Question about Philips Magnavox MWR10D6 DVD Recorder
Magnavox dvd recorder & 4 head hi fi stereo vhs with digital tuner
Just bought it, set it up and menu will not come up.
  • 44 Answers
How are you connect to the tv. Make sure on the back you have your color cables on the VIDEO OUT section and are going to the back of your tv. Now that just will work as a dvd now if you want to record you have to get that screwy antenna cable thats on your tv. YOu want to unscrew that one off your tv and put it in the dvd recorder under ANT IN the cable that was provided with you goes to ANT OUT back to your tv !!! if that cable is too short just "find another that's longer and will suit your situation. Keep in mind if you dont have the color connections it wont work and you will have to buy another unit its called a RF modulator and which converts the signal for you and works the same. Rf modulator runs at 5-20$. THATS ONLY IF YOU DONT HAVE THE COLOR CONNECTIONS ON YOUR TV. IF YOU DO HAVE THOSE CONNECTIONS, you need to get your original tv remote and look for a button on the remote that says input, tv/video (the name of the button varieties from tv companies but it has something to do with video) the reason why we are looking for this is because your dvd recorder needs to be put on this special channel to operate from there you will be able to change the channels
Posted on Oct 31, 2008
Recording Error-Cannot record on this disk. . New disk
Check on different/various format disks...if it will not write to any may have developed a component fault or the reading lens may simply need cleaning with something like isopropyl alcohol.
Ensure the machine is unplugged if you do the cleaning internally
Jul 07, 2015 | Magnavox ZV457MG9 DVD Recorder and 4-Head...
Does the JVC DR-MV5S DVD recorder/VCR combo unit have an analog tuner or digital tuner, so that you can record one channel while watching a different channel on your TV?
You can read what JVC is telling about the recorder. It is not an digital tuner, but still you can record a DVD and watch another channel or vice versa.
Want to read the whole manual? click the link:
DVD Recorder Hi Fi VHS Combination DR MV5S Introduction
Jul 25, 2014 | JVC DR-MV5S DVD Recorder/VCR
Recrod vhs to DVD dubbing
Unfortuneately a lot of products are not consumer friendly leaving people confused about what to do.
Mar 04, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
I cannot record digital when I try to set up my Magnavox ZV457MG9 (DVD). The unit will only record in the external L1. I have a Comcast box.
This is normal for the ZV457MG9 units. The Magnavox ZV457MG9 does not have an analog (NTSC) tuner; additionally there is no digital (ATSC or QAM) tuner either. It will only record on line in (L1) which is a composite input (limited to SD). The HDMI port on the recorder is an HDMI out to TV, not an input. The component video jacks are also only outputs.
The manual for the Magnavox ZV457MG9/F7 is available here: http://download.m4c.magnavox.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf . The unit was manufactured for Magnavox by Funai; thus another link to the manual is http://www.funai-corp.com/6pdf/om/ZV427MG9.pdf .
I wish that I had better news for you.
(If your DVD/VCR recorder had a tuner, it would record off a coaxial (antenna) cable input. Many DVRs can record off the HD connection (HDMI or component); that may be a better option for replacing this Magnavox unit.)
Oct 01, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
Need to know if I can record from dvd to vcr on a magnavox ZV420MWB vcr/dvd combo
Magnavox ZV420MWB VCR/DVD Combo
The answer is YES YOU CAN! Take advantage of one-touch recording from videotapes to DVD+/-R and RW discs or from DVDs to VHS tapes. A variety of different inputs also let you record from compatible camcorders, external TV tuners or cable boxes.
CONSUMER ALERT: This model does not have a built-in tuner for recording TV programs and will not record copy-protected tapes or discs. For more information, call the Federal Communications Commission at 1-888-225-5322 (TTY: 1-888-835-5322) or visit the Commission's digital television website at: www.dtv.gov.
Feb 15, 2010 | Philips Magnavox DVD/VCR Dual Player
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Error code E 4 54040990
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Dafid
Apr 16, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Philips Magnavox MWR10D6 DVD Recorder Logo
147 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
