Question about Frigidaire 11.6 cu. ft. / 328 liter Upright Freezer FFU12K1CW
Freezer is not running even the power receptacle is working
I plug the power cord of the freezer to the power receptacle which is hot. However the freezer is not running ( not sure if it is a fuse of somewhere failed or the compresser stop working). Please help me how to verify whcih one fails
    Novelist:
  • 124 Answers
There are no fuses on a domestic freezer that i have ever seen. there are no fans and there are no traditional freezer coils. so you have only a few things that could be going on. if the temp is way up the thermostat should sense hot and close and send power to the compressor and it should run. you can do one of two things . find the thermostat inside the freezer usually . gently remove cover and check incoming terminal and outgoing terminal. if you show 120 volts its open and the stats bad. if you don't show 120 volts between terminal connections then its closed and the compressor is failing to start. if power is coming into the stat when checked to ground then go to compressor and see if there are starting components . they are a start capacitor and a START RELAY AND PERHAPS A OVER LOAD . SEE IF POWER IS ARRIVING AT THE COMPRESSOR. IF SO CHECK THE MICROFARED OUTPUT OF THEcapacitor . you need within 10 percent of the rated value. also you can gently remove the overload , a little plastic disc and look on the bottom side and see if its cracked or burned looking. an amp probe on the compressor will tell you what amps it pulls if it trys to fire up . 6 to 10 is good 30 to 50 is mechanically locked up and then the overload trips. if compressor is ice cold to touch then your not getting power to the compressor and its not trying to run. if its hot to the touch thens its trying but start caps weak , or its locked up. most domestic freezers are not worth the cost of a new compresssor anymore. good luck
Posted on Oct 31, 2008
I have a Kenmore 5 cu ft freezer that won't come on. I've tested the power cord and that's not the problem. Where should I start looking?
Make sure that power is reaching the motor after going thru the thermostat.
If juice is there replace the starting capacitor. If the motor gets hot but still does not run the rotor might be frozen - check with ammeter for abnormal current draw.
If compressor is frozen all you can do is replace unit.
Jul 18, 2015 | Kenmore 5 cu. ft. / 142 liter Chest...
The fridge isn't getting cold. It has been close to 48 hours since I plugged it in.
You haven't said if you could hear the compressor running. If so then either the compressor is shot or there is a refrigerant leak. If it's not running it could be a bad cold control or the compressor starter. Oh and check to see that you have power at the receptacle that it's plugged into, I've been to calls of the refrigerator not working only to find out the it wasn't plugged in or the power was off at the receptacle.
Nov 02, 2013 | Midea HS-65LB Refrigerator
Burnt power cord
Is it burnt at the plug or near the box. It probably is old and worn out. I would replace it from the receptacle back to the box itself.
Feb 24, 2013 | Frigidaire 13 cu. ft. / 368 liter Chest...
The freezer is cold, but, ice is melting. Its running and the run and power lights are lit up. I removed ice(very little) around the top edge to make sure the door closes shut. It was just fine last n
All I can offer for advice is to ask if it is on an extension cord. Is the freezer plug in good shape and not blistered? Make sure that the cord is a heavy enough gauge to carry the current needed to run the compressor. An extension cord can break down over time and cause the compressor to overheat or fail. Wish I could be more help. Good luck!
May 02, 2012 | Magic Chef Chest Freezer MCCF5WBX
The light on my chest freezer will flicker on and off when I open the door. It will only remain on when the door is in a certain position. How do I fix this? Secondly, the red "on" light on...
Both light flickering probably indicates a problem with the plug or the cord. If it was just the inside light I would suspect the door switch, but both light would indicates an open short in the wires or plug.
Check the plug connection at the wall and see if it is loose. While unplugged check the cord for any nicks or cuts. Plug something else into the same wall receptacle , like a light and see if the power to the receptacle is ok.
If none of the above work then it is time for a qualified repair person.
J
Feb 20, 2018 | Woods Chest Freezer C1501W3
I have cut plug off to fit another type plug, how do I identify Neg & Pos wire
I dont recommend the refrigerator repair you are performing, as you are altering how it is designed to receive power. Furthermore, there is no negative and positive wiring on a 120 v A/C circuit, only hot and neutral. That being said, on a typical two wire cord, the hot lead is usually the ribbed side. On a three wire cord, the ground usually runs along the center.
Sep 28, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
Freezer not working
  • Make sure the freezer is plugged in
  • Check for a blown fuse or tripped circuit breaker
  • Test the power outlet for voltage
  • Inspect the electrical cord for damage
  • Eliminate use of an extension cord, if any is being used
  • Check the outage votageIf power is reaching the electrical outlet, trace the freezer wiring and test components as you go. Either there is a short, which must be located and repaired, or the freezer has sustained electrical damage.
Thanks.
Jun 26, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Plugged a new tumble dryer into an extension lead in garage with my lec fridge freezer and blew the fuse,brought new tumble dryer inside house and is working fine,lec fridge freezer in garage now showing a...
you have more than likely ruined the control board on the refrige,a dryer and refrigerator should each be on their own dedicated circuit,they use an enormous amount of current to start, and even if one is running and the other starts thats enough to trip even a 30 amp receptacle, and furthermore extension cord use on these types of appliances even a large gauge cord i.e. 12 ga. that will carry 20 amps is not even a good idea because of voltage drop,as this causes motors to draw excessive current and over heat the motors and reduce appliance efficiency too
Nov 09, 2009 | Freezers
Freezer's power is dead
check the plug itself may be melted. next check the cord itself at terminations inside the freezer compressor section. if it's plugged into a gfci try resetting the gfci receptacle. check breaker, may have tripped off.
Aug 20, 2007 | Whirlpool 17 cu. ft. / 481 liter Upright...
Frigidaire 11.6 cu. ft. / 328 liter Upright Freezer FFU12K1CW Logo
137 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
