Question about Audiovox VE705 7" Drop-Down LCD TV with AM/FM Tuner Replaces VE700 Television
Setting TV stations on audiovox VE705
I bought a used unit and can't get more than one station. When I try to get it to stop at a station, it won't. It just keeps going.
3 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: Stops receiving signals
Make sure that your antenna is in a line of sight such as a window. I know Sirius works in an Easterly direction for line of sight but I think XM works in a Westerly direction for line of sight.
The system has a buffer in it so it can take 5-10 minutes to lose the signal if it does. Keep an eye on the meter.
Posted on Aug 26, 2008
  • 6771 Answers
SOURCE: Audiovox CE-500S tuner issues
Check to make sure your antenna properly extended, add a wire to the terminal or rod to bring up the gain, sometimes the tuner becomes dirty and causes a loud raspy sound, if that is the case buy electronic tuner spray, take unit apart! you should see a square plastic container with screws and tuning plates, spray into holes where the screws are, tune back and forth a few times, and repeat. Tuning will drift for sometime until compound dries.
Posted on Mar 05, 2012
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
No picture 9" VE927 LCD Drop Down TV
I went through the manual.........
Take pg no: 30 of this manual www.retrevo.com/support/Audiovox-VE927-TVs-manual/id/3068dj099/t/2/
In this manual it is given if there is no picture : The region number of the disc doesn't match the region number of this unit.
Please read this manual and i hope it will solve your problem......
Oct 06, 2008 | Audiovox VE927 9 in. Portable TV
Display station not showing outside temperature
Check battery status indicator on main weather station of remote unit. If no indication, replace battery in remote unit. If battery is good then check "channel setting" of remote unit to make sure the channel setting on remote unit matches the "channel" setting on main unit. many weather stations will take up to 3 or 4 remote units and they must use different channels to relay the remote imfo to the main weather station unit.
Jun 19, 2015 | Measuring Tools & Sensors
I just bought a nu tec tv and it won't tune into any stations please help
T uner of signal module needs replace. Check and see if you have signal going to your video input.
Apr 09, 2012 | Televison & Video
I just bought the RCA CD/DVD home theater system RTD206. I cant figure out how to change the radio channels. Also cant figure out how to change the cd disk tracks. Does this system have a remote. Or do...
The system does have a remote (at least it should come with one if purchased new), and you need it to control pretty much everything. Here's what the manual says about the radio tuner (you can find the whole manual here) :
Manual Tuning
1. Connect the FM aerial and the AM loop antenna at the back of the unit. Rotate the AM loop for
better reception.
2. Press TUNER to enter TUNER mode and toggle between FM and AM.
3. When the FM station broadcasts Stereo sound, ST is displayed.
4. Tune a station by pressing repeatedly the TUNER+/- buttons until the desired station is found.
Alternatively, you can press and hold the same buttons down for about one second to activate
the automatic search function. In this mode the player will automatically tune frequencies until
it finds a station.
5. Repeat step 4 to tune to another radio station.
Storing radio stations
The player can store up to 30 radio stations in its memory. You can enter every single radio station
yourself or the player can store all available radio stations automatically in ascending order.
Automatic preset programming
1. Press TUNER to enter the Tuner mode.
2. Press and hold TUNER down for 3 seconds to start automatic preset programming.
Note: A weak signal can affect the "Automatic preset programming" function's efficiency. Adjust the aerial for better
reception and a more efficient search.
3. Radio frequencies will be browsed and radio stations stored automaitcally. When all the available
radio stations are stored or all 30 memory locations are full, the auto preset programming
function will stop.
Manual preset
1. Tune to a radio station (see "Manual tuning" for details).
2. Press MEMORY once to enter flashing Preset Loaction number.
3. While the Preset Location number is still flashing, input your desired preset number (1-30) using
the numeric buttons or press the CH+/- buttons, then press MEMORY to store it.
Retrieving preset stations
2. Press CH+/- to search up or down for the preset stations or directly press the numeric buttons.
As you see, you really need that remote. The same is true for disc play. While there are front panel buttons for play/stop, disc skip, and drawer open/close, you don't have any other control without the remote. Without the remote control you'll find this system won't do too much, unfortunately. If you bought this new, check the packing material before you throw it away to make sure the remote's not still somewhere in the box. They often come tucked into slots on the foam inserts.
