Question about Toshiba 36A41 36" TV
36" CRT Toshiba has that vertical issue mentioned on here a bit
When we turn the tv on, either it comes on right away and goes to the problem shortly afterwards or immediately the problem occurs when the TV is turned on (after it's been off for a while). The screen starts out black, and can hear the sound, then a thin white line across the screen appears, then it starts growing above and below until it finally fills the entire screen. I can make it appear full sized if I lightly tap the TV on the side though. Question 1: Is it bad to be tapping the TV on the side, where more damage than good will come of it, and just let the picture slowly get to full-sized? Question 2: Should we get it repaired now, or wait until it progressively gets worse? It only happens once each time when we turn the tv on, or a few minutes later, and then it's fine after that. In other words, is it worth spending a few hundred $ on this right now, or wait until it gets worse, and how much worse can it get?
Noone - it's still doing it about the same amount of time, slightly worse, after 5 months...not sure when is the right time to get it fixed (maybe when it completely goes??) - right now it's just an annoyance. Can sometimes get the pic and sound back quicker if the back of the TV is lightly tapped with a finger, but that probably isn't a good idea. My question is this: Is it worth getting a 9 yr old TV repaired or just donate it / get rid of it? i.e. Ballpark cost on getting something like this repaired?? Anything over $150 or so isn't worth it.
Posted on Feb 04, 2007
  • 105 Answers
Your problem is most likely caused by a cold solder joint in the vertical circuit. Normally this is easy to find and correct. The problem will only get worse over time, but not likely for more damage to occur.
Posted on Sep 17, 2006
4 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: No picture Thin line across middle of screen
Most problems indicated by your description involved the Vertical IC. With your post "tap...pop back up" signifies a loose connection or to be more specific a cold solder. I suspect that no part(s) need top be replaced but would however require re-application of heat with the use of a soldering iron.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 19, 2008
johnnydiode
  • 647 Answers
SOURCE: When the TV is first turned on, thin white lines
On this particular model there is one capacitor from the video process IC (jungle IC) that supplies the Vertical pulse that shoul be changed.
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical. Be sure to vote/rate me if this helped Thanks!
Posted on Oct 23, 2009
tvrepairbiz
  • 63 Answers
SOURCE: My 36
You need to have the vertical IC resoderd I think it is ic301
Posted on Feb 15, 2010
Tv not coming on has a blinking power button
Toshiba CX36F85 36" TV Blink - Questions - Fixya
www.fixya.com > ... > Toshiba > Toshiba CX36F85 36" TV
Toshiba CX36F85 36" TV, blink related issues. ... Every brand TV will have its ownblinking ... stand by light blinks 6 times, wont power on tv is only 4 years old. ...From the number of blinks occur at one time switch ON, you can get an idea ...
Toshiba CX36F85 36" TV Blinks - Questions - Fixya
Toshiba CX36F85 36" TV, blinks related issues. Get free help ... Every brand TV willhave its own blinking codes. From the ... Push power button and it ... and then ... stand by light blinks 6 times, wont power on tv is only 4 years old. Junk! it wont ...
Toshiba power light blinking not turn Standard (CRT ... - Fixya
www.fixya.com > ... > Standard (CRT) Televisions
Jan 10, 2016 | Toshiba CX36F85 36" TV
Standby light is flashing and tv won't turn on?
The Toshiba sets are well known for vertical problems, if the problem is bad enough it will cause the tv to shutdown to protect the picture tube. To properly diagnose the issue a tv technician will be required.
Jan 16, 2011 | Toshiba 36A40 36" TV
1 vertical line across the screen maybe 1" tall. It appears to have the entire picture in that short little space.
tv turns its self off i unplug it plug it back in it will flash on not showing picture it u can her it flash on and right back of some times it will not flash in back of tv and i can hit power it will flash and go off every now and then it will come on show picture after being unplugged and plugged back but then shuts off
Jul 16, 2010 | Toshiba 36A50 36" TV
My Sony Trinitron CRT TV is not powering up. It comes on and goes off in a few seconds. The standby LED is blinking 4 times. I read somewhere that this could be an issue with Vertical deflection/power...
I had one of these in the 36" version blinking 4 times but it was not the vertical. It was the color amp ic at the crt board that was shorted and an open resistor. The repair for this, if my diagnosis is correct, should not be more than $100. Ask for an estimate though to be on the safe side. Thanks for using fixya.
Mar 11, 2010 | Sony KV-27V42 27" TV
My Toshiba tv picture has switched.
sounds like your power supply output is low. does the size "bounce" when pix changes?
Dec 28, 2009 | Toshiba 36A40 36" TV
Pin cushion adjustment on Toshiba TV 36" CRT
Pin Cushion, someone is pulling your leg.
Oct 26, 2017 | Toshiba 36AF61 36" TV
TV Shut off will not turn back on
the vertical i.c. is shorted, replace it.
Dec 20, 2007 | Panasonic CT-36D31 36" TV
No Picture on my Toshiba television
Try hooking the tv up to the back with the right cords. Turn off 1st and replug the tv and turn back on.
Nov 26, 2007 | Toshiba 36A43 36" TV
Toshiba 36A41 36" TV Logo
283 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
