Question about Insignia IS-LCDTV32 32 in. Television
Insigna lcd tv
The tv flickers & no sound for about 15 seconds when we turn tv on after that it works fine is there something about to go out
  • 1 more comment
  • Lrw19 Dec 17, 2008
    WHAT STARTED OUT AS 20 SECONDS HAS NOW GONE INTO 8 MINUTES. THIS IS RIDICULOUS. HELP
  • Thomas Pilette
    Thomas Pilette Dec 23, 2008
    started with sound and flicker ,now the set powers up to just back light and thats it no buttons input or any thing what causes this they wont help since the reciept is lost
  • Anonymous Mar 15, 2014
    46" insigna tv flicker on and off on SD channels
  • 905 Answers
Yes it is :( this is one of the common problems happening to these LCD's
you should call your local electronic repair shop imediately to get the problem fixed , otherwise it will do more dammage as other components are also going to fail and it will only get worse
if you have a warranty use that when you call your local electronic repair shop
sorry about your tv :(
electech
Posted on Oct 31, 2008
When we turn our TV on we get sound, but our picture is distorted for about 15 min then it's clear. Any sug?
Your TV is about 5 years old.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Feb 26, 2015 | LG 46LD550 46 in. LCD TV
Toshiba sl738b
- Flickering screen
- Dim screen
- Slow start
?Check the cables, connectors and connections.
Apr 11, 2014 | Toshiba Televison & Video
Vizio LCD dark screen and picture is flickering flashing
Your back light inverter is provably bad.
You can get get parts for this tv at www.interliquidparts.com
Nov 25, 2011 | Vizio 42 in. LCD TV
Sony Bravia No signal plus flickering image and
You know how to reset the tv to its factory setting, I think you are a technician. Second thing you can do is software update. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 . If it doesn’t work. Replace the Main board (UB board). Part # A-1547-086-A Cost approx $320.
Knowledge obtain from: Repair experience on same symptom.
Parts reference: Andrews electronics, 800 289 0300.
Apr 18, 2010 | Sony Bravia KDL-42V4100 42 in. LCD TV
No picture, no sound, green light flicker ongoing
The power supply in the Tv has failed and should be looked at by a qualified technician.
Sep 09, 2009 | Samsung Televison & Video
My tv screen keeps flickering on and off
  1. Need Model # of set and the brand so I know if its a plasma, LCD, or CRT set keep me posted
Aug 23, 2009 | Televison & Video
No picture
I had one that had a black screen and fixed the problem by repairing the inverter. When I opened the unit I looked at the capacitors on the inverter board and found them swollen. I looked at the bottom of the board and found that the fuse had opened up. The caps were a cheap quality low temp variety 150uF at 25V I replaced them with 330uF 25 volt 105C caps. I then replaced the 2.5A surface mount fuse with an axial 2.5A pico fuse and the TV worked beautifully.
Mar 26, 2009 | Philips 15PF5120 15 in. LCD Television
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Sep 13, 2008 | Westinghouse LTV-30W2 Television
Flickering tv screen when playing playstation games.
I don't think it's a configuration problem at all. I do think that the set is not adjusting to the correct format. Most Stores have 30 day return policy. If it's over 30 days then they may not take it back. If you bought it online, then, the return may be difficult. If the return is not possible, then, contact Toshiba online and find a local Toshiba authorized servicer in your area. Hope this helps.
Mar 18, 2007 | Toshiba 15VL33B 15 in. LCD Television
Insignia IS-LCDTV32 32 in. Television Logo
99 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
