Question about Dishwashers
Foul odor coming from insinkerator disposal
We are a Homebuilder and install insinkerator disposals for our new homeowners. I have had 2 complaints from Homeowners that there is a bad odor coming from, their disposals. These complaints come from owners that bought Spec Homes that were about 2 yrs old.We have made several suggestions ranging from lemon peels, bleach, vinegar and baking soda. A Homeowner said today it sorta smelled like rust. How could this be? Please email me if you have suggestions or remedies
  • mvanwall Jan 01, 2009
    foul smell coming from disposal unit. Had dishwasher hoses all changed out. tech said he also cleaned out disposal unit. foul odor still there. plumber said it was not the drains. Help!!!!!! Insinkerator evolution compact.
  • TDLeGrand May 20, 2009
    We installed one of the more expensive Insinkerator disposals and have had the same odor issues.  We had a plumber check the drains, dishwasher hose, etc... and he said all looks well.  Not sure what else to do... :-?
I had an insinkerator Essential installed 2 years ago. It stinks all the time. I clean it and after a few uses it stinks again. I have had disposals in my homes for over 40 years and never had disposal odors, NEVER. I recently found the reason. The anti-vibration mounting ring at the top of the chamber is shaped in such a way that it is a natural food trap. Put your fingers just under/inside the steel mounting ring and curve them up toward the sink. There you will find a ridge about 3/8 inch deep that will be filled with old stinky food, gross.
I called insinkerator about the POOR DESIGN of this unit and they just didn't get it. They said I am the only person who has ever complained. They tried to troubleshoot the cause of the odor everywhere, even though I told them all about the large amount of stinky food I found trapped in the anti-vibration mounting ring. They were of no help at all. They agreed to send me a new replacement unit. I said OK, but the problem, and a new replacement unit will not fix it unless you have corrected this serious design flaw.
Posted on Jan 25, 2013
The only thing that should be used to clean a disposal is "Ice" anything else will / could cause several different problems. Run the water for about 10 seconds, turn the disposal on, put a few handfulls of ice down the drain, when the ice is gone, leave the water running for about 20 seconds. This both cleans the unit and sharpens the blades..
Posted on Dec 04, 2008
Leaking from bottom
Replace rusted garbage disposal:
Copy following link for troubleshoot walk-thru and tips installing new disposal, with manuals for each major brand:
Aug 17, 2013 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
In Sink Erator leaks half way down
1) Copy following link for troubleshoot and replacement tips.
2) Insinkerator usually has 5 year warranty.
If unit is leaking, then replace with new disposal.
Waste King disposals have longer warranty, but local hardware sells Insinkerator/Badger for less.
Jan 18, 2013 | Electrical Supplies
I have a brand new garbage disposer and was surprised that it was so quiet. I've been in homes with a disposer and they are noisy and the water and scraps get sucked down the drain quickly, but m
You're complaining that the garbage disposal is working quietly?
Most folks complain the opposite.
Look down opening and see if blade is spinning rapidly.
Check that disposal eats lettuce leaves and carrots.
Otherwise you have good disposal.
Nov 21, 2012 | Badger 5 All Insinkerator 76037h 1/2 Hp...
I installed a new dishwasher and now my insinkerator disposal has no power? What happened?
That is strange did you hard wire d/w or simply plug it in.did you trip the gfi.need more to go on.There is a reset on the bottom of disposal a red button push it it should click might need reset.
Apr 16, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
UNsermount sink with waste disposal
The easy mount disposal has a ring the (sort of) screws onto the insinkerator sink drain - the thing that is labeled insinkerator when you look down into the sink.
If this is a new install on a new sink, I recommend the EZ mount model. If there is already the sink drain (thing mentioned above) labeled insinkerator, you may be able to simply attach the new disposal to the existing drain ring.
Also: If you have a dishwasher to connect, this is a great time to install the "air gap valve" (available for almost free at any hardware store.)
May 05, 2009 | Dishwashers
Garbage disposal leak
Don to install a new one.
don't think it is a DYI and by the time you call for service it would be cheaper and use your DIY.
Hope this is a FixYa
Please rate the answer
Mar 23, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
New Badger 5 insinkerator garbage disposal just installed 3/4 hp
I would definitely return this item to the store and get a new one. Not a good sign. good luck
Jan 20, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Dishwashers Logo
2,528 people viewed this question
Top Dishwashers Experts
