Question about Intermec EasyCoder 3400 Thermal Label Printer
I cant get the printer to not loose its initialization.
I checked the printer thoroughly, even the dip switches in the rear are set to spec just as the others in our network are... the only difference theirs work and mine doesnt...Help It wont hold its initialization settings.. it holds the format ok but not the other. do I have a blown board?
    Novelist:
  • 148 Answers
There is a battery i that holds the configuration and it is mounted on the board since it holds the fomat I think the battery is ok
since it holds the format ok you are getting something ( a space or character) in the data stream going to the printer
if you put the printer in manual mode dip switch settings 1 on to and 1 on botom you can do a test print and make sure you have label calibrated sometimes if dat will not it on label the printer wi not print
good luck
Posted on Jan 04, 2009
Torque specs for opel corsa 1.4 comfort utility 2005 model
Assume you are needing the cylinder head torque specs?
The head bolts are angular torqued and best practice is to fit new bolts and ensure all the female threads are thoroughly cleaned. I recommend greasing the bolt threads and washer faces.
The initial torque (following a spiral pattern) is 25 NM followed by angular movements of (degrees) 90 + 90 + 90 + 45
I generally start the engine and thoroughly warm up and allow it to cool before the final 45.
Nov 09, 2015 | Opel Corsa Cars & Trucks
How to reset fuser error konica 7030
In your case the soft switch will be 3-1-1 changing last bit to 0. if the code comes back do not reset as this code deals with the fuser it can catch on fire and that will ruin a perfectly good day.
Setting Software DIP SW1. Setting method
This setting specifies the software DIP switch on the software SW setting screen. (*1)Caution 1: The bit of the DIP switch is written in
the non-volatile memory every time it is
changed.
Caution 2: The numbers shown in the message
area are defined as follows:
Software SW 8-bit switch values in indicated in hexadecimals from 00 to FF.
Example: 04-7 : 1 A8
Bit data
1 : ON
0 : OFF
Bit number (0 to 7)
Switch number
2. Setting proceduresStep1
Operation procedure
Enter the 25 Mode.[25 mode menu screen] Hold Down the 25 and power on.
Press the [1. Software SW] key.[Software SW setting screen]Select DIP switch number.Use the left [  ] , [ ] key.
Select bit number of the DIP switch.Use the center [  ] , [ ] key.
Select ON (=1) or OFF (=0) of the DIP switch.
Use [ON] or [OFF] key.
[ON] : Set bit.
[OFF] : Clear bit.
Press the [Return] key to return to the 25 mode
menu screen.For each switch function, refer to "List of Software DIP switches".
25
May 24, 2014 | Konica Minolta Bizhub C300 All-In-One...
I am trying to send a dos file for printing to epson fx-2190. althought i have set the character table to 437-Greek my printer does not print greek alphabet
You would probably need to set the printer DIP switches to print Greek, however it is quite possible that this is not possible. Get hold of the printer DIP Switch settings and check. Alternately you will have to try the exercises using a GUI operating system to print the selected font style.
Jan 16, 2011 | Epson FX-2190 9 PIN Matrix Printer
DIP Switches don't seem to matter
You need to completely power off (wall switch or breaker) when changing the dip switches. Not just power off from remote because it will keep previous setting. I learned it the hard way....
Sep 14, 2009 | Hunter 27185 Remote Control
HP LJ2420 Not recognizing toner
remove left side cover, in the center there is a system of 2 black plastic levers, one has come loose from its mounting. Its pretty straight forward to see how it should go back.
Apr 01, 2009 | HP LaserJet 2420 Printer
Epson t88iii will not print
I would like to say sorry to you I got my serial port mixed up with the parallel port. I have resolved the problem, it was a DIP switch change which needed to be set. If anybody can not get their computer to communicate with the printer then I would suggest they download the Epson Technical reference guide and read it thoroughly, but only use the guides for your method of connection which is dependent on your model of printer. I found that for a baud rate of 38400 DIP switch SW 1 numbers 7 & 8 should be switched to ON .I hope this helps some else.
Dec 12, 2008 | Epson TM-T88III Thermal Printer
Thermal printer settings
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Please reference the user’s manual on page 11 and 12 for dip switch settings.
Jun 03, 2008 | Samsung SRP 350 Thermal Printer
Car stereo
Most current Pioneer car stereos needs two wires plus the ground wire to be activated. The yellow is connected to the always on B+12 such as the positive terminal of the battery, the red goes to a switched B+12 such as the ACC of the IGN switch while the black of course goes to the chassis/body ground.
Should the above been done correctly and problem persist, then perhaps the fuse may have blown, there is a loose connector at the rear of the head unit or a probable internal electronic defect has developed.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 05, 2008 | Pioneer DEH-1600 CD Player
Sony Model SMO-F551-01 MO Disk Drive Jumper and DIP Switch settins
We use a stand alone--single drive and a Jukebox with two drives. Both drives in the Juke box have 15 dips off and the #1 switch closest to the rear, switched on. The Standalone drive has all switches off. Our drives use terminators on the cable connectors on the rear of the drives.
Sep 12, 2007 | Sony SMO-F551-01 Tape Drive
Intermec EasyCoder 3400 Thermal Label Printer Logo
207 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
