Question about NEC SuperScript 1450 Laser Printer
No printing I am not getting it to print the paper is coming out plain, black or just spotted. Please help me. Regards, Ms. Gomes.
0 characters
1 Points
I have a Brother MFC-6490. The printer can not print in black. The black cartridge is new. There is no problem with color printing. Thanks for your help.
Remove the black ink cartrige and rub the print head into a plain paper with rubbing alcohol until ink flows. If not rubbing alcohol, no problem. Just rub the printhead into a plain paper.
Then try to print again. I hope it helps you. Please post comments if you need more help. Regards
Apr 09, 2011 | Brother MFC 6490CW InkJet Printer
New black ink cartridge is fading in and out and leaving lines on paper. Do I need to clean something?
Yes, you need to run the print maintenance like print nozzle and print alignment page to check to clean the print head and to check if it prints fine.
If still not working, remove the ink cartridge and rub it into the plain paper with alcohol. Let ink runs until it flows.
Please let me know if you need more help and please rate this solution if you find it helpful to you and to others.
Mar 01, 2011 | Canon PIXMA MP460 All-In-One InkJet...
My HP photosmart 2710 all-in-one has "spot sensor
The Spot Sensor Out of Calibration error comes due to color paper placed in paper tray.
Follow the steps to resolve this issue.
1. Under printing preferences set the paper type to plain paper instead of automatic. This makes it so that the spot sensor doesn't need to look at the paper.
2. The spot sensor, when calibrating, needs plain white paper. Setting the plain paper instead of automatic helps if you are just printing, but colored paper makes the spot sensor confused during calibration.
If you are still not able to print, there is a utility program that fixes the issue too and which will be helpful for you in future use too. Click on the link to download the utility program : Utility download
Hope this resolves the issue.
Nov 04, 2010 | HP Photosmart 2710 All-In-One InkJet...
I have a Brother MFC 465CN and cannot get the black ink to print. I have cleaned it several times, and am quite irritated! If i print a page from my computer, the colours come out fine, but not the...
Another user here suggested that you change the Media Type in Printing Preferences to 'Inkjet Paper' instead of 'Plain Paper' and this worked for me. Of course I don't know if it's pulling from the black nozzle or not, but I do get black now.
Dec 26, 2009 | Brother MFC-465CN InkJet Printer
Printer picking wrong tray for print
From the start menue to printers and faxes go to your printer right click and select properties label the 4 drawers as to paper type and select continue, or auto continue to off.
-Carl, please let me know if this helps.
Jun 26, 2009 | Xerox Phaser 8560MFP Laser Printer
Won't print black when set for plain paper
Try removing all ink bins except black then you won't have any problems. You should also be able to go into your printer settings and select "Black and White" or "No Color" and it will print ok. Removing the ink trays is the easiest way though.
May 28, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Paper Type and weigth Fot Lexmark C912
Media paper weight: is 20lb or 75gsm.
Media type: card stock, envelopes, Glossy paper, Paper Labels, Plain Paper, Transparent.
Media size: A3, A4, A5, Banner up to 11.69"x36", Executive, JIS-B4, JIS-B5, Ledger, Letter, legal, Super Tabloid, B5, C4, C5 DL, 7 3/4 9, 10 Envelopes.
demension is in inches, you need to convert it to centermeter.
Oct 30, 2008 | Lexmark C912 Led Printer
Blac Spots on right side of page
This generally happens when,
The paper is mismatched to the paper setting for the printer.
For example, if you are using high-quality photo paper, set the printer's output for that paper; do not use the plain paper setting.
Post your response about how things turned up and i can help you up from there.....
Oct 01, 2008 | HP Deskjet 6940 InkJet Printer
HP 7310
Both these issues could be caused by a dirty media sensor. If this is the issue you may be able to improve things by selecting "plain paper" rather than "Automatic".
You can also try cleaning the sensor. The sensor is on the bottom of a black plastic piece mounted to the side of the carriage. Open the printer lid as if you were going to change the cartridges, then gently move the carriage about an inch to the left. There is a small black part mounted toward the bottom rear of the carriage. The sensor is on the underside of this. You could try cleaning the sensor with a damp Q-tip. Be careful not to get in the service station area where there is waste ink. This can be messy, be especially careful not to get ink on the sensor.
If the sensor was the issue normal printing could take several hundred passes of the carriage, with the paper moving just a bit after each swath. There is another possibility for slow printing, where the printhead pauses for 8-15 seconds at the end of each swath. This may be caused by a cartridge issue. In this case try removing the cartridges and cleaning the contact pads as shown here (for a different printer series, but similar....). If the carriage still pauses for 8-15 seconds after each swath then one of the cartrdgies will need to be replaced.
Bob Headrick, MS MVP Printing/Imaging
Jun 18, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP photosmart C4200 successfully installed and prints only on white paper. Unable to print on conqurer paper.
What is the problem - does it feed the paper or just nothing comes out when the paper is fed through to print
May 08, 2008 | Printers & Copiers
NEC SuperScript 1450 Laser Printer Logo
19 people viewed this question
Top NEC Printers & Copiers Experts
Martin Murray
Anthony Chiang
Anthony Chiang
Are you a NEC Printer and Copier Expert? Answer questions, earn points and help others
