Question about GPX KCL8806DT 7 in. Portable Television
Gray Screen, appropriate sound
When I turn my TV on, there is a gray screen. The sound works just fine. When I change the channels, the sound is accurate with the channel that displays. There is no picture. I would appreciate any suggestions that you may have to offer. Thank you!
  • 3 Answers
I recently did a repair on mine for a different reason and noticed this same condition when I turned it back on. I found that by squeezing the casing for the LCD the picture came back. I have not investigated further to assess loose connection, broken connector, etc. But I would start at this location (the LCD assembly). The internal board (main assembly) has all the pin connectors glued into place and the main assembly is not a moving part. So would suspect connection problems less likely here.
Posted on Mar 27, 2009
Kcld8886dtwht undercabinet lcd tv/dvd player has sound but no picture we have only used to a few times
Posted on Nov 04, 2008
I have same problem
Posted on Nov 03, 2008
My emerson LF391EM4F tv has a white screen
Most likely the T-Con board has failed.
Jan 26, 2017 | Emerson Televison & Video
Screen went gray during program. can't turn on or off by remote but can by tv button. cable checked out fine. is there a reboot button other than disconnecting power (which I did) the vizio name lights...
Hi
It sounds to me like you have a bad main board.
But it you may be better of by buying new TV
those boards run over $300.00.
You know the prices of a new TV's !!
Good Luck
Vizio have a parts distributor- Vance Baldwin you may give them a call, or call Vizio to find out if they have anybody else.
Mar 04, 2015 | Vizio L37 Television
Lg tv gray screen main menu screen flickers
tats something in the board its self youll have to take that to a tv repair man
Dec 06, 2013 | LG Televison & Video
Gray vertical bars on screen but no picture
It sounds like you might have shorted out the display panel driver board / boards.
These boards are located at the bottom of the screen and are prone to liquid damage.
Just before this happened, did you happen to spill something on the screen or clean the screen using a spray bottle cleaner?
The only fix I know of is to replace the whole panel but it is usually just as cheap to buy a new TV.
Nov 28, 2013 | LG 55LE5400 55-Inch 1080p 120 Hz LED HDTV...
Gray bars while full screen viewing my Broksonic CCVG-4500 42 in
hi, i have a broksonic model ccv-4500 , these is a monitor or tv because i cant founder the digital cable imput. thanks.
Apr 25, 2010 | Broksonic CCVG4200 42 in. Plasma TV
Gray box on screen with sound.
It sounds like you need to turn off the text mode in the closed captioning menu,
Jul 23, 2009 | Samsung HLT6187SAX 61" DLP HDTV
Black and gray boxs show up on my screen
try to hook up signal diffrent instead of rf go video, or s video
i would try video if you have original remote see what happens
Jun 13, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV is cutting in and out of color
My sony Trinitron TV just shows a padlock on the screan.Please help me unlock it.
Mar 16, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
GPX KCL8806DT 7 in. Portable Television Logo
301 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
