Question about Nikon COOLPIX L4 Digital Camera
Won't turn on
Camera worked fine until 2 days ago won't turn on even with new batteries.Tried everything. Is this a common problem with this camera?.Please help!
    Problem Solver:
You can try to clean it out..you do this by following these steps: 1. Clean the inside of your camera by opening the back and then blowing the dust out with a can of compressed air, or with a bulb tool that blows air when you squeeze. 2. Clean the lens by blowing any dust off with compressed air. Use a special lens cleaner and lens cloth to thoroughly clean the surface. 3. Wet a cloth and wring out as much water as possible. Use this cloth to clean dirt off the camera casing, making sure no water seeps into the camera's interior. 4. Use a dry soft-bristle toothbrush to clean out the crevices of your camera's casing. 5. Rub dirty battery contacts with a pencil eraser. Although, this is not a common problem..if cleaning it out does not work you are better off going back to the store and either returning this item or demanding a repair service.
Posted on Feb 26, 2007
I have a Sony AX Digital 100 Camera. I used it yesterday and everything worked fine. Battery is fully charged. Tried to use it today and it won't start. I have taken the battery in and out and even...
Does there is something happened when you turn on the camera? If you can heard sound made by the len or the camera try to open but turn off in a second? If so, there is something wrong with the lens, and this how to fix camera lens error will be helpful. Else, if the camera are without any reaction you can check it the joint of the camera to battery is well.
May 20, 2011 | Cameras
Hi. I have a Canon G9 camera. I bought in October 8, 2007 but did not register the camera's warranty until a few days ago. Here's the problem. I dropped the camera a weeks ago... Everything was...
Hi Cacy,
I don't want to offend you, please don't take it that way, but since your problems began with the addition of the new battery... I have to ask the question. Are you absolutely sure you bought the right battery for your camera?
It takes a NB-2LH battery pack. If your sure you purchased the correct battery for the camera, and since you dropped it, I would check to make sure it seats properly in the camara and that it locks properly. Also the cover should close with a CLICK sound. If it doesn't then perhaps the battery is not locking in properly. Double check it and let me know if you still have problems.
Rob
Mar 09, 2009 | Cameras
Turns itself off every time I try to take a photo
I had a similar problem with my Cyber-shot S600. It just turned off every time I tried to take a photo. I bought a Sony recharger + batteries and it fixed the problem. Camera works fine and I'm impressed with the how long the batteries last between charges.
Jan 04, 2009 | Sony Cybershot S650 Digital Camera
Help
Wow, this is trully amazing. I went to do a search on why my camera wouldnt turn on the past couple of days, even after i charged all THREE of my batteries and found similar complaints within the same time frame!! WOW. We need to get together and fight this, cause its suspect!!! I bought mine in Mass, anyone else?
Jun 30, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon Ixus 75 not charging
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
Mar 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Flash
i think the firmware is corrupted ..... you must install new firmware ....
just visit the nearby showroom or technician he will install the new firmware ..........
for installing firmware it may costs some 300 to 400 bugs ....
how ever there may be other problems too may be the battery is dead just change battery and check....
check whether it is detecting in pc or not..........
Feb 11, 2008 | Cameras
HP Photosmart M425
camara has been working fine till yesterday, poewer won't turn on, to take pictures, but it turns on when i moved the tab to brouse pictures, bur when I switched it back power won't work
Oct 29, 2007 | Fuji FinePix E550 Digital Camera
Camera won't turn ON
First off, everything was not fine until this morning. You had this occur a month ago. Frankly, I would have done exactly as you did a month ago and nothing more. I have seen too many electrical problems permanently solved by turning a device off and then on, or by rebooting. Here is what I would generally recommend: 1. See what the camera manual suggests. 2. Charge the batteries fully before using them. New ones are often not charged up. They could have been in a warehouse for months. 3. The electrical contacts on your camera, the ones that interface with the batteries, may be a little corroded. If you can access them easily, try cleaning them with the eraser on the end of a pencil. Same with the batteries themselves. 4. If exposed to prolonged high humidity, electrical problems may include not only the power supply, but other electrical switches, such as the reset button., which you cannot address on your own. 5. Call Sony.
Sep 13, 2005 | Sony Cyber-Shot DSC-P52 Digital Camera
Nikon COOLPIX L4 Digital Camera Logo
82 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