Also, when you hook the unit to a TV, it's just using the TV as a video display device. The TV has nothing to do with any of the system's other functions.
I hope you have luck locating the remote! Thanks for using Fixya.
Jun 29, 2011 | Audio Players & Recorders
I get a picture but no sound. I bought the car with the dvd player already installed but no directions.
Hopefully you have a remote control for this unit. There is a FM select button. It's to turn on the FM modulator. When you press the button it will select different radio stations on the FM band. Once you select a station on the DVD, tune your vehicle radio station to the same and you will be able to hear the sound. Use this system to select the station with the best reception and less interference.
If no remote is available, there may be a FM button on the DVD player to perform the same function.
May 05, 2011 | Audiovox VOD102 Car DVD Player
Having problems gettin sky channels through archos i get to setting infrared settings and can not get code.dont know wether to connect dvr t the tv or the sky box
Remove the DVR station from the box, and attach the DVR adapter plate (found in the
DEVICE box); it is correctly attached when it clicks on.
-Take the Black Audio/video Marked "output" cable, and insert the connections into the corresponding coloured sockets, yellow>yellow, green> green etc. Make sure they are
inserted into the TOP row on the back of the DVR Station "Marked Out". The remaining
black connector should be plugged into the SW socket, which can be found underneath
the orange socket on the back of the DVR station. (If after setting up your ARCHOS the
picture is very green remove the black cable from the SW socket)
-Plug the SCART connector into the SCART socket on your TV set. These are usually
marked AV1, AV2, or Ext 1, Ext 2, L1, L2, Line in 1, Line in 2, Aux 1, Aux 2, make sure you
select the corresponding channel above (ie AV1 AV2 etc) on your TV set when you turn on
the TV.
-Attach the UK plug adapter to the Mains charger, and plug the charger into the DC-In
socket on the back right of the DVR station. Turn the mains on at the socket.
-Insert the powered off ARCHOS unit onto the DVR station, the unit will now power on,
and ask if you want to 'Switch to TV out', select 'Okay'. The 'TV output configuration' set
up will load up. Select 'Okay'.
-TV connection: When your DEVICE is connected to the optional DVR Station you need to
select the type of video output (Composite, S-video, component, RGB, HDMI etc), based
on how you have connected the DVR Station to your TV and what possibilities your TV will
allow. For the cables supplied and the instructions aboce you will need to select either
RGB or Composite. Use the arrows to go through the options and select either RGB or
Composite.
-TV Standard: this should be set to PAL (Europe). Select 'Next'.
-Now you need to test the settings, select 'Okay', the ARCHOS home screen should now
be visible on your TV set. If you have nothing showing on your TV, scroll through the
AV/Ext channels, the channel will correspond to the AV/Ext socket you connected the
cable to on your TV set. Use the ARCHOS remote to select 'Okay'; you have now set up
the output connection settings for your DVR station.
-You may need to adjust your output from the ARCHOS to match your TV, from the "TV
Format" options. Use the arrows on the ARCHOS remote to select the format of your TV
screen, so the ARCHOS unit outputs the correct picture size (ie 4:3 / 16:9 etc). Use the
arrows on the remote to select 'Next'.
Dec 24, 2010 | Archos 605 WiFi Digital Media Player
Setting up fav stations
seek to the station you want and hold down the preset button you want that specific station set to.
for ex: seek to 101.3fm and hold down the number 1 preset button for about 5 sec.
May 11, 2008 | Pioneer DEH-445
Wacs700
From HDD mode on the centre, press menu and select "Station Management".
If the option is available select "Delete Station" and delete any stations listed.
Select "Add New Station" and the unit will start searching.
On the station press menu and select "installation mode"
If this option is not available, try from another source setting, such as AUX.
Once the centre has found the station, press stop on the centre, as the station cannot connect until the centre has stopped searching.
If this doesn't work, you will have to reset both units to factory settings and start again.(Menu -----> Settings ------> Restore)
Feb 23, 2008 | Philips WACS700 Shelf System
Setting my preferred stations
you need to select your station then press the preset button then 1 thru 0 to store the station. repeat for the rest of yoiure stations you want to store.
Jan 08, 2008 | Audiovox XCS9 XM Radio Receiver
Televison & Video Logo
37 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
