Due to moving I had not used my McIntosh audio equipment for several months. Was working fine before. Now hooked up as before but no sound out of speakers. PreAmp C-32. Gets power, can hear with headphone plug in. Speaker Control Relay SCR 2. Hear a single clicking sound (as before) when power turned off or on. Amplifier MC 2205. Both blue light panels come on when powered up. No needle movement or sound from speakers when music source turned on. I do hear the music when headphones plugged into preamp headphone plug. No sound when headphhone plugged into amp headphone plug. Have triple checked all connections. Any ideas as to problem in relay switch or amplifier? Easiest way to check would be most appreciated.
  • gtbasinger Nov 01, 2008
    Yep, found a loose wire. thanks, jer
  • 905 Answers
If there is no headphone sound on the amp then there may not be no sound input to the preamp inside the amp , first make sure the the switch that changes the speaker set up , like A set , B set , and make sure thats not the problem , then if thats not it you will have to make sure the preamp output is good ( hook it up to another input and or another source )
if that is good then the problem lays in the power amp , try , unhooking inputs , turn off amp , unplug it from the wall for a min. then plug it in and turn it on wait for the click then plug in the inputs ( if the output of the preamp is good
if this all fails to work it will need to be tested and components checked to determine what the problem is exactly
electech
Posted on Oct 31, 2008
  • jason Oct 31, 2008
    and it might be this preamp transistor on the preamp or the amp
    Brigadier General:
  • 3,614 Answers
Well if you find problem on your amp. it is better to re check again the audio input / output connections could be a loose connections or you got a wrong connection. or try testing iton the other speakers and check it alone.
  • micromaster
    micromaster Nov 01, 2008
    kindly rate my solution as fixya, once the info fix the problem.
    thanks
    Genius:
  • 1,550 Answers
The problem lies in amplifier .
  • SAM ANDERSON Oct 31, 2008
    If you have any spare speakers (which is working ) connect to amplifier to check whether it is working properly .
Mitsubishi rear projection tv, model WS-48311 - Lost audio after moving tv and re-hooking up cables. How do I get it back?
It sounds like this TV is being used only for the PS3. We'll need to troubleshoot this through a process of elimination.
If you're using Component Input 1 and audio, try using Component Input 2 and audio instead. If this set of inputs provides working audio and video - you can stop. Or, try going back to Input 1 once more. If Input 1 now works - you may have simply made a better connection. If it doesn't - then there's probably an issue with input 1 on the TV.
If moving to Input 2 above still didn't solve the problem, you should try using a different set of audio cables between the HDFury and the TV. If it now works, the original audio cables are faulty.
You can check the HDfury setup on another HDTV with component inputs with it connected to an HDMI cable. if the HDFury wors, you know the device and all the cables work. If you do this test and it works with your PS3, then you know that the PS3 is providing good video and audio signals via HDMI. If the problem follows the PS3 - then it's the PS3 at fault. If everything works perfectly on the second TV, then there is some issue with the audio amplifier / inputs / speakers of the Mitsu TV. You could get a cheapo stereo amp and speakers - or a set of computer speakers for audio - it all depends on how much you want to spend for sound.
Good lcuk!
May 07, 2015 | Mitsubishi Televison & Video
Have a McIntosh MC602 used to drive two 4 ohm subwoofers. Worked perfectly until a close lightening strike took out several theater components. Even though it was turned off during the storm it was plugged...
it seems that the right channel is blown. the unit has no fuses inside, most likelly output transistors are gone. not easy fixable, you need to bring it to a repair shop. if you are in nj you may brong to ebcelectronics
Sep 12, 2011 | Mcintosh MC602 2-Channel Amplifier
McIntosh C-39 preamplifier will not power on. Over the last several months this problem has gotten progressively worse, from taking several tries with either the remote or physically pressing the power...
Is it plugged in directly to the wall or are you using a Uninterrupted Power Supply or Auto Voltage Regulator?
Check for any signs of overheating on the Capacitors and the IC's usually this intermittent shutdown can be caused by a faulty capacitor which cannot hold the electricity and thus causing the unit to shutdown.
Hope this helps!
Aug 14, 2011 | Audio Players & Recorders
I have a cable box connected to reciever and was working fine for months, now i get no picture on tv only sound. I use hdmi cable out to tv that also uses my ps3 to tv which is working fine. What...
I don't know what kind of TV you have and what kind of output capabilities you have but, while your receiver will transfer your video signal, it is not the ideal way to hook it up. The port you are using may have to be reset somehow or, may have gone bad. Ideally you want to hook all video componenets directly to TV then, use, digital optical is best, audio out from TV to receiver. If you have more than 1 input in to TV, you can run your PS3 and cable box directly to TV, using the TV's menu to select which you are using, then, run your audio out to receiver.
May 23, 2011 | Denon AVR-887
The right speaker produces almost no sound
This can happen due to several reasons.
You just check whether th wire got bend . It can happen due to that.
-rate if it helped you.
Apr 08, 2010 | Bose Companion 2 Series II Multimedia...
Equipment not turning on!???
Have you tried checking the remote wire yet? Because it could very possibly be that. Without a remote wire hooked up, you cannot get any power. Try that and see if it works.
Apr 29, 2009 | Alpine MRP-M500 Car Audio Amplifier
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
No sound but plays the dvd fine
I think this is due to wrong Audio settings.
Try to change audio setting as Stereo/Right or Left/5.1 from the Audio setup of the Menu
Dec 14, 2007 | Emerson SpongeBob SquarePants 3D Sculpted...
81 people viewed this question
 Grubhead
Grubhead
