weak batteries make it hard for the TV to see the signal from the remote. 2. Is there sunlight or ambient light hitting the TV on the infrared receiver (the part which sees the remote)? If so, it could be "blinding" the TV. 3. DO you have a ceiling fan which is casting a "flashing shadow" onto the TV? This can interfere with its ability to see the remote.
Mar 09, 2007 | Panasonic PV-DF2003 Triple Play 20 in....
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
122 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
