Question about iLO 3200 32 in. LCD Television
How do I change to the front inputs to play video games w/o the remote?
We have no remote and cannot switch inputs.
  • twilder1174 Oct 31, 2008
    The 6 buttons on front are: Menu, 2 volumes, 2 channels, power. There is no selection in the menu screen to access input selection.
There should be a button on the frame of the TV that say's input. or Source, Press that button until you have the game showing on the screen. Make sure the game is turned on before you start changing inputs..
Posted on Oct 31, 2008
  • steve360 Oct 31, 2008
    If you already looked thru the Menu, and you have no options there for changing the input, then I'm afraid that your only option might be the MX-850 universal master remote. It has the codes for a LST32HA36 on that screen you have a choice for; input, sleep, freeze, favorite, colors red, blue, green, yellow, P-Mode, S-Mode, PIC and several other choices.. http://www.universalremote.com/product_d... sells between 250.00 and Retail 399.95 but you need a dealer to program it is the catch, software not available to public anymore.. Good luck..
Sanyo AVM-3259S TV is stuck on video2 remote is lost. How do change video input? Right now I can only play video games on it.
As the TV has no menu button on its front panel, you must have its remote control to select inputs.
Jul 22, 2013 | Sanyo AVM-3259S TV
To play videogames on an old tv PLEASE HELP
You'll need to switch the TV into Video mode. Most TV sets will have a button on the front panel labelled "input" or "tv/video," and pressing this button will cycle through the various inputs your TV has.
Alternatively, this button may be located on your remote control.
Rarely, no button exists, and video input is selected by changing the channel below channel 2; as if you were trying to select channel 1. This will select the video input on sets without a separate input selector button.
Dec 20, 2012 | Televison & Video
Trying to connect a Sega Genesis. I know it's connected properly to the place where the cable wire goes and then that is connected to the connector. What channel do I go to to play the games?
The input from the Sega wont be on any channel number - you need to select the correct input for the Sega using the "INPUT SELECT" button on the Symphonic remote control supplied with the TV. Switch on the TV the Sega, then press this button repeatedly until you can see the picture from the Sega.
- If you are using the sockets on the BACK of the TV, the correct input is "VIDEO 1"
- If you are using the sockets on the FRONT of the TV, the correct input is "VIDEO 2". You can also switch to the "VIDEO 2" input by pressing the "GAME" button on the Symphonic remote - if you still have it.
If you don't have the Symphonic remote, look for a button marked "INPUT" or "SOURCE" if you are using a universal remote.
If you don't have any remote for the TV, you will only be able to use the sockets on the front of the TV. You will then need to switch to "GAME MODE" by using the buttons on the front of the TV:
1. Switch ON the TV and the Sega;
2. Press the MENU button;
3. Press the VOLUME UP button to open the PICTURE MENU;
4. Highlight GAME MODE using the CHANNEL UP/DOWN buttons;
5. Set GAME MODE to "ON" using the VOLUME UP/DOWN buttons;
6. Press MENU again to close the menu
You should now be able to see the picture from the Sega. If not, check you have correctly connected the Sega to the TV. When you have finished using the Sega you will need to use the method above to switch game mode off again.
Hopefully, I've covered every possible angle. If you have a different Symphonic TV model from the one listed above (ST420FF), the method should be similar, but if you have any difficulty, please post back for further assistance.
BElectric.
Jan 16, 2011 | Symphonic ST420FF 20" TV
How do you put the tv in game mode without a remote
Follow the steps below to switch your TV to game mode without using the remote:
1. Connect the game system to the TV using the AUDIO/VIDEO inputs on the FRONT of the TV.
2. Switch the game system on.
3. Press the "MENU" button on the front of the TV
4. Use the "CH" UP/DOWN buttons on the TV to highlight the "PICTURE" option. This is the first option so should already be highlighted.
5. Press the "VOL UP" button to select this option
6. Use the "CH" UP/DOWN buttons on the TV to highlight the "GAME MODE" option. This is the first option so should already be highlighted.
7. Press the "VOL UP" button to change the GAME MODE setting to "ON"
The TV should automatically switch to GAME MODE if you are using the inputs on the front of the TV.
8. Press "MENU" to exit and play your games.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Dec 06, 2010 | Sylvania 6427FF TV
Hi, my RCA CRC311 BT turns on my Sharp television, changes the channels, etc, but it won't switch to video mode, even when I hit input. It is an old TV, but I used it to watch videos, dvds and play games...
Unfortunately you will not be able to switch input.
I also have a Sharp, I have tried 5 different universal remotes. None will switch input. I guess that function is not provided properly.
Sep 18, 2010 | RCA RCR311B Remote Control
I usually play video games on the rca 14 inch true flat tv but my remote broke that they gave me so i cant go to input to play video games. Do i need a new remote for that or can you do it a diffrent way...
Unless the set has front panel menu buttons and the on-screen menu allows you to select the source, the answer is "no, you can't switch without the remote". If the original remote is really broken, you may be able to use an RCA-brand universal replacement that has an "input" or "source" button. Unless the original is physically damaged, before you toss it check the battery contacts inside. They sometimes get loose from handling the remote a lot and don't make good connections. Also make sure the new batteries are fresh and facing the right way.
Apr 09, 2009 | RCA 14F512T 14" TV
Playing Games
It you plug your video games into one of the inputs in the back or the front, you need the original remote that switches between the video inputs. Most of the universal remotes does not have this function so your best bet is to order the correct remote from Hitachi or part store. You may try the Logitech universal remote which may have the video input selector but not sure.
Jan 19, 2009 | Hitachi 51F500 51" Rear Projection...
Rca tv model f35673mb - lost remote.... switch to video ???/
I asume your game systems and dvd player are hooked up via the rca inputs.So all you would need to do is purchase a universal remote,program it for your tvand press ch00 which should be the video input.make sure your dvd or game system is on so you know if you are on the right channel
Nov 09, 2008 | RCA F35673MB 35" TV
TV screen is frozen
Look for a button on the remote or front of the set that is labeled input (could be tv/video) this switches between video inputs and the tuner.
Oct 25, 2008 | Sanyo DS24205 24" TV
How do you play video games?
you will need to have a standard a/v cable or rf modulator the a/v will hook to the yellow/white jack on the front and you NEED the remote with the game button on it to switch to the game input on the front, otherwise buy a $20 stand alone modulator to plug your a/v cable into and tune to ch3.
Jul 08, 2007 | Sylvania 6413TD 13" TV
iLO 3200 32 in. LCD Television Logo
121 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
