How do I connect my laptop to my home theatre system?
How do i connect to listen to songs? The home theatre system has a USB port.
  • 1 more comment
  • kanee Feb 27, 2009
    i want to connect 5.1 home theatre to laptop, home theatre have 6 jacks and laptop have only one jack, how do i connect?
  • larink Mar 02, 2009
    I have HP Pavillion DV5 and Phillips DVP 2000 Home Theater System
  • rohandhanraj Apr 10, 2009
    Using the adapter which splits the headphone jack into two phono will only make 2 speakers work. How do we get the 5.1 to work?
The best idea would be to get an audio interface, providing that your home theatre has an IN such as left and right phono. hese can be found for around 60 GBP. A chaeper alternative would be to buy and adapter which splits headphone to phono although an audio interface would allow you to send sound from you theatre in to your laptop as well.
Posted on Nov 01, 2008
You can purchase converter single jack to 5.1. its available at electronic show rooms.....in hyderabad anand bazar we get that.........
Posted on Jul 30, 2009
Getting sound to TV from DVD Home Theatre System
lght304su home cinema,how to connect to tv to get sound through
Dec 29, 2009 | Sony DAV-SR2 System
I have F&D home theatre i want to connect it to laptop
go to radio shack or walmart . get a cable that has an 1/8th inch stereo plug on one end and two (male) rca plugs on the other end.
make sure your volume is not all the way up on either the computer or the stereo.
plug the 1/8 inch plug into your "speaker or headphone" jack on the laptop.
plug the red and white (male) rca plugs into the auxilary or cd "IN" on the home theatre.
Power up the stereo, make your source on the home theatre the Auxilary or CD, whichever you used to plug the RCA's into.
now you should hear anything from the laptop through the home theatre.
Regards..
Apr 25, 2009 | Creative Labs Sound Blaster Live! 5.1...
I want to hookup my laptop with my 7.1 Onkyo HTR540 home theatre, onkyo has optical input, i am confused how to hookup with my laptop which also has HDMI port but my home theatre does not have HDMI Port
If you have a plasma, or otherwise HDTV display, what you would do is send you information in two different directions.
Connect the video directly to the display. Connect the audio through your home theater, and set both units accordingly.
Apr 11, 2009 | Audio Players & Recorders
Multiple game systems through home theatre
what you need to do is hook all of your gaming systems into the "in ports" on your gameing switch, then hook the set of cables you want to use to the "out port" then the other end of those cables need to go to the "in port" on the home theatre system (you can pick which in port you would like to use, it should say which is which on the back by the ports) after doing this you need to find the out port on the home theatre system that corresponds with the cables you are using ie, rca component or hdmi. once you find that port you need to hook a cable to that into your 'in port" on your tv., lastly turn on all of your gaming systems, your tv and your home theatre system. and on your home theatre system select which ever port you hooked the gaming switch into, then turn your tv to the correct channel that you hooked the cables into the tv, lastly go through each swithc on your gaming switch to be sure that they all work, if not, you might want to use all the same cables for all connections, ie, all component all rca or all hdmi, i prefer component.
Mar 29, 2009 | Philips MX6050D System
Connecting a psp to our unit?
The USB port is only compatible with flash memory drives and some card readers.
Jan 03, 2008 | Philips HTS-6500/37 System
Panasonic home Theatre
You need to obtain audio leads and connect from home theatre directly to audio input in back of tv - be careful as there are normally 2 in back of tv
Dec 14, 2007 | Panasonic SC-HT720 System
2,134 people viewed this question
 Grubhead
Grubhead
