Question about Toshiba 26HF85 26" TV
Remote works but does not operate TV... no sound
My remote works but it does not operate my television. The picture is perfect but there is a clicking noise and no sound on the TV. Since this tv only operates the settings with the remote,I cannot do anything. Is it possible for the sensor to be bad and can it be fixed?
    Sergeant:
  • 337 Answers
The tv can be repaired by a qualified Technician,the replacement of the sensor ? should not be too expensive,the question is if the tv reacts to some remote commands or to none,if it does not reacts it could be the remote too.The sensors go bad but very rarely.Good luck.
Posted on Sep 18, 2006
Has a beautiful picture, but all of a sudden there is no sound. It was working one minute and the next it wasn't. I use the cable remote to operate the tv, not the tv remote. What should I do?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 29, 2016 | Honeywell Televison & Video
No sound coming from TV....recently relocated and ran TV from cable box, have lost remote to TV and now cannot get sound to work...picture good just cant get sound?
I think you are muting the the remote before you relocated...you need a remote to un-mute the sound of your TV...this cannot be done using the volume control in your TV unless you have the remote...if you loss the remote...buy a universal remote control
Sep 21, 2011 | Fujitsu Plasmavision P42VCA30EH 42 in....
Sony KV32FS120 Trinitron TV No picture or sound when power button on remote is turned off. Red light at front of TV blinks nine times per cycle.
Once your television blinks about 9 times then it means there is a problem somewhere most likely the lamp of the television. Another source of this problem is also a bad capacitor from either the main panel or the power panel.
If your remote turns off actually it is because there is nothing to operate on the television, so once your television starts the blinking light, the remote will not be able to operate the television, once you unplug the television and plug it back then press the power button, the remote will do the same.
Until the television is fixed is when the remote will work normally.
Take care and good luck
Dec 31, 2010 | Televison & Video
Tv wont turn on. toshiba 37c3030d
The internal power supply has died. take it to a repair facility.
Aug 13, 2009 | Toshiba 37C3030D 37 in. LCD Television
Grainy Sky+ Tv picture
Can't say it's a fix but when you press the tv button to make the picture better, cover the end of the remote and press sky so the tv and box don't pick it up.
It's more of a work around than a fix!
Mar 30, 2009 | Panasonic TH-42PHD8UK 42 in. Plasma...
Getting remote to control the menu
I'm not really sure why it's doing that...are you sure the remote has working batteries? I know that's a dumb question, but some times it happens. I just checked my remote and I have pretty much the same tv as you. Maybe you're just not operating the remote correctly. Click on the menu button, use the channel up and down buttons to scroll up and down. Once you got to something you'd like to change, click on "ok" to the right. To adjust sound, time, date, setup stuff, just experiment with it. You either use the up and down channel buttons or the left and right volume controls. Once you're done, click on ok. If you want to go back, press menu again. Hope it helps.
Jan 16, 2009 | RCA TruFlat 27F520T 27" TV
No picture - sound always on
1}Take batts out of remote,in case it is sending from a stuck button. 2)Check all tactil switches 3)Check for liquid spill damage in area of micro and tact switches.
Oct 03, 2007 | Sony KV-27V65 27" TV
SOUND BUT NO PICTURE
I HAVE A PROBLEM ON SHARP 21 INCHES THE PROBLEM IS NO VIDEO BUT THERE WAS A SOUND IF I PUSH THE CHANNEL UP AND DOWN WILL DISPLAY OR VOLUME OK BUT NO DISPLAY BLACK SREEN
Aug 26, 2007 | Sony KV-36XBR400 36" TV
Stand-by LED blinks-no picture or sound
the symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, video if,sound if, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service tecnhician
Jan 16, 2007 | Sony KV-32V40 32" TV
Toshiba 26HF85 26" TV Logo
119 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
